So, I got the veneer cut, my plywood form built, and tested it all.
It all bent easily around the form.
The real glue up should go ok.
Not sure how, once it's glued up and dried, how I will rip the U-shaped, or half round, apron to its final width. Band saw or table saw I suppose. Not sure I would feel safe using the TS for this though .
Hopefully I will be able to do this glue up this week.
You're going to need more clamps and blocking that is the full height of the apron. The layers look like they have serious gaps between the layers. Trying to force glue out of the layers is going to take more clamping area and clamps that will apply pressure to the full width. Not just the center of the glue up. Run it on the jointer to get a flat, square edge, then table saw.
I would go with much bigger blocks on the outside, you want to cover 80-90% of the outermost lamination's face to ensure that you apply pressure as evenly as you can.
Other than that, it's looking great!
I trim stuff like that on the bandsaw. Joint one edge first, rip to width and then joint again (lightly). Nothing to it.
I've done it on the table saw too, a full round skirt that the boss wanted a 1/2" trimmed off of. It was a little unsettling at first, but went fine.
When gluing up laminates around a form, you want to have even distribution of clamping pressure on the entire surface of the lamination. You can't do it with little blocks around the outside of the laminates, because your clamps are transferring the pressure only to those parts of the laminates that your clamp blocks are actually contacting.
I rip strips of 1/8" masonite, the same size as my laminates, and stack them around the outside of the veneers themselves -- in a case like this, to probably an inch or so (8 strips). Then I cut full-height clamp blocks to go outside these "caul strips" such that they transmit pressure to the entire surface, as shown by the dashed lines in the drawing below.
It is very important to wax these masonite strips -- and your form and the base it sits on -- thoroughly, and to use a layer of wax paper between the form and the laminations and the strips, or else the whole shebang will become one glued-up lump.
Nobody has addressed the spreading of glue. If you are using white or yellow thin it 5% with water to reduce the viscosity. A 2" stiff bristle paint brush is the trick (Headley shop trick). For scraping/spreading excess glue a credit/room key card works well. Take a fine triangular saw file and file fine, closely spaced teeth across the long side of the card. Run it across the veneer that has the glue applied (Finck trick) to spread, level and remove excess glue.
It will take a long time for the glue to set. Think of how much glue and water you will have for the amount of wood. If you use the Masonite as Ellis suggested the loss of water is going to be even more retarded. It could take days to dry in a cool shop.
When it comes out of the clamps joint on jointer, then saw on table saw. You will appreciate the suggestion of using a 40T 7 1/2" thin kerf blade when sawing this piece.
I'm pretty sure I will use the bandsaw & jointer like you say. I've seen articles and so on at FWW using the TS for this type of thing. That looks a bit risky to me. It just looks like an accident wanting to happen.
I was going to put clear packaging tape all over everything I don't want glued. That always seems to work when I have messy glue-ups. I can see using wax paper too with the masonite.
"It will take a long time for the glue to set. Think of how much glue and water you will have for the amount of wood. If you use the Masonite as Ellis suggested the loss of water is going to be even more retarded. It could take days to dry in a cool shop."
After it gets glued up, it will sit clamped up for a number of days. I'll probably take the whole mess up stairs out of the cold basement where my wife keeps the thermostat at a balmy 62 degrees...
All good advice so far. As you have realized this is something to have well thought out and everything ready before you start. Once the first drop of glue hits there is not time to stop and go get something.
The packing tape works well and so does the wax. Do both.
The Masonite cauls are an excellent idea. Learned that the hard way.
Bigger blocks and more clamps are a good idea. You might like to fit the blocks around the perimeter and number them and then cut a notch or groove in them for the clamp to avoid its slipping.
Thinning the glue 5% is a good idea. I also took a damp cloth and wiped the opposing surface.
I found a plastic "trowel" that had fine notches on the edge in the tile dept at the borg. It worked well. Bill's credit card idea works well too. I save room keys for trips just for this purpose. I have used a roller, but if you do you want to use a fine nap one and getting the layer "just right" seemed harder. Maybe a combination of the notched card and roller? Put it on the the roller and smooth it and take it off with the card. I have one of those roller applicator bottles that might work well for this. the trick is to get the surface covered with just enough glue to thoroughly wet the opposing surface and leave very little for squeeze out. Remember if there is excess glue along the center line, its a long way to squeeze it to the edges.
Might be good to wear disposable gloves although I tend to get them clamped in the middle of things.
When you clamp, start at the center and tighten that clamp. Then put of the ones to the left and right and tighten them. Tighten the center one some more. Then the next two and go back and tight the center one and the next two again. You are chasing the slack left and right and the glue out top and bottom by checking and adjusting the pressure as you go. You may find the clamps will continue to tighten. You are compressing the wood a bit and squeezing out glue and perhaps closing gaps.
Thanks for sharing this. I've never done this, but would like to someday. I watched a Rough Cut episode this weekend where he made a laminated chair. It was quite involved. He cut it on the TS and I was thinking the whole time that it looked a little dangerous. I built a round table a while back and made 4 sections. Looking back, I would now make two sections. I had eight M&T joints to wrestle instead of 4 with two bridle joints - next time.
Good luck with your project. A similar technique I have seen is making fishing nets. That looked like a fun project, but I don't fish or know anybody that would use one.
I've used one with the plastic resin glue when I was doing a bunch of these. First time I used a bristle brush not having a little foam roller handy. Roller works vastly better in terms of applying just enough glue evenly rather than too much in some spots and too little in others. It's also faster than a brush.
You method kinda sounds like putting down adhesive like when you are putting down tile, is that correct?
yes. I use it for spreading and removing excess. Maybe the foam roller will render it unimportant. You have a lot of glue to apply. What ever you do you need to work quickly. The frigid temperature of the shop will help.
Oh, and when you get the bundle assembled you may want to make a wrap of blue tape or saran wrap around the bundle to keep the layers from skidding. as the clamp pressure is applied. If you use tape it must be removed very carefully, pulling perpendicular to the grain so as to not lift grain.
I was in a demo and the demo person wrapped with blue tape and vacuum clamped. Later in the demo..... They were nervous and hurrying when they disassembled the stack. They got to the tape, grabbed the end and before I could do more than gasp they yanked the end of the tape. A large piece of wood tore loose.
These photos are of laminating guitar sides. The lamination was made of an outer layer of rosewood and two inner layers of cedar. The pieces were pre-bent on a hot iron to approximate shape and were then laminated together. If your pieces are flexible enough there's no need to pre-bend.
Leave some extra length and width!!! The pieces might slide around during the glue-up and you will want sufficient width to trim away the bits that are no good.
Glue was applied to the pieces with a roller (you have to be fast) to get even glue distribution, then they are placed into the form.
Watch out - the pieces will want to warp once the glue hits them! Four hands are better than two. Some strips of tape over the lamination will hold the pieces in place while you wrangle the masonite layers and clamps into place.
Then about seven layers of masonite were placed over the inner laminate, and clamps applied. For the glue-up pictured I had to thin and pre-bend the masonite in order to achieve the tightest bends.
The inner layer of masonite was covered with packing tape to prevent the laminate sticking to the masonite. 3/4 x 3/x4" MDF strips were used as cauls, and these were pre-shaped to the curvature and glued to the outer layer of masonite at the clamping locations. I used U-bolts in locations where I couldn't fit the clamp heads.
I used Titebond original for this lamination, which is more difficult than the one you are doing, and I had enough time, but just barely enough time. If I was doing this glue-up again, I would use fish glue (long open time), or epoxy (available with very long open time, but difficult to clean up).
Leave the mess in clamps for 24 hours. I removed clamps from a similar, but smaller, lamination after 4 hours and the outer layers peeled away due to all the trapped moisture.
I imported the scan into Paint Shop Pro (too cheap to buy Photoshop), added the labels, then cropped, reduced and saved as a GIF. I've done this many times over the years for forum posts.
For bent laminations I've been using plastic resin glue because of its long open time. A drawback is that it needs to be 70 deg F or warmer for the entire curing time to harden. A plus is that the glue dries very rigid, allowing little or no springback.
Don't be afraid to make a dry run assembling the package and tightening the clamps.
Epoxy has plenty of open time, acts as a lubricant, doesn't need a lot of clamp pressure, and sets rigid enough to not creep. A simple bend like this could be done with only one clamp across both ends, and you could pull it off the form as soon as the vacuum is pulled if you wanted, because the pressure is perfectly even.
I'll be demonstrating this at the Arkansas Woodworking club sometime before long.
Here is a link to some more challenging work, using vacuum-bagging that I did about 20 years ago. That outside stringer was about 20' long x 2" thick, and 20" wide. I don't think I had but about 6 clamps holding it to the form, and they were set very light, so as not to induce a kink in the natural bend.
That was the easy part. Since this was an Elliptical curve, and I laid the walking path out so the rise run ratio stayed the same 18" in from the outside rail, the stringers and hand-rails had to have big dog-legs sawn into them to hit the target height to match that.
I did a few similar glue-ups but i used system something like this. The band that i used was a bandsaw blade, an old Makita resaw blade about 2 1/2" wide. and a hydraulic jack. The strips were about 1/10" thick, and i used plastic resin glue. That piece in the photo was done about 20 years ago. Almost no springback whatsoever. It is Cherry. The top half of the jig slides the bottom half had the batons bolted to it. You can clamp a few blocks on the sides as there wont be much pressure from the band on the straight sides.
The good thing about this setup is it is fairly quick and gives really good pressure around the curve.
