Samantha's dresser Part 2 Design and "plans"
This discussion should have been part 1...but I am disorganized.
Part 2 Design
The dresser is a ¾ sized affair “designed” to be approximately 48” high and 28” wide and about 17” deep. . None of these dimensions are critical at this point. In fact, the lumber for the sides worked out better to make it 18” deep and just a bit taller to capture some nice grain at the bottom and enable the edge joints to mate more attractive while keeping the pattern centered. The bottom line of it is to not be wedded to some exact size from a plan.
When I examined antiques I saw that dovetailed drawer runners did not pull away from the case sides over time, while mortise and tenon usually did. The dresser will incorporate a false top dovetailed into the sides. Its function is to provide “kickers” for the top drawers, hold the case sides together and flat, and provide a place to screw through to hold the top on. The drawer dividers will be dovetailed into the case sides. Often the back dividers were mortised and tenoned to save labor over dovetailing. However, I find the dovetails so easy to do I do them everywhere.
It would be best to install a solid bottom dovetailed into the case sides with sliding dovetails to help constrain the sides to remain flat. This feature is especially important if the orientation of the grain in the sides could cause them to seasonally cup inward, which would bind tight fitting drawers (had that happen once and it was difficult to hand plane the inside of the assembled case back flat.). Its main function is to keep the sides from cupping inward and narrowing the drawer opening. It does not have to be a precision fit to accomplish this task. I am not going to bother with this feature on this piece.
I do not use dust panels. I regard them useless and they add weight.
I am not fond of the feet I have sketched. Maybe inspiration will follow later.
