Pantry project done
Pantry project done
Pantry project done
Mike Foster
Quite a while back I asked folks here about some construction dilemmas I had for a set of pantry shelving I was designing. I got a lot of useful suggestions and used a couple of them. This pantry highlights wood from a couple sugar maple trees that went down in our woods about 5 or 6 years ago. I hauled the trees out had a friend mill the wood, which then was stacked and left to air dry in my fields for several years. Cool thing is that these were trees I had tapped for maple sugar and some of the wood has those tap holes and the resulting streaking caused by bacterial invasion similar to ambrosia maple. It is a prized wood here in VT and is dubbed tap-wood.
The dilemma in design came from a couple of features my wife wanted. She did not want any side supports and wanted the shelving to be as open as possible. Supporting that weight was the issue. My solution, with help from the great folks here, is that the wood for The shelving is a full 4/4 surfaced rock maple, each shelf is supported by cleats and screwed into the cleats and I added some support from the beams on the front end of the units. The L shaped unit was a bit of a dilemma regarding wood movement. Someone here suggested breadboard joints, but I decided to go a step further and used sliding dovetail joints. This allowed an open shelf in the corner, which is really nice. The cabinet near the post and the shelf unit above it are designed to be removed if we ever get too old to go downstairs and do the laundry. We could easily install a washer/dryer combo here if needed. The cabinet just to the right has a large pull out bin that will store our dog food.
All doors are mortise and tenon pinned with ebony. There is a mistake highlighted by the ebony pins that you might be able to pick out if you look.
So this was my Xmas present to my wife and an 11 year project finally made good. Thanks to all here who gave me some great ideas.
Re: Pantry project done
I sure like it.
Keith Newton
I like all the other stuff that the pics reveal too. If all or most of those books, are cook=books, I hope you realize that you are a lucky man.
Everything seems to really work well together, maximizing the storage area for that space, in a charming way. I like that you used that wood, and that each of those streaks has a story to tell. Congrats.
Beautiful - no, stunning! - work
Nicely Done Mike!
Larry in NW Ohio
Mike An absolutly beautiful job. But One question, in the third pic on the left side you have what looks like a 3x4 going diagonal at a 45 in front of a window, what is that? Thanks for posting. Larry
Mike Foster
Larry, this part of the house is a post and beam addition that we added to the house 11 years ago. That post in the corner is the one that needed to be replaced due to water damage (happened faster than I would have thought but we fixed the source of the water so it should be good now). The diagonal is a brace for the structure. If you look at the shelving, there is one going up at a 45 there as well. It really made fitting the shelving a pain as I had to hold them up to mark the shelves and remove 2" everywhere the brace ran. My wife insisted on the window for light in the pantry, despite the brace running in front of it. It really does help to bring light in during daylight.
Thanks everyone, glad it's done
