question for post office box bank builders
How do you clean the brass? I tooth-brushed with Brasso and the brass still looks dingy. I am thinking about over coating with lacquer. Would that be a good idea?
Re: question for post office box bank builders
Tom Pilsbury (Chicago)
I'm surprised Brasso didn't work. That stuff is great. Have you ever used Tarn-X? It brightens up silver jewelry to a like new shine. Maybe it'll work on brass too. Of course - read the label first. Good luck.
Another good brass cleaner.....
roger lance
Bill.....I've been using a LV product called Autosol.....may want to have the brass off the wood when using as the black crud and such might discolor wood.....this is a good, effective cleaner.
del schisler
what i did was use a buffing wheel with crocus or the brown rugue and it came out like new brass, and than i done some with a very fine wire wheel brush and had a bursh finish , both look like good , now on the one's you are going to use the brown ruge on what i also done was to wire brush the whole unit , that made the plate look new, now posish the hi lite numbers with the ruge and than spray lacque , look's new than done lot's of them, we used to buy a whole block of them , like for $2.50 each, long gone now , their were a couple styles some with a eagle on the frount , and the knobs had the black dial on them, that was the oldest , than the other's had one knob with a pointer on top and a slide knob under the other that you slide to the right to open, i hope i got all info right, i haven't done one for a while, you can change the combo inside by changing the little screw's , if you change it don't shut door tell you are right on the combo, or a new glass will be in order, good luck del
I've used...
David Yoho
On old tarnished brass I've cleaned in the past, lemon juice has done the job. You might soak it a bit in the juice and then scrub it with a tooth brush and lemon juice.
Terry Quiram
It just so happens I built 5 for Christmas. My doors were extremely dirty. I soaked them with Simple Green, scrubbed them with a nylon brush, rinsed them off and blow dry with the air compressor. A drop of oil around the combination wheels and I was good to go. I sanded the brass with 600 paper. The doors turned out looking almost new. Sorry no pics they are already wrapped up.
Ron in Sterling, CT
I use Simi-chrome (sp) to polish brass & have had good luck with it. For me, it provides more luster than Brasso, and with less work. I spray lacquer on brass once it is cleaned to prolong tarnishing.
Ron
Learning to use Brasso
After brushing with Brasso I was washing the brass with water to remove the Brasso film. Bad idea.
The boxes I have are the pattern shown in the picture. The pattern has lots of crevices. The water that remained in these after washing re-corroded the brass. The more successful approach was to brush the Brasso into these crevices, let it sit a bit and then wick it out with a paper towel, and in fact wipe everything down with a paper towel, then flash dry with hair drier. Then follow up with dry brushing with nylon brush. Finally a coat of lacquer.
Re: Learning to use Brasso
Steve Kreitler
I wish I'd seen this earlier- because the answer to your question is simple and cheap. Simply soak the doors in a half and half solution of Coke, or Pepsi and household ammonia. A bit of scrubbing with a toothbrush might be in order, but this does the trick nicely. You'll need to remove any enameled dials before doing this, as it might attack the enamel. If you wish to remove paint from the windows, the easiest way is to soak the window in soapy water for a day or so- most of it will just slide right off. I've got two classic old doors soaking in this right now.
I bought all of the doors from a fairly large post office some years ago, and I build lots of banks- this trick was passed on to me by Jane Ingram, who makes her living doing this.
