Re: Guitar makers...
Tom
Often used horrid stuff like epoxy of super glue to build the base. In fact, one can pretty much FP super glue, the technique isn't exactly the same, but it is similar.
The problem with globing on a lot of spray or other stuff is that the material is not the same, and the layers aren't there. If one big fat layer was better, it would save a lot of time at the Ferrari factory, Shellac is not the stuff in the bottle, it is the dried on form on the product, so to speak. The thinner stuff is a different deposition than the thicker stuff, it would not look the same under electron microscope. Actuall, if I had had to guess, I would have thought the thicker would be better with fewer blow holes from escaping gases. Anywho...
Another method to quick build FP is to use a random orbital sander. This was explained in an FWW article. I haven't tried it. But basically you buit a fad for the ROS, and powered the stuff on. I didn't try it, because on the stuff I do, the corners are the trick, not the flats.
Whatever you do, don't be like the guitar couple who are rightly well known, and known for their FP work, and then it came out it was mostly 5 min or Cyano. They weren't doing anything bad in their minds, I am sure, sythetic bases are common on many guitar finishes, but heck, if we knew it was mostly epoxy, we wouldn't have been in awe. If you are taking shortcuts (though some as Bill points out are standard), don't pretend you are polishing.
