Spindle Sander??
Tom
Have a project coming up that a spindle sander would be a great benefit. I was wondering what you guys have gone with as far as a bench top unit?
Thanks!
Spindle Sander??
Tom
Thanks!
Re: Spindle Sander?? *LINK*
John in NM
I spent a little more and got the one that has an oscillating 4x24 belt too...
Home Depot sells them for $299. So far its been a fantastic little machine, saving me a lot of time. We'll see how it lasts over the long term.
There was a great deal on spindle sleeves too, mostly coarse and fine, no medium. Some surplus dealer bought all the individually packaged ones when HD went to the $15 set of them instead. I think the link is where I got them, but most are gone now. I was buying something like 10 for $4
http://www.toolsnow.com/SearchResults.asp?Search=sleeves
Delta *LINK*
Dick Coers
but it is probably 15 years old. But no idea what todays machine is like.
http://www.amazon.com/SA350K-Shopmaster-4-Horsepower-Spindle-Complete/dp/B00006JZZW
Ron in Sterling, CT
The older Delta Units (Boss) are built to last, & do a fine job. I don't know about the newer ones. I picked up a used Ryobi at an auction several years ago. I don't use it a lot, but it has served me well and gets the job done. They are a great machine to use when you have an application that they are designed for.
Ron
Larry in NW Ohio
I have a Ridgid I bought maybe 10 years ago and really like it. It has the up and down spindle and it also changes to a 4X24 belt sander, which can be very useful. Of course I don`t use it everyday but it works very well for me. Larry
del schisler
Larry that is the one i have and use it a lot , never had any problum's with it , just remember to leve the nut that tighten's the spendel down LOOSE or it will get so dam tight you can't get it loose with a pipe wrench , that happen to the first one , i took it back and they gave me a new one i had a lot of spair parts left over , didn't take all the item's back, they didn't want them any way,
Re: PC *LINK*
Kneale Brownson
I have the PC hand-held oscillating spindle sander that I sometimes mount to a piece of plywood with a hole in it to use as a benchtop oscillating spindle sander. It has a range of spindle/sleeve sizes and can be used in the hand to work on pieces too large for a benchtop.
http://www.portercable.com/products/ProductDetail.aspx?ProductID=11068
Tony - Memphis
I have been using a BOSS for many years. No issues other than a broken gear box cover which they replaced after I commented about it on a forum (somebody from Delta saw my post - not a complaint, just a note). I had glued the cover back together and it was fine.
The table does not tilt, but I have never felt the need for that. Spindles are easy to change.
Tony
Re: Spindle Sander?? ++ Ridgid Model EB4424 *LINK*
Bob Entwisle in NJ
I've had one for several years, great little machine for the occasional spindle sanding requirements that come up.
About 200 bucks at the Orange box.
And I agree with Del, store it with the spindle nut loose.
Bob in NJ
https://www.ridgid.com/us/en/oscillating-edge-belt-spindle-sander
Joe Mohnike
I started to get a Ridged drum sander from Home Depot, but found out the store does not nor will they order the sanding drums. I went to Harbor a lot cheaper and they stock the drums. Have used it a lot and no problems. It is small enough to keep it under the work bench and set it up when needed.
I have the JET JBOS-5 benchtop oscillating spindle sander. I have used it extensively for several years. It is sturdy, runs smoothly, is very quiet, has a tilting table, and I think the travel of the oscillation is greater than many of the other bench top models, and the drums are longer (6", instead of 5-1/2"). The only minor drawback is that it is not really good at dust collection. That is at least partially due to the additional clearance required under the table for the tilting top mechanism. Unlike some BOSSs, you can easily clamp a fence or a dust collection hood to the top because there is clearance at the edges all the way around the table. That's convenient if you want to convert it for use as an oscillating thickness sander. I also bought and use a larger diameter (3", IIRC, but I'm not going to trudge through a foot of snow and slush to the shop to verify my measurement) accessory drum and sleeves. However, this accessory may have been discontinued.
If you can afford it, the JET JOVS-10 floor mount spindle sander is also an exceptionally competent and durable machine, but probably overkill for most hobbyists and one person shops.
John in NM
The nut on mine tightens up when using the belt, but not the drums. Heeding your warning from when I first bought it (thank you
), I just tighten that nut to "snug" when installing the belt fixture and then use vise grips if needed to remove it. About half the time I don't need the pliers to remove it.
I figure if the nut wears out under that treatment, I'll make a brass one instead, or maybe a stainless one with a hex head so I can put a box wrench on it.
Re: +1 for Ridgid
David Hay
I got the Ridgid spindle sander for Christmas and have found it pretty nice to for the couple of small projects that I've used it for. I'm sure there are nicer and heavier duty machines out there, but for my needs, it's just fine. Definitely a nicer than the drum unit I had for my drill press.
David
