can aging be artificially induced?
Jerry Gibbs
I have a walnut slab that has heartwood and sapwood. I am still debating whether to stain the heartwood so that it doesn't lighten over time. Is there a practical way for a woodworker to speed up aging to see the effect of time and light on various combinations of wood, coloring and top coating?
Re: can aging be artificially induced?
Cameron Hood
Marriage usually does it!
I'm telling what you said!!!
Bill Howatt
My first thought is that an intense UV light source might do it. Maybe also higher temperature storage for a while but strictly guessing.
Bill
There are laboratory devices that accomplish this task. They combine high intensity UV light, oxygen, and moisture, in various combination, to achieve accelerated ageing.
For the home shop the summer sun will best accelerate ageing.
Re: I'm telling what you said!!!
Cameron Hood
Prior to posting, I asked permission! And she said that my statement was true--she had the grey hair to prove it!
Ralph Lipeles
I've used a dilute solution of Chromic acid. Swab some on the wood, let it dry, repeat as necessary to get the effect that you are looking for. Then rub the piece with a damp swab to remove any Chromic acid residue
Note - Chromic acid is bad for the environment. Excess solution, swabs and anything else that was in contact with the acid must be collected and properly disposed of.
Ralph Lipeles
heavy boozing and unfiltered Camels
Three reasons not to use chromate
1. The typical procedure for using chromate is to apply, dry and sand because application roughens the wood. Wet wiping will dilute but not remove the chromate from the wood. Subsequent sanding will make the chromate airborne. Chromate is one of the few proven carcinogens by lung exposure.
2. The environmental hazard is overblown. Never-the-less, the environmental hysteria has led to laws regulating it use, storage, disposal, etc. If a neighbor that hates you learns you are using chromate there are states where this information could become a big problem for the unprepared user.
3. Chromate does not age wood. It colors it by binding to the tannins in some woods. Premetallized dye stains will produce the identical color and be more light fast.
jim Hoeller
I have used lye (sodium hydroxide) to age cherry. One teaspoon to a pint of warm water worked quite well. i have also used ammonia to age white and red oak. Ammonia fumes do the work and require a sealed container or tent and should only be used outdoors preferably in warm weather. I don't know how either will work with walnut.
coloring vs aging
I regard aging as the effect of light and oxygen on wood and wood finish. Some woods change color and then bleach, walnut for example, as they age. Most woods darken, for example maple, ash, cherry. Most finishes become more yellow.
The above process and result is different from coloring wood by various means. The color can be added in the case of dyes or created by the action of chemicals on the wood constituents in the case of ammonia, chromate or caustic treatments.
I did some light fastness studies on mahogany colored by ammonia, caustic and chromate. The caustic and ammonia color bleached relatively quickly by accelerated aging in a weathering machine. Chromate bleached more slowly. Best of all were premetallized dyes by Mosher, and others.
Steve Schoene
A friend specialized in William and Mary reproductions. To make the walnut appear the appropriate aged look, his practice was to bleach the wood using 2 part wood bleach. This gives a very light--generally about cream colored wood. Then applied dye and stain to get the aged color make the finish look right.
Rob Sandow
I have walnut pieces that I made over 10 years ago. My experience is that heart walnut will not change that much with age. If it started with a mild purplish hew this will shift to a more coffee-like color, but it will not lighten up anywhere near the color of the sap wood. Then again, I avoid commercially kiln dried walnut which is steamed to attempt to blur the lines between the heart and sap wood so that both can be salable. All of my walnut is either air dried or dried in homemade kilns. I would probably not attempt to blend heart and sap walnut, and just remove the sap wood to use as a secondary wood.
Re:artifically aging
Larry in NW Ohio
I know that after getting married @ 27, and after having 3 children, 9 grandchildren, it seems like only the next day I`m 67 and a grandfather. I know I had fun in there somewhere, because I still have a smile on my face. Larry
Ebrace your sap!
I don't know your project so maybe sap wood could be a problem. As for me, I let the sap wood show in some of my work. And by golly it can look quite nice!
T.
Re: Ebrace your sap!
Jerry Gibbs
The project is a walnut slab that will be a desk top. I want to preserve the live edge and the contrast between the heartwood and sapwood. Jerry
The contrast will always be there. With lacquer the walnut heart will bleach first to brown and then a lighter yellowish brown. I think it unattractive personally.
Forget the reds and purples for they will change to a chocolate brown whatever you do.
Oil it and the sap will turn some darker and the heartwood much darker. The contrast will remain and stay that way over time. I have oiled gun stocks that are nearly 100 years old and they look about like an oiled gun stock 2 years old.
Varnish or whatever over the oil to protect if you wish.
I don't think staining is the thing to do for the effect you want.
