ADVERTISE HERE - FREE TRIAL
Need part for sander
David Frame
Hi All,
Does anyone remember the model #335- 6" QuickSand Random Orbit Sander from Porter- Cable. It's not a right angle sander. It is exactly like the old Model #333"- 5" 5 hole. They are the both older model ROM's that had to have their sawdust catch taped in place. Anyway, I need a new hook and loop pad with 6 holes. It has three screws that hold it on to the sander. If anyone knows where to find a few, please contact me. I would be grateful for your assistance.
David Frame
P.S.
Porter- Cable doesn't even have it in listed their inventory.
Re: Need part for sander
David Frame
Hey all,
I forgot the part number. It's #13906.
Thanks,
David
Bruce, a MN Galoot
I don't know about the 335, but I have a 333 and needed the H/L pad. My local decent tool store (Thomas Tools, St Cloud, MN) had them in stock on the shelf.
Re: Need part for sander *LINK*
Bob Entwisle in NJ
David,
Not sure if this is what you are looking for or not, maybe try to give them a call and ask, the part number in the link does not match the one you listed, but the web listing says they have pads for among others, the 335.
I've no experience with this vendor just found the link via google.
Hope this helps,
Bob in NJ
http://www.mikestools.com/sanding-pads_2117.aspx?page=2
I have one of those. The pads don't last long, at least not as long as they used to. Home Depot carries the pads. They are in the tools section at the right end of the sander section all the way at the top. About $14. I keep a spare on hand and have several worn ones also. (If they stop stocking them I will glue on new H&L.) They are 5 hole though. If you can't find them, let me know and I will see if they still have them and ship you one.
Stuart Johnson
Try here. I've purchased from them several times and received quick, accurate service. Their shipping might be on the high side so order any additional parts you might need at the same time.
I just check the diagram and notes. The part is no longer available. I would delete this post but the company does have parts for a lot of items.
replacement parts
David Frame
Stuart Johnson has it correct, but the part is discontinued.
David Frame
Thanks
David Frame
Stuart,
They discontinued the part. I may buy one from another company and if it's a close match, drill the holes myself. We'll see.
Thanks a lot man,
David
Re: Klingspor has some but 335?
David Frame
Hey Dick,
Close but no cigar.
Thanks,
David F.
David Frame
Thanks,
David F.
http://www.ereplacementparts.com/porter-cable-335-type-634-random-orbit-sander-parts-c-129_1997_14505.html
David Frame
Close, but not quite. It has 3 small screws on the bottom. The link you sent is for a right angle ROM sander.
Thanks man,
David F.
David Frame
Bruce,
I have a 333 too. the 335 is 6"- 6 hole.
Thanks,
David F.
Sorry, I did not read carefully enough to pick up the 6" part. I have glue new hook and loop/velcro on disks. Run the current one on a belt sander or some such and grind the rest of the loops off, leaving a level but slightly rough surface. Then you can glue on new velcro. I think you can buy kits for doing this.
Jerry Roberts
hi David. I have a like new PC 335 and hardly ever used it. The Pad turned to mush and I couldn't find another one. Good ol PC don't make them any more . Its been in the box for a couple years now. Good luck. Oh, if you find one, let me know.
David Frame
Jerry,
If I happen upon 4, I might let you have one. LOL
David F.
David Frame
Barry,
I would normally tell you to soak that thing in acetone, buuuuuuut you know what will happen.
You could try minreral spirits. A really thin layer in a flat plastic bowl and then put the cover on it???
Or a really thin layer on a small piece of glass then saran wrap it? It might work.
David F.
Stuart Hough
David, I was looking for a replacement H/L pad for my Ridgid ROS in Home Depot a while back, and looked at the PC and Dewalt replacements they had as a final option, to drill and modify one to work on my unit. The PC and Dewalt are both 3-screw attached, and IIRC, the holes line up. You might want to look into that approach. From what I remember, the Dewalt pad is a bit more robust, and should last quite a bit longer, assuming that the PC unit won't suffer a rejection crisis, being "frankensteined" that way. Good luck!
David Frame
Hi Stuart H.
What is IIRC?
I have been looking into this option, I just didn't know which pad to go with. Thanks helping me look in the right direction. I've been so busy in my shop that I've not had time to deal with it.
By the way, this may be "Bride of Frankenstein" instead of Frankensteined because she looked better than him when the good doctor finished with her. Frankenstein is what I call the pad after it sits for a while and destroys itself. LOL
Thanks Stuart,
David F.
David Frame
Stuart,
Can you tell me what 6" model number Dewalt H & L pad closely matches the 6" PC 335 ROM?
Thanks for your time,
David F.
Larry in NW Ohio
David IIRC means If I Remember Correctly. Larry
J. Waters
David,
I think the Dewalt 151416-01 for the DW443 or such is the 6" Hook and Loop pad, they aren't cheap, but there are some generics on Ebay. HOWEVER, the 6" Dewalt appears to have 4 HOLES not three.
I have personally used a DeWalt 5" H&L pad on my PC 333VS (and DeWalt/Porter Cable sold it to me and told me it would fit as they were out of 333VS pads). It was a little tight where the screws go through but once each was started, they screwed all the way in.
Hopefully, you kept the bad pads as they have a fiberglass back and you can scrape off the foam and then use a solvent to get the goo off. You could center it up on another brand 6" pad and drill the holes.
No guarantees on these ideas, but hope it helps-Jason
P.S. Re: Need part for sander
J. Waters
I just went in the garage and compared my 5" 333 pad holes to the 6" Right Angle pad holes and the 3 rivets that are one the 6" Right Angle pad do NOT line up with the 333 pad (so it would not with your 335 either). I was thinking you might cut just grind out the rivets and punch them down through the pad (with some careful cutting) and it would line up, but it will not, you would have to drill new holes.
David Frame
Hi J,
First I looked into purchasing a Dewalt #DW443 and eraplacementparts.com wants $36+ dollars for that particular pad. The pad I have is a 3 screw hole and the Dewalt is 4. That's not a big deal though. I just won't pay the high price demanded for that H&L pad. And yes, I did keep the old velcro and platen and I am in the process of scraping off the foam on it. I was able to find some really dense foam for the PC #335 platen and H&L velcro. I am going to put the contact cement to it.
Thanks,
David F.
