Need a smoke alarm with a
Larry in NW Ohio
Corbon monoxide and a natural gas detector in it. Does anyone know of such a toy. Thank You Larry
Larry in NW Ohio
Re: Need a smoke alarm with a
Ralph Lipeles
I never saw a combo but I bought a CO detector last year at Home Depot.
Ralph Lipeles
Here is one *LINK*
mdclor
3 in 1 detector
Time for me to get enlightened about alarms
Bill Howatt
Hi,
I have a combo CO and natural gas monitor (no smoke detector) but I thought the instructions said it should be mounted low not high since the natural gas is heavier than air - I believe that CO is a little bit lighter than air so it will eventually rise.
I await erudite comments with thanks,
Bill
They're both lighter than air
Tim Greif - West of Chicago
Both CO and natural gas are slightly lighter than air. However, both will mix with air and become dispersed, creating a pretty homogeneous mix. In my engineering past, we put combustible gas detectors (mainly for methane) up high on the wall. In a home where air is being pushed around by furnace fans, I don't think it will matter if you put them up high or down low. In completely still air situations, it might matter.
This advice is worth exactly what you paid for it.
Re: Natural gas is lighter than air
while propane is not.
- other facts - Natural gas (methane) is quite a bit safer than propane for a couple of reasons - propane will "pool" in basements or low areas of buildings while NG will rise and dissipate into the atmosphere. The "LEL" (Lower Explosive or Flammable limits) range of propane is 2.1% while natural gas must reach a concentration of 5%. However natural gas does have a higher "HFL" (Higher Explosive or Flammable limits) of 15 vs propane of 10.1.
As to CO (carbon monoxide) I found the following facts:
"So how does CO compare with air? It is 3% lighter. So it distributes very easily through a house.
But when CO is produced, it immediately begins mixing, and therefore diluting, with the air around it. Therefore, it mixes with nitrogen, which doesn't burn, oxygen, which is burned creating the CO, H2O (humidity) and CO2 which are in the air. So the CO produced is not in pure form in the air. It is very diluted. And as CO is produced, it is warmer than the air around it.
So what is the most advantageous place to put a CO detector? CO moves with the air, so where the air is flowing it will go also. It is very unpredictable where the air, and therefore CO, will move at any given time. That is why the instructions with the unit you buy do not say to place it high or low on the wall.
Understanding all that, the National Fire Protection Association (NFPA) suggests in 720, 2-1.1.2* 1998 -
"A carbon monoxide alarm or detector should be centrally located outside of each separated sleeping area in the immediate vicinity of the bedrooms. Where bedrooms are separated and the audibility of the alarm or detector to occupants within the bedroom area could be seriously impaired, more than one unit could be needed. Each alarm or detector should be located on the wall, ceiling, or other location as specified in the installation instructions that accompany the unit."
