jointer question
jointer question
jointer question
McKay
I have a Delta 8" DJ-20 jointer that I am not sure how to fix. I am getting a small belly in the jointed pieces. In a 40" piece, I will get a belly of about 1/32" in the middle. Before I begin to mess with the adjustment, do I need to drop the outfeed table or raise the outfeed to get this perfectly flat? If I ended up with a spring joint that would be ok, but a belly is unworkable. TIA
Re: jointer question
Dave Nichols
if I remember correctly you would need to raise the outfeed table
Yep, try raising it
Lee Schierer in McKean, PA
With your unit unplugged, remove the guard. Stand a steel straight edge on edge on the rear table. Leave an inch or so just past the center of your cutter head. Then by hand rotate your cutter head in the direction of the normal rotation. When a knife touches the steel straight edge it should move the straight edge just slightly (maybe 1/32-1/16") toward the in feed table. Raise your out feed table until you get just this slight movement.
Lee
Tom
This can be the operator also. A lot of people with a board that has convex curvature, will make it worse or preserve it. You need to work on the high spots first.
In theory, with a perfectly straight edge piece laying on the outfeed, with an end over the blade, with an unplugged machine. UNPLUGGED. Rotate the arbor by a safe means. The stick should move with the blade an inch or two. If the blade doesn't move at all, then the outfeed table needs to be move down till it does. If it moves a lot you need to raise the outfeed. The exact amounts will vary a little but if the board moves a lot or hardly at all, you are out of adjustment. Dull blades can aggravate maters.
Good advice so far. Once You get the table set for the center of the blade, Check both ends of the blade and both ends of the other blades. They should all be the same. A high knife or even a high end on a knife can ruin an otherwise good set up. DAMHIKT
One clue is the edge is scalloped. Its as if you have a one knife jointer. You have to reduce the feed rate to about a third to avoid or reduce the scalloped edge.
I don't agree with the cure
I have an 8" Delta jointer.
If the outfeed table is too low you will get a snip on the trailing edge of the board as it leaves the infeed table and drops to the level of the outfeed table. A convex edge will be the least of your worries. I set up a jointer by raising the outfeed table until I get no snipe. (the ruler technique is fine too) If the outfeed table is too high the board will jam into it and not feed. I find anywhere in between just fine.
Convex edges can be difficult to remove on the jointer, and easy to generate with improper positioning of hands and downward forces. As many miles of lumber as I have shoved through one occasionally an edge leaves me flummoxed. I take the piece to the table saw and saw the edge straight and start over on the jointer.
The traditional fix for a convex edge is to start the piece of lumber an inch or so onto the outfeed table. In this way nothing is removed from the leading edge of the piece where it is already thin. Continuing to feed, the jointer will remove material from the middle where it is fat, just what you need to do. In most case the following trip across the jointer will yield a straight edge.
More complicated stuff happens with drooping infeed or outfeed tables that I never understood. I just hoped that a quality jointer and tight jibs would never leave me needing to worry about it. Maybe someone that understand the mechanics of drooping tables can explain. I suppose something drooping might make a convex edge.
My bad.....
I misunderstood the problem. I read "belly" as a joint that was sprung with too much gap. If you meant a board that is convex rather than concave, I'm with Bill. The tables have to be co-planer to have any jointer work correctly. I would hate to have to even try to correct my 40+ year old jointer. (Glad it still works well) You may be able to check it with a really good straight edge but it would probably have to be three or four feet long.
I think the next thing to check is your technique. Bad hand placement and improper application of pressure can lead to strange results.
Setting the knives properly is still necessary.
"messing with it " is how you learn
Mark Hennebury
The fun and excitement of woodworking is in the discovery, asking people for the answers sucks all the fun out of it.
Mess around, try different things and enjoy your "ah ah" moments when you discover the answer on your own in the solitude of your own thoughts.
Why would you want to give those precious moments away. Learning is the fun part.
Re: "messing with it " is how you learn
David Yoho
I totally agree with you. That's usually my approach. But, I've also had those times when I just hit a brick wall and find it helpful to ask for insight about something I might have missed or didn't think of.
Sometimes a coach or teacher is necessary or at the very least very helpful. The voice of experience can cut through the chaos and point us in the right direction. Some of us are not "Mechanically Inclined" or perhaps as observant as we should be.
I like messing with it too, especially on something that is broken. (Motto: You can't break something that is already broken.) If the choice is throw it away or fix it, I will take a shot. OTOH, If the choice is fix it or buy an expense new one, I ask for help.
The Kreg jig I posted about recently is a good example. I ruined it. One suggestion was to use "slip paste or retaining compound" to fix it. I had no clue such stuff existed. Looks like it worked. Another suggestion was to activate the warranty and contact Kreg. I did and they sent me a new one at a very reasonable price. Asking Wood Central is like having many brains messing with it.
no.....
Getting to put your socks in the finished chest of drawers is half the fun.
Most of the frustrations are the unanticipated obstacles that pop up between start and finish. But then one person's frustration is another's opportunity.
Ikea
My Understanding . .
The tables must be co-planer across their width and length before anything else is done.
1. UNPLUG IT
2. Raise the infeed all the way.
3. Rotate the cutter head so that a knife is below the table's surface.
4. Put a long straight edge across both tables and move across the width, front-to-back. The straight edge should maintain even contact with both tables along its entire length. If it doesn't, you have a table gib issue. Your owner's manual will tell you how to adjust the gibs to get your tables dead-nuts on the same plane.
5. With the tables flat and even, drop the infeed a little and stand a good 12" steel rule on edge on the outfeed table with an inch marker on the edge of the opening. Gently rotate the cutter head clockwise so that the knife contacts and moves the rule. Note how far the rule moves as it should be no more than 1/32. Do this at both ends of each knife. If the knives do not move the rule the exact same amount each time (or don't move it or move it too far), you need to adjust your knives in the cutter head using the knife-jacking screws.
6. When you've done all that, just for laughs check and adjust your fence to make a precise 90°.
A well-tuned jointer is a joy to use. A cockeyed machine is just scrap metal taking up space.
How do you define belly?
Keith Newton
I'm not sure whether the question is in, concave, or out, convex.
motivation
You might find it interesting that most of the good woodworkers in my area got into woodworking because they could not afford the kind of furniture they wanted to live with. I do not know how common this motivation is among us.
So many things to build, so little time to learn the skills and build them. I take any help I can find. I don't buy anything I can make if I have the time and skill to make it.
Knowing no better while visiting Orlando I went to an Ikea store to see if they had anything I might want to make. I thought I might see Scandinavian furniture there. It was my first and last visit.
Jesse Cloud
A favorite teacher of mine told me once, "You can and should learn from your mistakes, but don't depend on that for your whole education."
Re: My Understanding . .
William Duffield
but, a DJ20 doesn't have gibs.
Well Then
I guess it won't be going to the disco! ;)
Re: Well Then
William Duffield
It's a parallelogram bed as opposed to a wedge bed.
For the curious, this parts diagram might be explanatory.
http://www.ereplacementparts.com/images/delta/37-350A.pdf
I don't think there's any adjustment in the parallelism of the infeed and outfeed beds (other than replacing worn bushings), but I've never heard of one getting out of adjustment.
So
I pulls up the manual and it says to set the outfeed and knives at "exactly" the same height (forget the 1/32 "hop-skip" method). Still have to check the knives at each end and adjust them with the jacking screws.
Re: So
William Duffield
That's how I've always set mine. Usually I use a 4" steel double square (because it's in my pocket), but any straight steel rule will do. I set the square on the outfeed table, and with the jack screws move the knives up and down until the knife edge just scrapes the rule, but not high enough that I can see the rule move or see any light between it and the outfeed table. Sometimes tightening the jack screw nuts moves them a little, so I usually have to fiddle with them until they are right.
I lock the outfeed table down tight and never adjust the height. The master whose shop I worked in used to have a wedge bed jointer, and he could get it to produce a spring joint by finessing the outfeed and infeed table heights, but I could never consistently get the hang of it. I find it just as easy to joint the edges straight on the power jointer and then take them back to my bench and match joint them to put the spring joint in with my #7. The same "in" and "out" marks that I use to insure complimentary (if not square) angles when registered against the jointer fence, also tell me which are the top faces that need to be clamped against each other when I match plane them.
BTW, I always use spring joints when building glued up panels. It only makes sense.
Re: I don't agree with the cure
Robin Corell in Atascadero,CA
If you read the manufacturers set up instructions for most machines they will have you setting the knives a few thousandths above the outfeed table. the reason is to prevent the exact problem to OP describes.
Robin
billv in MI
The DJ from delta all are based on almost equal length parallel controls arms in a unique parallelogram design. In theory the parallelogram design allow the tables to move vertically and stay flat. However you will notice that the gap between the cutter head and table varies as you raise and lower the table. The ideal is that manufacturing tolerances are tight, but slight machining variations occur so some level of field adjustability is required to ensure the tables operate as an equal length parallelogram.
Two rigid control arms support the in-feed and two control arm support the out-feed table. Your cutter depth height adjustment arms are attached to the outmost control arms. Those rigid arms pivot on shafts which are about 8” long. There are eight eccentric bushings (4 for in-feed, 4 for out-feed). As you rotate those eccentric bushing slightly changes the effective length of the parallel control arms.
Contact Delta and they can fax you instructions on the adjustment of the eccentric bushings. My experience is your problem might be far end of out-feed table being low has caused this as well as the end of the in-feed being slight too high.
Make sure tables are flat. Get a very high quality/precision 36”-48” steel rule (Starrett or Lee Valley). I believe it should be out of flat 0.005”-0.008” at the max.
How to adjust: Don’t use the knife edge as the reference; use mass of the cutter body. Knifes heights are adjustable and can nick you or the steel rule. Start with the out-feed side. Lower the table until the cutter body contacts the steel rule. All parallelogram measurements should be within 0.010” of a feeler gauge. Measure the straightness at the inside and outside edge and then measure a crisscross (X) pattern. Measure in the middle with the feeler gauge and use 0.010” as the guide. What important really is they are the SAME not that one is 0.002 and the others are 0.010. Just use the same gauge and adjust to they all match. Yep the crisscross measurement is very important. My problem was not the factory but my tendency to lift or move my DJ-20 around the shop. One of the hex screws was loose holding the eccentric bushings. Did the two board comparisons and notice a well-defined gap.
If you need/want to adjust loosen the 4 Allen headed screws which are vertically orientated about one inch above the eccentric bushings. Experience says loosen them all up at once, nothing should move on its own. The eccentric bushings require a spanner wrench or a punch that fits nicely into the holes. Rotating one of the eccentric bushings will cause the table to move slightly. Do the inside/outside/crisscross test again and again and my experience is the crisscross measurement is more amplified by the adjustment. I remember locking the tables down between measurements because that places some strain/preload on the system as it normally would operate. Once you can do the whole test sequence and stay within the 0.010 the table should operate in a true parallelogram fashion. Do the same for the in-feed table side. Then I double checked the in-feed and out-feed together by moving them up to the top of their travel and adjusted the big STOP screws and nuts.
Once the tables are staying horizontally flat with vertical adjustment then set the out-feed to as you normally would to the top edge of your knives. Now is the time to make sure they are adjusted flat to the out-feed table and best you can to the height. Be sure to check inside and out knife locations if you move the eccentric bushing because it will shift the table.
Tom
When I bought my jointer the Deltas were just out. I went all over the place with a precision 36 and examined all the tables, they were all over the place, including the Deltas. Never buy a jointer without inspecting the specific model.
