One sure way to get your heart going.....
roger lance
is to be working quietly and highly concentrating on cutting close to the line when your bandsaw blade breaks.....BOOM.....boy, that is real fun.....my heart is still going fast.
Re: One sure way to get your heart going.....
My shop teacher in High School.....
wore a long sleeve white shirt and a tie. If he was going to actually work, he would roll up the sleeves and tucked the tie inside. He had student that argued that it appeared impossible to cut curves on the bandsaw because the kerf was very skinny and the blade was half inch wide. Therefore any curving would be impossible. The Teacher took him to the saw and gave him a piece of pine shelving board. Told him to cut into the board and then told him to curve to the right. Instead of gently turning to the right, the student instantly rotated the piece of wood ninety degrees. The blade snapped. Came out of the saw and went between the teacher's arm and his body. It was a huge bandsaw with about 30" wheels. Long blade. It snagged his shirt on both his arm and his body. I don't think he got scratch, but I doubt he was ever able to use the underwear again.
He sent us to study hall for the rest of that shop period.
One saw I used to use...
John in NM
Did something about like that every time. The end of the broken blade would hit the bottom of the saw frame and a whole mess of blade would pile out on the right side of the guides. That darn saw broke blades all the time too, usually before the blade was all that dull.
Adam of Oakland
Adam of Oakland
yes! and i must say from my experience it's good to just take a breather after that kind of mishap. for me it's my lunchbox planer blowing a fuse because of dull blades that I knew better to try to run this old doug fir thru.
as we age our hearts can be prone to arrhythmia and so let us be careful, okay?
turn it all off for a few, go upstairs and give your wife, husband, dog, neighbor a hug and take a break.
jeeze i sound corny :-)
Adam of Oakland, CA
Do you recall where he was standing?
Keith Newton
I'll bet he was standing to the right side, in line with the wheels. Every blade that I've had break, ended up out there, so I never let anyone stand there while the saw is running.
My uncle Gordon set up and taught a shop class. One year, he had one kid who was a cut-up, clowning in his class while his back was turned working with another kid. The kid was near the bandsaw waving his arms around. My uncle turned around and caught him, then scolded him for being careless. When my uncle turned back to the other kid, the brat did it again, and this time, cut his hand totally off. They ended up closing down that program, and got rid of the shop because of that reckless kid's action.
As far as the blade breaking, usually I hear a clicking as a crack passes the guides, so I try to shut down first. Otherwise, the actual danger probably isn't that high. Well, not much more than letting the coils get away from you while unfolding one. It could take out an eye, but more likely to just scratch you up a bit.
Re: Corny
Tom
No you are right. In particular when you think you should stop, resist at all costs the tendency to ignore a warning sign and "finish this last cut". I have seen some pretty weird warnings, and ignored some, and not others. The ones I ignored landed me in the hospital, one time for 3 months.
It is the same with "military intelligence". While admittedly they probably ignore stuff every hour that it would not be practical to change all plans in light of, it is interesting how often major disasters resulted from ignoring intelligence that predicted the event. Today there is so much "noise" one can't take these failures too seriously, but even when reports came in perfect written essays well spaced in time, people often ignored them no mater who signed them.
Re: Do you recall where he was standing?
You are correct. He was standing to the students right and the blade went under his right arm. He was ex-military and ran the shop like a drill sergeant. Very focused. I don't think I have ever seen anyone quite so flustered. He was desperately trying to remain calm, cool and collected, Trying to ignore his arm and shirt, and hoping no one would notice his desperate search for a wound. Most fortunately he was not wounded.
The principal at the same school had been a shop teacher in the distant past. The story abut him was he was demonstrating why you never joint a piece of wood less than a foot long when the jointer took the tip of his pinky. I was not there of course, but I am willing to bet no one in that class has ever jointed a piece of wood less than a foot long.
Jason Roehl in Lafayette, IN
My shop teacher...
...was pretty hard-nosed, too. He made no bones about the fact that he played favorites--only those who showed interest AND competence could use the more "dangerous" tools.
He definitely didn't let us stand in line with the bandsaw wheels--said he had one bread and come out, roll across the floor and start to run up the wall.
I don't know if that was true or not, and I didn't help his case, because it didn't take me too long to break one. It just snapped and the end above the wood just stuck out at a funny angle--no piling up or coming out.
Jason
