OT-Garage Door Openers
Tom
It appears that my Wayne Dalton opener is dead. This is the kind that turned the shaft and did not have a rail down the center of the garage. So I called a local garage door company and they use Lift Master. Now I need to consider belt or chain drive.
What say ye??
Re: OT-Garage Door Openers
Larry in NW Ohio
Belt drive, no doubt about it. Have 3 of them and love them. The only bad thing about them is if you have children that run around, you can`t hear them when they get home. You can`t hear the door opening. >( Larry
Nat Robison
I'll second that. Replaced a chain drive Craftsman with a belt drive Chamberlain. I often can't hear the garage door open when I'm on the other side of the garage wall. Doubt I would ever go back to a chain drive.
John McGaw
I have two new belt-drive Linear openers and am quite happy with them. Part of that might be the transition from some nasty noisy antique Craftsman chain-drive openers that sounded like the slow opening of a castle drawbridge but the Linears really are quite nice.
Art Lusczynski
I have the Lift Master that runs on the shaft and love it because is so quiet that I don’t hear it run unless I am in the garage. Does not wake my wife (happy wife happy life)
Charles Yawn
I just replaced my worm-drive opener with a Chamberlain Whisper Drive belt-driven opener. I was able to do it myself with the good instructions included. Like the other reply's , it is super quiet compared to the screamer I had before - sometimes we have to look to make sure the door actually closed. I like the wireless controller mounted outside, too. As a side note, if your garage door is old, inspect the side rollers and replace if necessary.
Charles
paul in AZ
I have a Chamberlain Lift Master and it is VERY quiet.
It seems that there are two models. The DIY variety from the borgs is claimed to be a dumbed down version with the "better" model being that from the professional installers. I can't swear to that though.
Larry in NW Ohio
Got mine from Amazon and had no trouble with either one. Larry
Tom
Art, Do you know which model # you have? I like the idea of the jack shaft mounted units.
Art Lusczynski
It is the 8500 it was a bit pricey but worth it.
Tom
Thanks!
Stuart Hough
Tom, was yours the I-Drive? I installed one of those on a house I had back about 10 years ago, then had to move for work 2 months later (wouldn't ya know). Spoke to the folks that bought the house when I went back through that town a couple of months ago and they said they have had zero problems with it. I really like the idea of having no obstructions in the gara...er...shop. Were you able to determine what the actual problem was?
Tom
Yep, I have 2 Wayne Dalton I Drives. The problem one will only beep and then do nothing. I have had the problem in the past and just redid the install procedure and I was good to go. This time nothing. I am going to call Wayne Dalton and try that before I go the replacement route.
I remember when I installed these, the local garage door guys had nothing good to say about them as they had lots of problems with them.
Thought about replacing it with Lift Masters version but I don't think I have enough jack shaft to make it work.
