Jet bandsaw switch
Jet bandsaw switch
Jet bandsaw switch
Joe in a Cleveland suburb
This switch on my bs is not very good. Never has been. It's about 12-14 years old. The design of it is such that whenever you press either button it will stick and not push in if you press slightly off center causing the plastic button to go down at an angle. So, often you have to fiddle with it to power off.
I looked on Amazon and there is a brand called Woodstock. Wonder if they are any good or just as cheap.
I don't think you can lubricate plastic like this, can you?
Thanks.
Re: Jet bandsaw switch
Keith Newton
They are pretty simple, and you may be able to lubricate it if you can get it apart. The Start button, is a momentary contact, and the Stop, will be a normally closed set of contacts. Both may just have a little shaft, which could be lubed. Try something that doesn't attract dust. And if you have them all the way apart, check that the contacts are not pitted.
Larry in NW Ohio
Joe I have one of them around here somewhere`s, I can`t look anymore tonight, but first thing in the morning I`ll look around. Larry
Alan in Little Washington (NC)
That is mechanical switch, not a low voltage switch like you described.
sorry...
I didn't explain the problem very well. Pictured is a picture of a cover. The cover has these plastic green and red buttons. Those are what stick. The actual switch, with the cover off, seems to be fine.
Hope I'm making sense. Probably not ...
Thanks
Woodstock is Grizzly, and it probably came
Dick Coers
from the same place that Jet uses.
Try some lube
Graphite or whie lightning (bike chain lube) should cut the hangups for you.
Cheap and handy alternative
While they are not rated for operating motors I have found that a heavy duty "light switch" handles 0-2 HP motors just fine and lasts decades. I buy the most expensive double pole switch ( a few bucks) that is on the shelf at Lowes or HD. As an example I have one on my band saw with 1.5 HP motor.
