My wife would like to get a lamp, and when we were shopping I thought maybe I could make one if I could find one design she would like. Is there some where I could go that would have pictures of a lot of lamps? How would I google some thing like that? Thank you Larry
maybe start by narrowing down the field. i.e. craftsman style lamps. or go to a specific retailer's web site like Restoration Hardware, Crate and Barrel etc. The trick is to get your first search criteria selective enough to produce manageable results.
I made lamps for Christmas presents last year. I searched Google using the image search option. That brings up lots of ideas. There are several good lamp part retailers online too. I got most of my parts from this place:
First thing is to understand how lamps go together (there is a system). Once you start looking at the parts, it makes sense. Pay atention to the thread sizes too.
Thought I had some pics of my lamps on my work pc, but I can't find them. Actually, I'm working on finishing the prototype I made for the mahogany lamps right now. It was glued up poplar, so I'm going to paint it. Lowes and Home Depot have some parts and pieces too. Might be enough depending on what you are going to do.
I suppose you are wanting some portion to be wood, but my crystal doesn't have a link to your wife's taste. Maybe if you posted a pic of where she would like to use it would get you some good creative suggestions. Desk, table, or pole, maybe wall sconce light, pick one.
Otherwise, if I were planning to do a wooden lamp, I would certainly be planning to use LED for the source. Because of the low heat output, this allows for a lot of design freedom not possible in earlier periods.
So, I would start looking at what is available in LED, then looking at whatever period of art or design that you like most, then trying to combine the two. You might even check around to see about taking a stained glass course.
I built these out of scraps of teak and mahogany since they will hang outside. I was just fooling around and this is what came out. They connect to landscape lighting. I had to build a "box" (bridge, caps, buck converter or rgulator, etc.) to convert the ac source to dc, then drop it down to 3 or 5v. I used a cheap flicker candle circuit via a transistor to drive my led's (there are two - a warm white and an orange to get the effect). It works real well and looks neat at night. I made a mold for the "flame" and cast it in resing with the led's embedded in it.
Testing the light...the cord actually goes up through the center of the finial.
I really like my baseball cap with three LED lights in the edge of the bill but I just can't seen to warm up to their use as accent lighting indoors. I would still like to pay around with some EL sheet and think it could lead to some interesting designs.
Yea Robin, that could be interesting to play around with too. However, I wonder if it would be bright enough to light up a room, or even sit by, and read a book. It could certainly backlight some glass. That is probably what is behind this computer screen.
Have you not had any dealings with LED besides your cap? There are plenty of brighter options than that.
The power company here in LR, just spent 2 million to light 3 of the bridges crossing the river, to celebrate their first 100 years of service. I'm pretty sure it was all LED. I wish I had some of that kind of lights to play with.
Robin You lost me with the "baseball cap" statement in your post. Do you happen to have a picture you could post. Also Del, you gave me a lot to look at.Thank You everyone, but everyone keep posting if you think of something else. Larry
You didn't say whether the lamp will be for reading, or atmosphere, whether it will be a table lamp or a floor lamp or a hanging lamp. So, figure on function first. It it is to be a table lamp for reading, it will have to support a bright enough bulb to give you the requisite number of lumens on the book pages for comfortable reading.
Also, beware of designing for LED lamps if it will be possible to use regular incandescents in the same socket. At one point in my career, I used to make a line of lamps. Though I didn't go to the expense of getting them UL Listed, I did follow the UL standards for lamp design, which are quite extensive and written like building code. One of the things you really need to be aware of is ventilation, and UL specifies a certain number of square inches of cross-sectional ventilation space per watt of power consumed, as well as very specific minimum distances from bulb to combustible materials and maximum wattages. It also specifies the kind of wiring and plugs, minimum wire gauges, and of course the infamous "UL knot," which must be tied in the bottom of lamp sockets to prevent the wire from being pulled back out through the nipple and causing a short circuit.
I haven't looked at the standards in years (my hard copies burned up in my shop fire in '99), but I'll bet you can find them on the internet. Don't take chances.
Thanks Ellis, of course I never thought of that. I`m thinking of a table lamp and then maybe a floor lamp for a LED bulb, if I can find something my wife likes that I can build. Thanks to everyone for all the advice. Larry
If you build floor lamps, you'll want to find a source for "loaders," cast iron, plate-shaped weights that you mount in the underside of the lamp base. I used to get them wholesale from a company called Kirk's Lane. I don't know if they sell onesie-twosies. You might have to experiment with different size loaders, depending on how top-heavy your lamp standard is.
If you have any old brake rotors laying around, those might work too! The ROugh Cut show did a floor lamp. Might not be your taste, nut there might be some techniques/tips. Also, I believe I have seen some articles on floor lamps over the years.
I fianally remembered that I`m stuck with doing something that can be done without a lathe, because I do not have one. I know that really limits my design somewhat. I have gotting good suggestions so far. I hope more keep coming. Thanks Larry
@ Tony in Memphis, do you have a schematic of the circuit you built to make the LED lamps flicker and can you share it?
I have dozens of brick xformers in a box and can pick any of them to provide the power and regulate it down to the voltage I need, but the flickering circuit is not one I have ever designed.
That helps a lot, because it saves me the time of finding and processing pics and writing up a description of lamps I have built, if it turns out that no one cares. Both were not applicable to your application, being outdoor lamps in an Oriental style, one a garden lantern in teak and slate, and the other a hanging patio lamp in teak and stained glass.
Sorry, I don't have any schematics or anything. It is very basic. I found a flickering tea light with a flicker pattern I liked (compare them - some aren't realistic at all - GE seems to be a nice one - ~$2). I use that as the input signal to a transistor (might need a PNP vs an NPN) and the transitor controls the LED's. There are some similar projects out on Make and Instructables, etc. The parts are only a few dollars. I spent the most on a Buck converter just because I wanted to try one and it is easier and neater to wire up. I used a 5v regulator on the first one - works fine but gets a little warm and requires caps to make a pretty signal. Both of these have been working through a couple of seasons - so far so good.
You have to figure out which side ot the LED the candle circuit controls (look at which leg of the LED is connected directly to the battery) That determines whether you need an NPN or PNP transistor (mine required a PNP). I feed the candle light whatever voltage it requires (usually 3.2V for mine - coin cell 2032). Might be necessary to measure the current draw of the circuit and add a resistor depending on your source. I then determine the resistors required for my LED(s) again based on my source and the LED data. The way I look at this is that the transistor becomes a switch on one leg of my LED's controlled by the tea candle circuit that feeds into the base of the transistor.
I used my last set of rotors as counter weights for an easel I built my wife. The weight of 2 350Z front rotors was almost a perfect match for the easel frame weight. I packaged them up in a cherry box to match the rest of the easel. Don't think the wife would be inspired by a couple of dirty rotors hanging on a string! I've use pipe flanges in the bases of small vases and other stuff.
Sometimes off and on, I will spend a lot of time in my canoe. Sometimes I take off in mid afternoon thinking I'll be back shortly, but get lost in Keith's world, and may be an hour or two after dark getting back.
A few times I have met up with archery fishermen out in their big boats, which seem to be lighted with "Ball stadium lights", powered by a big generator in the boat running wide open, killing any semblance of peace and tranquility. Several times, I didn't even have a light, so had to grope my way along following the opening between the treetops against the sky. After passing these guys, hell, I couldn't even see that.
A couple of days ago, I was out at Bass Pro, and there was one of those boats out on the edge of the sidewalk. This one was lighted with about 8 fixtures with LEDs about 1" square. I just did a search, and found one which used 50 watts and is rated at 4500 lumens, so x8 would be 36,000 lumens.
While I like having a good head-lamp when I'm out stalking the night with my camera, I don't think I will ever need that much light. Secretly I hope they attract clouds of dog-pecker gnats, then have engine problems so they can't out run them. It is the little things that can get you. DAHIKT
