Performax 16-32 drum alignment
Jim in N. Va
I have an older Performax 16-32 drum sander (made before Jet purchased Performax). Haven't used it in years, but I wheeled it out because I'm making a run of cutting boards. I'm following the instructions in the manual to align the drum, but it is an exercise in frustration. Any hints...or helpful web sites out there...that explain how to make this task easier?
Also, need to adjust rollers to eliminate snipe so hints there are welcome too.
Thanks,
Jim
Re: Performax 16-32 drum alignment
mark valsi
When you find out how to eliminate snipe, let me know. I make the piece long, then cut off the snipe, but can't always do that . . .
Jim in N. Va
I'm only getting snipe on the leading edge (not the trailing edge), so I'm hopeful I can adjust the one roller. It would be hugely wasteful to have to cut off 2.5 inches of the cutting boards, since they are edge block. I'm keeping my fingers crossed.
I have one also. Are you talking about making the drum parallel to the table/feed belt so the piece is the same thickness on both sides?
The pressure rollers can be adjusted to help eliminate snipe, but I have not had much luck. My rollers are loose enough that I can lfit them with my fingers, so they apply very little down pressure. What I do is put the piece on the infeed side and press it down firmly as the leading edge goes under the roller and drum and then press it down firmly as it comes out. The last pass needs to be very light, removing nearly nothing. And I turn it around and around to average out what ever "tilt" there is in the drum. This may leave a slight hump in the center of the board, but if there is I have never noticed it.
the other thing I did that seemed to nearly eliminate snipe was to set up in feed and out feed rollers. Longer pieces tend to tip up as they go in and down as they come out, accentuating the snipe. The rollers really help. There really is some finesse in using the machine. sharp sandpaper and very light cuts are important.
I also find that it does better with slightly coarser sandpaper. Does well down to about a 100 grit, but 220 seems to dog it down pretty badly. I sand to maybe 150 and any more is done with a ROS.
Jim in N. Va
Yeah, I don't think my piece is tilting up into the drum. Rather, I'm guessing the whole drum is getting moved up as the wood passes underneath...resulting in a deeper cut at the start. If I can't fix the machine, I guess I'll just attach long "outriggers" to the piece so that the outriggers get the snipe.
As far as alignment goes, a hump in the middle would be a problem. I'd like to get the machine perfect.
Its been a long time since I tried to adjust mine, but as I recall there was essential no down pressure for the rollers and it took an inch or two for the drum to press the work down. By applying pressure and eliminating ANY tendency for the lead end or trailing end to tip up , it helped. On mine, if there is any difference in the roller being parallel to the bed, Its imperceptible. My understanding is that The roller is supposed to be a bit "high" at the open end so that when you sand a piece wider than the roller you get a slight hump in the middle rather than a sanding tract. Supposedly you can tune it to be parallel, but I have not tried. Getting accurate measurement is difficult because there is a certain amount of "fluff" in the drive belt and the sanding belt may not be perfectly tight and it tends to "fly" above the roller when the machine is on. Might be best to make the measurements without sand paper on the drum.
You might start by checking bed flatness
DizD
I recently replaced the bed on mine. Years of running cutting boards and other short pieces resulted in a concave bed under the sanding drum. Take the drive belt off and put a straight edge across, long enough to be supported by the rollers on the end. Apparently short pieces running under the drum will cause the bed to flex downward in the center and over time will cause a distorted bed.
Re: Tangential Cutting Board Question
Why is a slight convexity in the cutting board surface a problem? All the knives and cleavers I use on my cutting boards have a slightly to pronounced "belly" or "rocker" to the cutting edge, so that the knife needs to be rocked to contact the cutting board all the way across, anyhow. A minor additional rocker in the cutting board surface wouldn't even be noticed. End grain butcher blocks used by professional butchers always develop a concavity in the surface, and these work as well until the radius of the "dishing" exceeds the radius of the cutting edge, at which point they are reflattened, traditionally with a butcher block plane, (e.g., a Stanley #62), or turned over. A slight convexity would only help to delay the inevitable, and might also help to counteract the egregious effects of leaving the board flat on the counter with some water puddled underneath.
On the boards I have made for people that will actually use them I have often made them concave on purpose. I dish out the center of the board about a 1/4", leaving the four corners "proud". The juices and blood tend to run to the center and if any drools off the sides, it breaks the suction and makes it easier to left the board. I'm not a believer in blood grooves unless the board is huge, they tend to reduce the effective area of the board.
Tom
Not that it helps, but I used to have the routine specified by the original owner. There was a fairly specific set of steps one had to take that was not entirely intuitive. I had the original email until some computer or other died. Presumably I still have the files, but I switched to Yahoo, and never found a practical reader for the old stuff.
Anywho, even with the info from the top, I never bothered to try it. My method was to run some cheap 1/8" ply though the machine until it was flat across the worked surface, but overall a faint wedge. I saved this, and marked the feed direction. Then I just put the piece I wanted to plane on top of the ply, and the package came out dead nuts. One thing pro and con this method was that the thickness would vary depending on where you centered the workpiece (or the ply wedge, though in my case it was full width). It would be parallel, but finished size would vary minutely. This was not a problem with guitars since the piece barely fit as it was. On narrow pieces it could be used to make slight adjustments, to final thickness. So it didn't bother me, once I had it worked out.
I suppose the piece could kick off the plate, but it never showed any inclination to do that in my work. Just be aware that there could be combinations that would make this problem worse, so use sense when trying setups. There are a number of ways of dealing with the kcik issue if it ever came up. But unless there is interest I won't bother, they are pretty obvious anyway.
The total slope on my pieces was about .6mm which is very little. On easily planed woods it would simple to come up with a rote tapering routine to dust off that slight wedge of material
Pretend it's a building...
Paul Woolson
...and start from the foundation, working your way upward. Make sure your bed is flat and true. I've had three of these machines and every one of them had bed issues. The worst one would throw a conveyor belt into the side (ruining it) within about three rotations, regardless of how I adjusted the tension. I found that that one corner was lower than the others and after shimming it, things ran great.
After I got the beds flat and true I put two equal thickness pieces of metal under the drum, loosened it and tightened it again in the new position. That was pretty easy and straight forward.
I never could get rid of snipe. Found that running a sacrificial piece of wood before and after worked quite well. You have to be careful to have your workpiece right up against the sacrificial board or things will "hop" and you'll get snipe again. Same goes for the sacrificial piece behind it.
I REALLY wanted this to be a good machine, which is why I went through three of them. But the bottom line was that it didn't meet my needs and I had to step up (substantially) to a wide belt.
Re: Pretend it's a building...
Paul, How did you detect/measure that one corner was low? (Or whatever)
When you say that you gave up and had to step up substantially to a wide belt, how big a step was that? I have a friend who is a professional cabinet maker and he has one. I can't remember the brand, but its something like Timesaver or Daysaver or whatever. Its been in his shop a long time, but even thirty years ago he paid around $11,000 for it. I have a Performax 16/32 I bought used about ten years ago for $400. I think it was about $1,100 new back then. Any comparison is completely unfair. I don't have room for the bigger machine even if someone gave me one. Don't have three phase power. Don't have enough height in my shop. Its like comparing a Peterbuilt to a Ranger pickup. Is there something in between? For a hobbiest, I can get what I need done with my Performax, as slow as it is before I can load it in my truck and haul it to my friends, sand it and come back.
Paul Woolson
straight edge end to end and corner to corner. If one corner is low, it will present itself as a high spot in the center of the table. Lots of trial and error, check and recheck on my part to get the darn thing right.
I went with a grizzly open ended 16" belt. I was skeptical with the Grizzly name but when I got it it was within .003" right out of the box. It runs off of single phase 220 but needs a continuous supply of 90psi air to track the belt. I have to say, I'm 100% happy with this purchase, and that doesn't happen very often.
Sadly, there really isn't anything in between. General makes a 25" dual drum (which, yes, I purchased one and had to return it because one of the drum mounts was welded crooked and made it so the drums couldn't be parallel). Granted, I'm extremely picky because I working in the range of .030" to .080" and need precision of .005". So in my case I had to pull the trigger and get a professional grade machine. Mine cost right at $6000 plus another $750 for a big compressor, piping, etc. The actual foot print is about the same size as the performax and smaller than the general. It is taller, about 5'10" tall I'd guess. And you'll need a lot of friends to help you move it. Shipping weight was 1200 lbs.
Hope that helps. Still probably more machine that you might need. And you can rent a lot of time on a sander for the price of this. But I use it every day and it's probably my most important machine.
That's a clever solution
Jim in N. Va
The plywood trick would be easy with the small cutting board stock. I think I'll just temporarily hot glue sacrificial "out riggers" that are longer than the cutting board stock to deal with the snipe issue.
Tom
If I was doing this again, I would consider a wide belt, belt sander. Largely because the belt stays cooler. My only real problem with the performax is that it clogged on some of the tropicals. And it was a little hard to know when that would happen, and then one would be down a while. Doing the soundboards is something that could easily be done by hand on the guitars I was building but planing the tropicals was more of a crap shoot. Working that kind of wood was about the nearest guitar making came to gambling. You could have 2K in a set of side, on cost, and if they blow, it would hurt. For guitars there are a number of options to the sander that I am planing to go through first, I know the sander works, but would prefer not to go there.
Larry in NW Ohio
Barry It sounds like it`s a Timesaver. They arevery good machines, we had them at work for sanding doors and they were BIG sanders. Something like 6ft. wide and about 8ft. tall and could sand something like 4ft. wide material, can`t tell you how thickof material it could sand, maybe a foot or more. They were some beautiful sanders. Larry
I think you are right about the name. Timesaver. I was stunned when my friend bought it. Just could not imagine $12K for a SANDER. But it a heck of a machine. For a demonstration, he lightly sanded a sheet of plywood. Use spray adhesive to glue a sheet of news paper to it. Backed off the sander and sanded the ink off the paper, leaving the paper behind.
I am not in the slightest offended that my Performax won't keep up with it.
OTOH, I wanted to make some lamps that the light would shine through the wooden lamp shade. I resawed some birds eye maple to about 3/32". Lightly Sanded a piece of MDF in my Performax to use as a carrier. Used a small piece fo double stick tape to hole it in place and sanded the maple to about .02" Granted the pieces were only abut 4 by ten inches, but they worked nicely. In fact, the give away that the thickness was right was it would sand through at the tape.
