5/4 x 3 S4S knotty pine source??
Kneale Brownson
Kneale Brownson
I need about ten feet of subject wood to make a document frame that matches the window treatment in a building. I need two pieces three feet long and one four feet long. Can't find any sources using the Woodfinder.
Re: 5/4 x 3 S4S knotty pine source??
Jack Guzman from Maine
Where are you located? Are you referring to white pine?---Jack
Do you have a table or band saw? You could make your own with 2x3 stock.
Kneale Brownson
Kneale Brownson
Yes, knotty white pine.
Kneale Brownson
Kneale Brownson
I have the wood and the machinery to make what I need in my barn that's 1400 miles away. I won't be there before I need to get this done.
Re: 5/4 x 3 S4S knotty pine source?? *LINK*
The reason I asked where you are is that I live in a white pine forest . They are everywhere around here. I buy my pine from a local sawmill slightly air dried and unplaned. Home depot around here sells planed kd white pine either #2 almost knot free to a cheaper grade that is pretty knotty. If you're not in New England I could send you what you need. Just have to find out how to ship it.Let me know.---Jack
Also: This is the website of a local lumber dealer that I know sells knotty white pine. Not sure if they ship-
http://deeringlumber.com/
John Veerkamp
Easy to ship. Wrap it in shrink wrap and take it to UPS of Fed-Ex.
You must have some tools
If you're really good with a handsaw, you could do the resawing that way. I'm assuming you have a limited kit of tools, but, not knowing what you've got, it's hard to suggest best approach.
Although I wouldn't want to have to do this in knotty pine, you could mark out the desired thickness and crosscut through the waste every inch or so (or less, depending on grain direction), then knock off the little blocks created before smoothing the rough face that will be left. In knotty pine, although I'm a hand tool guy, I'd be looking around for a belt sander for this last step. Crosscutting: set a circular saw to less than the depth, or mark out both sides and cut with a handsaw.
Finding the wood is of course easier. In this area, 5/4 wood is all but unknown except as special orders for large quantities. There's one yard north of me that might have it, but they have a limited range of species, and it's kind of random what they have in stock.
Kneale Brownson
Guess this DIY becomes more so
Kneale Brownson
All I can find locally is roughsawn. I'm going to try thinning down some 2X4 to get what I need. I have a circular saw, chisels and a belt sander. Thanks for the suggestions.
Re: Guess this DIY becomes more so
Larry in NW Ohio
Kneale If you have one of the big box lumber dealers or even other lumber dealers, they should have most anything you would want. They could do some milling for you also. Good luck with your project. Larry
Commercial lumberyard nearby?
It occurred to me after posting the how to do it yourself thoughts that, if there's a good commercial (caters to contractors) lumberyard nearby, they could probably resaw it for you. Whether the price would be scary or not depends on the yard.
