how to clamp a small mitered box
What is the best way to clamp for gluing a small box such as the one illustrated?
Tape
Henry W
Lay out longish pieces of tape (helps if they are in tension). I use painters tape (decent quality masking tape).
Set pieces in order onto the tape, end to end, with outside corners touching.
Glue the open miters
Wrap it up and add another layer of tape around the entire box.
Don't forget to set the bottom (or in this case the back) in place before gluing - been there and done that.
Henry
Re: how to clamp a small mitered box
Dale Lenz
As the other post stated, masking tape helps me manage the pieces during glue up and then I would wrap a web-clamp around the mitered box.
John Veerkamp
Large rubber bands, like cut from an inner tube.
Hank Knight
Bill,
I agree with Henry and Dale. Tape works well. 3M makes a tape for auto body painting. It is light green color and has some stretch to it so it will conform to the curves of an automobile body. If you pull it tight when you apply it to the glue joint, the stretch provides some additional pressure on the joint that you don't get with regular masking tape. I bought mine at an auto supply store. I've seen light green tape at the BORG, but I don't know if it's the same stretchy stuff that 3M makes.
Hank
Another approach......
roger lance
Bill....good to speak with you again.....Merry Christmas to you and yours.....some time ago I made a flag box.....
and used some shop made aids for clamping the miters which I store in my shop ceiling for the day when I may be asked to make another flag case.....
some people suggest to just glue the 45° stand offs directly to the mitered sides to be joined and then plane them off after the glue is set but I thought that some work could be avoided by attaching the standoffs to a thin piece of plywood that would be held in place by a clamp.....
please note that using these wood clamps for this type of glue up is important as I found that using a regular clamp with an unsupported long bar hanging out in space was able to slightly twist the glue up.....so the wood clamps will be balanced by gravity and not twist your box.
please email me
your email address has some error. I have a forestry issue(fire)
Keith Newton
While the miter looks fine, I think I would do a box joint corner. But then, I always seem to make life harder than it ought to be.
Lee Schierer in McKean, PA
As others have indicated, use tape on the corners to hold it while you get all the pieces assembled, then use small clamps or a band clamp for added pressure and alignment.
Lee
I have done a bunch of boxes. I lay the pieces down with the miters on the underside and the ends butting. Tape the joints with blue tape (because I have blue tape), roll it over, glue the joints, and fold it up and tape the remaining corner. Be sure to include the back and front if necessary. Then you can wrap it with rubber bands, bungee cords, the shrink wrap stuff for packages, or band clamps to apply extra pressure, if you see it needs it.
I use spline joints, either the type with feathers or the type that are folded into the joints. I don't trust plain miters, but they may be OK if you glue the (Plywood) back in.
Are you making them so that the grain runs all the way around the box? I can explain how if you care.
please explain
"I use spline joints, either the type with feathers" ??
"or the type that are folded into the joints"??
and
"Are you making them so that the grain runs all the way around the box? I can explain how if you care."
John in NM
I use those old Ulmia spring clamps. A lot of people don't like them because they leave divots - but I put cross splines where the divots were.
If I didn't have the clamps, I'd probably use tape -- gets great reviews
grain matching *LINK*
Rogowski
thanks
the sled idea is a lot less worrisome than the saw's miter gauge, especially for the small lengths I have to deal with. I will be making one before proceeding.
Re: please explain
Sorry to be slow with the response, Someone beat me to it with the article. I did not read it, but I looked at the pictures and turned the pages. What I was calling feathers they were calling Keys. I use a rip blade to cut flat bottom slots for the keys. I use a rather crude sled that rides on the fence to hole the box at a forty five and slice through the corner. I use a piece of wood with a little stop on it to rip the key stock. Its a little tricky to dial in the exact thickness, but once you find the sweet spot, rip a bunch.
The one I was calling "folded" he presented as a spline. Take car to get the slots "just right". Too shallow is ineffective and too deep, the corner falls off. They need to be very near the inside of the box. (page 42 bottom right in the article.)
And they did a good job explaining how to do the grain matching all the way around. This really adds to the box if the grain is pronounced, like with sap and heart wood or something really striped like zebra wood. I made most of my boxes four inches tall because I could cut them on my power miter box (shop saw) and it worked great.
I have two other tricks I don't think are in the article. I made about fifty wooden hinges. Fun and much easier than it might seem.
And then there is the technique for cutting the lid off the box that leaves it rabbeted so that the lid fits down over the box. Neat trick, but does not apply to the type you are doing.
Boxes are fun. Made one for my niece with a secret compartment.
Merle band clamp *LINK*
Rick L
The merle band clamp is the best way to go. Useful for many other things as well.
http://www.mlcswoodworking.com/shopsite_sc/store/html/smarthtml/pages/merle_clamp.html
del schisler
Bill i have made lot's of those bank's, got them whem the post office change, bought lot's of them for $2.00 each, long gone tho, what i did was use a web clamp on mine use a square and put on the box to make sure that the web didn't pull to one side and make it not square, of course we are not doing rocket stuff, of course it will be square with the web, just make sure that you right down the combe, you can change them in the back by taking out the little screws and moving them to what you want.
Strap Clamps
I use strap clamps. Mine are Pony brand. They work great.
T.
Sent
Re: Tape
Dominic in Buck's County Pa
"Lay out longish pieces of tape (helps if they are in tension). I use painters tape (decent quality masking tape).
Wrap it up and add another layer of tape around the entire box."
That's the way I do it. I learned that from a Box-Making Basics: Design, Technique, Projects" by David Freedman
http://www.amazon.com/Box-Making-Basics-Design-Technique-Projects/dp/1561581232/ref=sr_1_1?s=books&ie=UTF8&qid=1386602483&sr=1-1&keywords=box+making
two ideas
Michael Dresdner
Personally, I like tape paired with self-fusing silicone "tape," which is not an adhesive, but a band of stretch silicone that sticks to itself, stretches 300%, and will conform to any shape and size. This is particularly good for non-rectilinear shapes. They sell it at most WW stores. http://www.rescuetape.com/?gclid=CKGDw9y9o7sCFc9sfgodYmIA0A
Another trick I like, which also works great to keep a whole cadre of small parts being glued aligned (think tumbling block cutting boards) is a pair of L's. Make two ninety degree L's from wood, each with legs just shy of the length of the box sides. With just two clamps you force the four sides together and keep them exactly at ninety degrees. It's wonderful for mitered corners. Make sure you line the L's with waxed paper so you don't glue them onto your box. It's cheap, fast, and something you can make out of scrap.
Bill I haven't read all the other responses but I use string and a stick, like making a turnequet. Make a couple of circles out of string or thin rope. put them around the box, stick a dowel through each one and then twist the dowel until it cinches up all the joints. I usually use some cardboard corners to keep the string from denting the sharp corners.
question
is the silicone tape reuseable?
Silicone tape
Michael Dresdner
Let's just say that it is not meant to be reusable, at least as far as the manufacturer is concerned. I've never tried reusing it, but then, I was sent a case of the stuff for free, so my motivation is lacking. It's not like a rubber band; once it stretches out it only springs back part way, so I'd guess reuse is limited. Do let me know if you have any success reusing it.
Pony tail . . .
Steve Mackay
A square (I've got a right angle gage block) and elastic hair (pony tail) ties. They're small and will "pull", where tape won't. I was wondering the same thing until my pencil got caught in mine. I took it off and tried it. Now I keep them hanging on the "assembly bench". Four or eight will do, then check it with the square.
