Help! I damaged my Kreg jig
I got the bit in my Kreg Jig in a bind and spun the steel insert/sleeve. I have one of the ancient ones that is made of Metal (Aluminum?) not one of the plastic one. For once I was proud of being an early adopter and thought mine was superior to the new fangled plastic ones.
Something gauled the bit and it in turn gauled the inside of the sleeve. The sleeve turned about forty five degrees. It all seized up together. I used a heat gun and managed to pull the sleeve out of the aluminum. Got the stop collar off the bit. Polished the bit up by putting the sleeve with the bit stuck in it in my wood lathe and using a file and 600 grit sand paper on the shaft. Drove the bit through the sleeve with a punch.
I plan to put the sleeve back on the lathe and polish the inside of the tube. the I want to put it back into the aluminum body. The tube appears to be coated with something that looks like varnish. I assume it is Epoxy. How would you remove the old epoxy? Heat gun? polish it off? What solvent?
Then to re-install it I plan to coat it with epoxy and press it into place. Probably will brush the outside with sand paper and the same inside the hole to give a little tooth for the epoxy.
Anybody got any better ideas?
Re: Help! I damaged my Kreg jig
Bill Howatt
Sounds like what I would do.
Since it is metal, I'd try some acetone first to see if it removes the coating. If it doesn't and it's expoxy then the heat gun should break it up.
Bill
Bruce, a MN Galoot
Red Loctite. It won't come apart until the temp hits 500ºF.
Thomas S Stockton
Barry
Like Bruce says red loctite or if it is a little loose Loctite sells a products called press fit repair made to take up a little slack.
Tom
Lee Schierer in McKean, PA
For your assembly you probably want to use Loctitre 6300 Retaining compound. It is designed for slip/press fits and is much stronger than the red loctites.
If you think loctite was used before, cured product can be removed with a combination of soaking in methylene chloride and mechanical abrasion such as a wire brush.
Contact Kreg and ask them what adhesive they used/recommend to repair your jig.
Lee
james jacomb
Yeah throw your kreg away and buy a real pocket cutter! I have used my Porter-Cable 550 for years now with no problems.
Where could I get one?
Amazon lists the 552 production version as unavailable.
Not sure I want one, but was surprised I did not know about it.
They turn up...
John in NM
They're kind of a love-hate thing, no one seems ambivalent about those things :D Not too hard to find a used one with low miles.
Only one I ever used was absolutely horrible - noisy as all git out, irritating vibration, and cut slow. On the other hand, IIRC, it had a single flute HSS bit in it, which would cut well for about 10 pocket holes :D With a quality carbide bit the tool is probably much more pleasant to use. I believe they shipped with that crummy HSS bit, so I suspect the pristine looking used ones still will have it installed :D Find one that is well worn and I bet it will have a proper production bit.
I still like the Kreg jig, since I only use it now and then. Mine is one of the lower end ones that just uses a special vise grip to hold it - stupid simple, no storage space required, and cheap to replace if needed.
One thing I like in particular is that it drills the whole stepped hole, as I recall (and it's been years since I used the 550) the 550 just cuts the pocket.
Ken Eaton Iowa
Did you check to see what Kreg's warranty will do?
According to their web site: "Drill Guides are subject to direct contact with the drill bit every time a Pocket-Hole is created. The core of every Kreg Jig® features hardened steel which carries an exclusive 100% Lifetime Guarantee."
Maybe they can help you get your aluminum jig up and running.
Ken
Larry in NW Ohio
Barry As Ken said I would call Kreg and tell them what happened, and I`ll bet they will fix it or give you a new one. When ever I dealt with them, they were very good. Larry
I would contact Kreg, I feel sure they will help you out. I have two of the "Master sets" in the plastic suitcase. The first I purchased at Lowe's off a clearance rack for about $60. I then bought a spare drill and other odds and ends, a year or so later I was at an estate auction and they had a brand new set with the cardboard still over the case, I bought it for $30. I have used the jigs quite a bit, but I always "lube" the drill bit with Bee's wax before drilling. I just rotate the bit in the drill and shave off some wax before using. Never had any galling or other issues.
