Re: How secure are these things ...
craigd
Cloud security is a huge question and should be spelled out big time by the provider. In the case of LastPass, they do all encryption (AES-256 + SHA-2) on the local machine so no info "in the clear" leaves your machine. You remember a master password or use two factor authentication (ie a usb device, cell phone, etc) to gain access to LastPass. When I last worked in security, we also worried about clear text remaining in memory where it could get hoovered (which is actually a worry, even if the machine gets shut down). Of course, if you have a key logging trojan, are sitting next to somebody recording your key presses or somebody really wants your info, you are probably hosed (unless using two factor but that only helps connection access, not other things, eg the Target breach). It's pretty much like the locks on your house; break those and it is free access.
