shop cut-offs are valuable
They are valuable for more than kindling. For example-
Long relatively thick cut offs can be collected in a waste basket and saved to protect the outside edges of boards during panel gluing. (they go between the clamp jaw faces and the panel)
The thn cut-offs can be saved to be used as shims to fix screw ups, for example loose tenons or dovetails.
End cut-offs can be used to aid set up for edge treatment, for example routing a profile. Additionally, they can be broken to test the glue joint. Feed back of how well the joint was made, as evidenced by how much wood failure occurred when the joint was broken, is useful in developing panel gluing skills.
Can you think of other uses?
Most that I'd saved came from that shop. One of the guys there saved all the chunky mesquite scraps with no epoxy for making carne asada
