I think you're point-on, Keith. The point of woodworking, as I see it, is to enjoy doing it. To that end, I have more recently decided to build more and sand less, sanding being my least favorite part.
I figure I'm not making heirlooms here .. no one to leave them to, really .. so I have fun doing the designs and the woodworking and sand only to about 150 and polish the finish only to about 00 when, indeed, it needs to be polished at all.
I'd love to find someone who likes to sand and finish, give my stuff to them and say, "Here."
I actually plan on doing MORE sanding (and finishing) in 2014 than 2013 (no Yonak - don't send me stuff) as that translates as more time and making more stuff in the shop.
In fact, think I'll close down thisyeer box and go make something!
Seeing you'd asked for superstitions to assure good luck through the year, I though I'd include a reference to the Yom Kippur custom of waving a chicken over one's head to symbolize transferring one's own sins to the chicken.
By way of explanation, my father came from a pretty secular family; my mother from a little more than four centuries of Rabbis. I've never actually seen this ceremony done.
Perhaps another little known custom or superstition, but perhaps a little more related to woodworking, as it involves a tree.
My vague understanding of a Shrieking Tree (from one of the Eastern Cultures) is that you have a tree that you go to and in privacy, shriek at it and curse it with all your troubles. The tree assumes your burdens which is honorable for the tree. Might be some pretty gnarly wood if you were to harvest it for lumber later.
Happy New year to all.
I resolve to actually make some of the stuff I have been thinking about for years.
Well, I didn't eat collards or black-eyed peas with pork fat. I spent a good portion of the day cleaning shop, and several other things listed as bad. I didn't get up in the middle of the night to kiss Sassafras when she was barking at all the gunfire out on the streets.
This morning, I tried to open my big gate, 10' x 16' White Oak on treated pine frame, several hundred pounds. Someone must have run a car into it last night, which broke one of the wheels off the bottom. It is colder than a well diggers butt out there. One
Two, I tried an experiment last night to see if I could thin the epoxy that I keep on hand, down to use like the penetrating epoxy I used recently, which is twice as expensive, and mostly thinner. I don't think it is ever going to kick. I started out the back door with a box of saw-dust and 3 cups of thinned epoxy. I dropped one, which totally soaked one of my shoes. If it doesn't dry, it will be sticky. If it does, it will probably be brittle.
I sure hope there is just one more thing, so I can chalk this up to bad things come in threes. But a google search indicates these omen, are all year long. You guys are going to get tired of hearing me whine, if it does last.
As I have heard it, back in the days of hand-dug wells, the well-digger - the one down in the hole - would be standing in a hole at ambient soil temperature of maybe 50 degrees, with water up to his keister sucking out body warmth, trying to finish digging the well with a short-handled shovel before he lost all feeling in his fingers. Not OSHA-approved working conditions, in other words.
I've tended to make a distinction between "well-digger's butt" and "well-digger's toes," with the latter being colder. But this is relative. I just finished a book in which the author refers to 20 degree (Fahrenheit) temperatures as being bone-chilling cold. Out here on the North Coast, we don't get the kinds of winter temperatures that those of y'all who live in the Midwest and upper Atlantic Seaboard find normal; but even so, I wouldn't consider 20 degrees "bone-chilling." Brisk, yes; but bone-chilling here doesn't start until we're down in the teens (my bride, by the way, would disagree with me; she sets her thermostat somewhat higher).
Thanks, that an interesting explanation, Bill. While we are now used to thinking about historical woodworking by hand, we sometimes forget that in the good old days, everything was done manually, uncomfortably, dirty, and usually downright dangerously.
If I wanted to describe the old Florida Cracker I learned the expression from, "polite" is not a word I would find pertinent. To be a little more polite, I think his favorite expression would have been synonymous to "Chiroptera guano."
We have a hand-dug well on our property - no longer in use, although it fills with water every winter - 45 feet deep, three feet across, brick-lined. I've tried to imagine several times being 45 feet down, digging with a shovel, hoping that the brickwork I placed above me was done right. I've seen the description for how you line a well hole as you go down, laying bricks around in what amounts to a circular arch (that is, strong in compression all the way around the circle), and then laying courses of brick under the courses you already installed, but the engineering is too complex for me to retain.
It is astonishing how much they did, back when "power" meant you or a horse.
