You may recall that I overheated my kreg jig with a drill bit that has a slight gaul on it. I posted about it here asking for suggestions. Lee suggested Loctite 6300 and I have sent him an E-mail asking for more info. Several suggested contacting Kreg.
I sent an e-mail to Kreg and they responded. From Them "I'm sorry to hear that this piece has pulled out. Unfortunately we do not have a way to repair this situation since it will pull out again. In this situation since this model has been discontinued , we have been offering an upgrade to the newest model for our cost. If this is something that you would be interested in please let me know."
I have sent back to them asking what the cost would be.
Perhaps I should ask for suggestions on how to fix it, but obviously they don't know.
I am surprised at Kreg's response. I sure hope mine never does that, since it is the same one you have. Although I'm sure the newer plastic models work just fine, there's something about the all metal one that I like. I'm betting they switched to plastic for cost-to-make. Still, it seems there should be a way to fix it. Makes you wonder!!
I know this is a little strange, but I actually had my hopes up. I was thinking I was in for a little piece of good news. This does not look like the 100% lifetime guarantee someone quoted from the web site.
I was also disappointed they did not quote a price. Made me write back and ask what that would be. (I have)
And, I was thinking I was disappointed they did not tell me what they used to install the sleeves. (It had some sort of varnish looking compound on it that I have scrapped off.) To be honest, I did not ask, but they could have been forth coming and told me. But it occurs to me that they have not sold the metal version in years and corporate memory may be short. They may have contracted with some out source supper to make them and they may no longer know how they were made.
I was really pleased I had "one of the originals" that looked to be better made that the cheapened plastic version. This is my fault. I knew I was dogging it. I was drilling hole in a partially assembled piece and the drill was in a bind putting lateral pressure on the bit. Thought I could get away with it. Not good thinking.
Apparently, this was not a press fit piece. I would have thought it had been set with a press, with a metal on metal fit, but now that the sleeve is out and cleaned up, it slides in and out of the hole nicely. I wish there were some sort of ribs or other mechanical registration to position the tube and its chamfer. If it were mechanically registered, I am sure epoxy would do the job.
Not sure why this response disappoints me. Since the tool is fifteen +/- years old, I never thought to contact Kreg until someone posted the idea here. I was in the "I can fix this mode" and trying t save the cost of a new one. Still don't want a plastic one. Still working on a fix. Have not found a reasonable source for a replacement, but I will probably put $500 worth of effort into saving $50 on a new one.
Barry, you have already gotten some good suggestions, Locktite was going to be my first, but if you choose to enlarge and rough it up, JB weld is another product that is tough, and high heat, found at any auto part store.
Oregon ought to make and sell a titaniumnitride bit for their jigs, because of the slicker more durable property, that would aid in chip ejection.
take the two parts to a machine shop and have them knurl the center piece and then epoxy them before pressing them back in, that should hold it safe and sound. The knurling will give it a little more diameter. Just a thought
Take Kreg up on their off, especially if the interior of the sleeve is galled.
The Kreg jig could have been assembled using any number of methods- the sleeve glued in with a fast setting glue like Cyanoacrylate (Super Glue), two-part adhesive (Epoxy), or RF set adhesive; press-fit; or the sleeve could have been installed during the injection molding process. In any case, repair to a "like-new" condition may be nearly impossible without the danger of having to do it again. Since original assembly was most likely a fully-automated, high volume/high speed operation, it just doesn't make economical sense for the manufacturer to spend the labor costs doing repairs.
That being said, you can likely do a repair that will be quite satisfactory unless you abuse it again by using a galled drill bit or putting side pressure on it and allowing the sleeve to heat up. Unless you have a bad bit or are being careless, friction induced heating and rotational forces on the sleeve should be minimal.
The simple solution is to clean the exterior of the sleeve to remove dirt, grease, adhesive residue or sloughed plastic, rough it axially with coarse grit abrasive or a file, then glue it in with a slow setting cyanoacrylate or high temp/high hold Loctite (cyanoacrylate). I wouldn't attempt to dimple the surface for fear of distorting the shape. If in a year, it loosens up again, just repeat the repair process.
Barry Keith came up with a good idea and someone with the dimpleing it also, but with the dimpleing I would be very careful the insert is probably hardend and to dimple it would not be easy to do if not impossible. The J-B weld might be the way to go, but I`d ask the collective if the weld would be able to "GRAB" ahold of the sleeve since it is very smooth surface. Maybe you could rough it up a little with a rough grinding wheel very little so as not to undersizing it. Another way maybe would be to cut a little flat spot on the side of the insert and put a set screw in to the side of the fixture into the insert. I think I would do that with the JB weld. Good luck. But I would try something, because it`s already broke and your not going to hurt it. Larry
Drill bushings are usually quite hard and won't knurl worth a darn. I know that trick though, it's normally a good one.
If I really, really wanted to fix this, I would fill the hole with molten zinc and re-cut it to fit the bushing. Those old ones were cast zinc I believe - what my dad used to call pot metal.
Personally, I'd just go for the plastic one. Tools made from zinc aren't really any better, but they are more expensive. If the jig had been made of cast iron this probably never would have happened, but it would have cost 3x the zinc one, which probably cost more than the plastic one.
Another idea, use those bushings in a nice shopmade hardwood jig Only tricky bit is getting the angles right!
Barry, don't fear the plastic embrace it, remember The Graduate "plastic is the future son" or something like that. Seriously I'm on my 2nd Kreg plastic jig only because I won the newer one in a raffle and gave the other one to my nephew, I've never had a problem with them, probably drilling over a thousand holes.
Loctite 648 Retaining Compound. Lee recommended Loctite 6300 but I could not find it and called the parent company and talked to "technical assistance". They said the 6300 was sold in Europe, but not here and substituted the 648 version.
Its in my nature to try to fix things. Make something out of nothing. So, this compound was $20, an I am going to try it.
If Kreg comes through with a good price on the jig, I will buy it and have a spare.
I tried to find the jig alone but have not had any luck.
I think I will scuff the sleeve a bit and then install it with the Loctite.
Thanks for all the suggestions. I think the thing should have had some sort of key or indexing to state with.
In the first response Kreg offered to sell me a replacement at their cost, but did not say what it was. I sent back asking the price. They have responded with an offer of $25 for the K4 version and $30 for the K5. Not bad considering they list for $99 and $139 respectively. I have responded that I will buy the K5, Asking how to consummate the transaction. Now we will see what they send me. The absolute bare bones jig? Jig with the "wings"? The whole kit with the bits and clamps etc.? Interesting.
I've only had one dealing with Kreg for a replacement and they were very good about it. I had one of the bit-holder + drill bit + screwdrive bit kits and the detent balls in the holder fell out. I let them know and they sent a whole new kit along with no questions asked -- shouldn't have to worry about drill bits for a while since I have three now.
"... I will probably put $500 worth of effort into saving $50 on a new one."
At an Air Force base the wood hobby shop is across the parking lot from the auto hobby shop. People sometimes stick their head into the wood shop door, and when I invite them in for a closer look, they reply with something like, I could never build anything useful from a piece of wood, and these machines are too complicated.
These same people will work on their cars next door and cause $1,000 or more damage trying to save $40 or $50. (One guy worked on his brakes, knowing nothing about bleeding the air out. The parking lot is not level ... he pushed his car out of the bay, it rolled backward across the parking lot, and crashed into a cement block wall and took out a hand rail on the stairs. Before the collision, he was able to jump into the car and step on the brake pedal, but since that was no help, he slammed the shift lever into park -- which also did not help. So, in addition to brake work he needed transmission work, body work, and the wall and handrail needed to be repaired. A $99 brake job would have been a better option that day.)
Acetone contains within spec a small amount of machine oil. It is amazing the number of crafts I have come across that have some magic solution for cleaning parts that actually stems from the fact they are using acetone, it is contaminating their parts, and they then are using the other things to clean off the contamination. It works out because the normal instinct is to use the strong stuff, the acetone, first. Sometimes there is something that needs acetone for removal, but often there isn't I try to get away with alcohol these days.
For years I cleaned my skin with acetone, after using epoxy, a practice many people warn against. Then I learned that epoxy can be washed off with a combo of mild soap and two cooking oils. The point being a lot of people used the acetone because it did remove epoxy, but there were actually several milder alternatives, so check that first.
As a footnote, anything you can do to keep epoxy off your skin in the first place is well worth the effort. I am not sloppy about that. Masterful would be more like it. But eventually one gets tagged.
