Lets here it for the Kreg Company....
Recently I posted about the fact that I ruined my old all metal Kreg jig. I have had it fifteen years or more and it only gets sporadic use. I dogged it by having the drill in a bind against a frame member in whatever I was drilling and the sleeve overheated and came loose. I posted here and got what looked like two things I could use. One contact Kreg as it has a 100% lifetime warranty and Two try Locktite Retaining or Slip paste.
I tracked own the retaining paste and the local Fastenal store got it for me. It appears to be greenish slime. I cleaned the mating surfaces thoroughly, and glued it. Seems to have worked, only time will tell. Wonder what I can do with the remainder of the slime to keep it fresh for a few years until I need it again?
I called Kreg and they said they can not repair the aluminum jig, but they would sell me a new one for cost. Offered me the K-4 for $25 and the K-5 for $30. I was Little put off by this interpretation of the 100% guarantee but went ahead and bought the K-5. Then I was wondering if they were sending me the whole kit or just the jig. The kit retails for $139 so I was assuming I would get the jig only. Nope. They sent the whole thing. I have not had a chance to use it yet, but it appears quite a bit more sophisticated and elaborate that the original. All in all, I am pretty happy with Kreg.
Re: Lets here it for the Kreg Company....
Larry in NW Ohio
Barry I`m glad things worked out for you. I have found out the if you have trouble with a product, first off keep some of the paper work that comes with it and put it in a fileing cabinet with the receit and addresses. Then when you have trouble with something that you can contact them, and most of the time they are very good to deal with, especiall American Co. Larry
I am not upset with Kreg at all. It had not occurred to me to contact them until someone here suggested. After all, it was fifteen years old and I was abusing it if only slightly. After I thought about it, I was not surprised they sent the whole kit. In truth, I doubt they have "parts" of kits. I suspect they are manufactured somewhere else and probably even shipped for a fulfillment center.
The Loctite stuff is pretty weird. It sets up in the absence of oxygen. Wonder why it does not set up in the bottle. (Maybe it will, time will tell)
Not made elsewhere
Tim Greif - West of Chicago
Read the FAQs on their website. Although some parts are sourced overseas, most are from within the USA. And all jigs are assembled and packaged in Huxley, IA.
RobCarr
I have a tube of blue Locktite that has be 35 years old. Its larger than the tubes you see stores it's about the size of a tooth paste tube - I think it may have been made for industrial users. I don't know if it develops the same strength (bond) as it did when new, but I figure as long as its liquid it's good enough - plus its not like I'm using it to build spacecraft here!
Re: Not made elsewhere
I did not necessarily mean China or even far far away. I was thinking that it might be difficult for some body to pull out one part and ship just that. I was thinking that even if they were assembled down the street it might be difficult to pluck out the central unit, it being fully assembled, and ship that without having the balance of the "system" left over. And if they sent the request to the parts department, they might not see the central unit as a "part".
I would not have been surprised either way. Glad to know they are still making stuff in America.
I looked up the data sheet on the product and have already forgotten the numbers. They were in Degrees C and I had to translate them to F. Something like 46* F to 68*F. I was thinking about my freezer or even the fridge, so I'm glad I looked. Basically a cool place. I will put in a cabinet and hope for the best. I may never need it again, but I have the pack rat gene and it would bother me to throw it away, specially after paying $19 bucks for it and using a very small percentage of what I got.
And I to have ancient tube of Loctite. Interesting stuff, sets up in the lack of oxygen and yet does not kick off in the tube.
Tom
Good for them. And quite the value added, if you know what I mean.
wjb
The bottle allows oxygen to pass in. The larger molecule of the liquid cannot leak out. Keep the bottle clean. If it gets dirty enough to seal, the stuff sets up.
