THE WOODRAT IS BACK!
Shower head (OT)
Shower head (OT)
Shower head  (OT)
Larry in NW Ohio
Our shower seems to be slowing down some, I assume it`s begining to plug up with the minerals in the water. What`s the best way to get it clean short of taking it apart. I heard of stuff that you just soak it in to clean it, but forget what it is. The head has some kind of rubber product so it can not be something that will hurt that. Any ideas? Thank you. Larry
Re: Shower head (OT)
Nat Robison
You can soak the head in vinegar or some of that CLR liquid cleaner you can get most anywhere. Try google for other options.
Joe Bradshaw
Joe Bradshaw
Kaboom also works well for this. It can be found at WalMart.
Bill Turpin in WNC mountains
All these cleaners are acid based. They dissolve calcium chloride or lime deposits. They work well if that is your problem. They will not touch granite or sandstone chips. Have fun
Don Goodwin
I don't know where I read this, but take a small ziplock bag and put it over your showerhead (no need to remove the head) and hold it in place with a rubber band. Pour in some white vinegar to cover the showerhead and let it sit overnight. That really improved the flow for us.
