"crowd editing" cutting board finishes
This is an experiment for participation.
Possibly more than any other topic, the question of how to finish a cutting board comes up on this Forum. It gets tedious for all (presumably) typing the same answers several time a year. The solution is the WoodCentral Articles section. Here topics of general interest are posted. Persons posting a new question can simply be pointed to the article. So, we need a good article on cutting board finish and Ellis has asked that I wrote it up. He will use his considerable talent as an editor to edit the final Article. Here is your chance to make your thoughts on the topic preserved in an Article.
If you want to add or change something send me an email with the information
The Article is in two parts. First there is a summary of common finishes. Following, is a discussion, simplified but not misleading, of the chemistry involved.
Finish for functional cutting boards and butcher block counter tops
Cutting boards and counter tops can be finished to help preserve them and make them more easily cleaned, or they can be finished to achieve and maintain some appearance. This article focuses on preserving a cutting board to make it long lasting and easy to clean without regard to appearance.
The main reason to add some sort of protective coating to a cutting board is to repel food from entering the wood pores and make cleaning it easier. This treatment must coat and partially fill the wood pores and be resistant to washing, yet it must be easy to maintain and restore. There are 4 common treatments:
1. Mineral Oil The wood is soaked in mineral oil, USP or food grade, available from the drug store. Some heat the oil while others heat the wood to aid penetration. The treatment is quick, cheap and it looks good for items to be sold. The board may feel oily after treatment and oil may bleed out of the wood for some time. This treatment is the least durable.
2. Mineral Oil and Wax Paraffin wax is dissolved in hot mineral oil and the resulting solution applied to the board. The mineral oil aids penetration of the wax. This treatment is durable but more involved.
3. Walnut Oil The wood is treated as it would be with linseed oil. Wipe it on. Wipe the excess off. Walnut oil is a drying oil. It cures after oxygen exposure to a protective film like linseed oil. (see chemistry section for details)
4. Cooking/Vegetable Oil This controversial treatment is both handy and durable. It is applied like the walnut oil. Wipe it on, then wipe the excess off. Repeat when the board appears “dry”. These oils are more viscous than mineral oil, and depending on the plant source they can cure more or less quickly to become even more viscous or even a durable film. They stick to the wood better than mineral oil. Every kitchen has some on hand to be reapplied as needed.
This treatment is controversial because some object that a cooking oil treatment will become “rancid”. This claim is irrelevant for a board that is going to be used to knead bread, cut up meats and similar activities involving food that contains fats and oils. In use, the board is going to pick up some amount of vegetable oil and animal fat which will simply add to the cooking oil previously applied to the board. Upon close inspection a used wood cutting board is going to smell like a used cutting board no matter the pretreatment. If the faint odor of a used wood cutting board is unacceptable it would be better to use a plastic cutting board and run it through the dishwasher.
The chemistry that occurs to make these odors is identical to the curing of linseed oil and walnut oil and no harmful products are generated. The odors result from the same volatile organic acids and related compounds that provide flavor and odor to fermented and cultured products like cheese and bread.
In summary, cooking oil provides a handy means of treating a cutting board with a reasonably durable protective film.
The Chemistry of cutting board treatments
This chemistry section provides more details about the chemistry of fats and oils and how it compares to the mineral oil treatment.
Mineral oil and Paraffin wax are products of refining petroleum. They belong to a class of chemicals called “hydrocarbons”. Cooking oil, vegetable oil, walnut oil and fats belong to a class of chemicals called triglycerides. These chemicals are used by plants and animals to store energy. Animals store triglycerides that we call “fat” to get the animal through “hard times”. Plants store triglycerides that we call “oils” in their seeds to provide energy for germination.
Hydrocarbons are composed of just carbon and hydrogen. In general, for each carbon atom in the molecule there are two hydrogen atoms, that is, the ratio of carbon atoms to hydrogen atoms is 1:2, except at the ends of the molecule, a detail we can ignore for this discussion. The simplest and smallest hydrocarbon is methane. A molecule of methane has one carbon, ethane (2 carbons), propane (3 carbons), butane(4 carbons). Naptha is a mixture of hydrocarbon molecules that are made up from 5 to 7 carbons, Mineral spirits is a mixture of 7-12 carbon containing molecules, mineral oil is a mixture of molecules that contain about 15 to 20 carbons, paraffin wax is a mixture containing more than 20 carbon atoms per molecule and poly(ethylene) molecules contain 50,000 carbons, more or less. As the hydrocarbon molecule contains more carbon and hydrogen the material becomes less volatile starting at methane which is a gas, mineral spirits which is a liquid, paraffin wax which is a solid and finally poly(ethylene), a special class of solids with special properties that we call a polymer.
Hydrocarbons are not affected by exposure to air or moderate heat. When mineral oil or paraffin wax is added to a cutting board it remains unaltered over time. These materials are essentially tasteless and odorless and they will remain colorless, unlike the plant oils.
Plant oils and animal fats are natural products chemists call triglycerides. The name is derived from the fact that the triglyceride molecule contains three (tri) organic acid molecules attached to a glycerin molecule (glyceride). The organic acids are made up of carbon and hydrogen just like hydrocarbons but they also have carbon, hydrogen and oxygen at one end of the molecule that makes them acidic. We are familiar with many organic acids- formic(1 carbon), acetic(2 carbons), butyric acid (4 carbons), stearic acid (18 carbons). The acids in triglycerides typically contain 16 and/or 18 carbon atoms. These acids are collectively referred to as “fatty acids”.
The acids that make triglycerides usually have some carbon atoms that are deficient in hydrogen, that is the ratio of carbon atoms to hydrogen atoms in a fatty acid is typically less than 1:2, unlike like the case for a hydrocarbon.. These “deficient” carbon atoms will react with oxygen when exposed to air. When they react with oxygen one of two things can happen. The site where the oxygen has reacted can cleave off a piece of the fatty acid. The piece that cleaves off will become a smaller acid or related molecule. These smaller acids have a strong and characteristic smell that can be detected in tiny concentrations. These same acids are made by bacteria during fermentation and “culturing” and result in the characteristic odor of many cheeses, buttermilk, bread, etc. When these odors are associated with fats and oils that have reacted with oxygen we say the oil has become rancid.
After reacting with oxygen, instead of breaking off a piece of the fatty acid molecule to make a smelly acid, the triglyceride molecule can attach to another triglyceride molecule. The resulting molecule is twice as large, less volatile and more viscous.
The various fats and oils differ from one another in how many of their carbon atoms are deficient in hydrogen and therefore are more or less prone to react with oxygen. If there are a lot of deficiencies like in the case of linseed oil, or walnut oil, there will be a greater probability of one triglyceride molecule adding on to another. After exposure to oxygen for some time lots of triglyceride molecules will have added to one another to make a giant molecule we call a polymer. Polymers are tough and rubbery and make a good coating. We refer to this chemistry of adding together triglyceride molecules to make a tough film as “curing” or “drying” the oil. Chemists call it “polymerization and crosslinking”. In addition to curing/drying, the oil will also be splitting off smaller volatile acids that give these films their characteristic odor, especially in a confined space.
Oils like olive oil and saffron oil have fewer carbon atoms deficient in hydrogen. They can’t react enough to make a tough film. They don’t even react enough to generate many smaller stinky acids. In between are the oils like soy and corn. They will react with oxygen to generate smaller acids and they will react with one another to make big molecules. But they don’t react (cure) enough, or in a short enough time, to be as good as linseed oil or walnut oil for furniture finishing. Never-the-less they cure enough to stick well to a cutting broad.
The fats and oils that accumulate with use, as well as the accepted walnut oil (or anything else with organic oil in its name- linseed, Tung, etc., experience identical reaction with oxygen to generate the same volatile products as adding some oil from the cooking oil bottle. So, for a cutting board that gets used it will smell the same whether it gets freshened up with oil from the cooking oil bottle or not.
Re: "crowd editing" cutting board finishes
Keith Newton
Bill, Thanks for writing that. Not having had chemistry in school, somehow you managed to make it more understandable than anything I have read.
My question though, is what to do before and after butchering meat. After cutting up a deer, bear or whatever else you folks in E TN shoot. What do you wash down with, and after a month or so, before getting started?
Another thing, which usually comes up, is the choice of woods. While the dense even texture of Hard Maple is desirable, is there any advantage or disadvantage to using woods with natural decay and insect resistance. Are these chemical based properties bound, or subject to dissolving and being absorbed into the food?
We actually have several cutting boards and two butcher block counter sections. I concentrate turning animals into parts on a maple block I made eons ago in MN in night school. After its job is done we wash it down with soap and water, a squirt of cleaner that contains bleach and then a light renewal of vegie oil. After bread kneading we just scrape the counter top blocks. The blocks we use for light duty cutting of vegetables and the like get a wet wipe and renewal with vegie oil as needed. I am not paranoid about bacteria, living on a farm. There is sheep poop everywhere and I am sure we track it into the house and from there who knows. I believe people have become "cleaner" than they need to be, or maybe should be.
In a commercial/public situation people with AIDS and cancer treatment, etc have to be accommodated. The ends they go to to prevent disease seems to be way beyond what was practiced in my youth, or what needs to be for a typical healthy person.
I was selling some lambs to a woman carrying a toddler and accompanied by a young daughter. The toddler dropped his pacifier (I despise these things) in the sheep pasture littered with "jelly beans". The kid picked it up and thrust it back into the toddlers mouth. The mother shrugged and allowed it boosted immunity. She may be right. As far as the farm goes it is less germ hazardous than nursery school.
Trees need to defend against fungus and the heat wood is laden with chemicals to do that. I don't know about bacteria.
Deja vu
Thanks, Bill. Your chemical discussion took me back to Organic Chemistry class in college. I aced it then but have forgotten most of it.That was a good, clear explanation and doesn't need a whole lot of editing or crowd sourcing.
The other questions/comments I have about this article from the inquisitive editor's viewpoint are:
1. Do you really want a drying/polymerizing oil on a surface that will be cut with knives? If so, are walnut or linseed oil preferable to heavier-duty, film-forming finishes like varnishes that contain resins in addition to the drying oils?
2. How is a mixture of paraffin and mineral oil more involved than mineral oil alone, and is it worth the extra involvement? What advantages might this have over standard mineral oil? I've been using Clapham's Salad Bowl finish for many years, and it is an aqueous emulsion of (I think) mineral oil and beeswax. It gives an attractive, in-the-wood surface to cutting boards and salad bowls. If you've got to heat the wax to mix with the oil and water, and then beat it with a mixer, there is a caveat about wax vaporization and fire hazards.
3. What about no finish at all -- just a soap and water wash after use?
4. Do we have any reviews of other commercially available products or homemade concoctions that are recommended for cutting boards and salad bowls.
OK, you asked for it... *LINK*
David Yoho
I've laid low on this topic but I feel it's time to speak up. Use it or don't but I know it works.
All cutting boards I make get one treatment and it has worked. I use Waterlox!
I got this method from Charles Neil several years ago. The idea is not to create a surface film but one inside the wood that seals the pores. I'll provide a link to an old newsletter Charles published where he talks about this and tests several things people use.
I think the information presented is worthy of addition.
Charles Neil on Cutting Board Treatment
There's a university study somewhere
that compared wooden cutting boards to plastic and other ones. It was a little gory with chicken parts and blood left on the boards and germ counts taken over hours. AS I recall, the conclusion was that wooden boards won out and were "naturally" protected. Wish I knew how to find it.
Where do I order my...
Joe in a Cleveland suburb
printed and autographed copy of this article?! :D
Please put this in the "WoodCentral Articles" section so I can read it, then read it again, and again, and again... over and over until it sinks in!
Thanks.
comments on Neil's information
I am agreeable to adding Neil's finish recommendation but doing so will take some additional explanation. Your post did make me realize that there are two finishing issues, initial and maintenance. The person and goals of the initial finisher (possibly seller or gifter)could be greatly different from the person doing maintenance 5 years after the board was made.
We need to know about "driers". Driers are chemicals added to curing finishes that speed their reaction with oxygen. What ever happens to the oil or varnish after it is applied happens much quicker with a drier present. Recall from the chemistry section that the carbon atoms deficient in hydrogen react with oxygen. This reaction results in the smaller oil molecules adding together to make a huge molecule that we call a polymer, which will become a tough and durable film.
It gets claimed that some chemical form of lead was once used as a drier. Perhaps this is true but there are better driers, for example those containing cobalt. While it would be trivial to determine, I don't know what drier chemicals are added to Waterlox. But whatever they are the paranoia over exposure to drier chemicals is great. This fear of exposure to cobalt, or whatever, will prevent many from considering a drying finish for food contact. As an added note, the short shelf life of Waterlox exposed to air is a result of the highly reactive drier chemicals added to the formulation.
Neil's test may be misleading. Given more time the linseed oil would have cured(dried) to provide as good a barrier as the varnish. I have found that given a lot of time vegie oil will cure too. Additionally, a dye molecule is small enough to penetrate places a bacteria can not go. Never-the-less, the Waterlox or any vanish is going to initially be a better barrier than any alternative. How practical it is for maintaining a cutting board, I don't know.
Thanks, David
Yes, my question about commercially available alternatives was intended to get someone to fill in the blank about wiping varnish. I wasn't aware of Charles Neil's recommendations, but I too have used both Waterlox and Behlen's Salad Bowl finish on woodenware, as well as a product from Swing Paints called Antique Gel Varnish, which I have found to have even tougher resins. The key with all of these is to wipe off the excess and let the remainder dry in the wood.
response
1. Do you really want a drying/polymerizing oil on a surface that will be cut with knives? If so, are walnut or linseed oil preferable to heavier-duty, film-forming finishes like varnishes that contain resins in addition to the drying oils?........I think a varnished cutting board that was used for cutting and dough working would be impossible to maintain. The oil in dough would soften the varnish and leave it gummy as is the case where body oils come into regular contact with a varnish finish.
2. How is a mixture of paraffin and mineral oil more involved than mineral oil alone.......I regard safely melting wax in mineral oil "involved". , and is it worth the extra involvement?....... those that use it must respond for I don't have any experience.
What advantages might this have over standard mineral oil?.....wax is certainly going to bleed back out less
I've been using Clapham's Salad Bowl finish for many years, and it is an aqueous emulsion of (I think) mineral oil and beeswax. It gives an attractive, in-the-wood surface to cutting boards and salad bowls. ...you need to add this experience to the article.
If you've got to heat the wax to mix with the oil and water, and then beat it with a mixer, there is a caveat about wax vaporization and fire hazards..... Indeed!
3. What about no finish at all -- just a soap and water wash after use? looks awful and provides no barrier to penetration of stuff from food.
4. Do we have any reviews of other commercially available products or homemade concoctions that are recommended for cutting boards and salad bowls.....now is the time to add this experience
http://frogojt.com/Cuttingboards.pdf
Re: Preservation of Waterlox
Waterlox is expensive stuff, but definitely worth it. To keep it from skimming over and eventually gelling in the can, I find it worthwhile to make another investment in Bloxygen, which is inert Argon gas in a pressurized can. If a couple seconds squirt into the Waterlox container after every use is done consistently, the Waterlox doesn't react with air in the can. The Argon is heavier than air and thus seals the top surface of the varnish, preventing oxydation and polymerization. The problem, adding to the cost of the Bloxygen, is that when you pour out the Waterlox, you also pour out the Bloxygen. There is a work-around, in the form of disposable pipettes, which will extract small amounts of varnish from the can without disturbing and losing the Argon gas. At 4¢ each in lots of 500 from Amazon, they are a lot less expensive than two seconds of Bloxygen.
heating oil and wax
Henry W
I can't understand why anyone would heat this mixture on a stove, unless they were off the power grid. This is the mixture I use for cutting boards, mostly for the sheen you get. It is easy for customers to "refinish" and/or re-apply this.
My answer to melting the wax is simple and quite accessible - the microwave oven. I use a glass bottle (spaghetti sauce I think) filled less than half full of the mixture. I microwave on LESS THAN FULL Power, about a minute at a time, allowing about a minute in between cycles. The liquid oil heats up more quickly than the wax, but if you give it time (out of the microwave), the wax will melt and mix. 2 or 3 cycles seems to work for me (your results will vary depending on the power setting and power of your appliance). Works for me...
Henry
Nifty trick, Henry. Thanks.
Varnishes and oils
My hunch is that the added resins in varnish products actually provide a better barrier than just the cured long oil itself. All things being equal, whether these alternatives reside in the wood or on it, the resins would produce a harder barrier coat. I'd need some corroborating evidence to state this as fact.
What I do instead...
John in NM
Is take a gallon of Waterlox and put it in jam jars and the like. Glass does not get recycled in our area, so the jars just go in the trash otherwise. Fill them right up to the rim and put the cap on tight, I've had Waterlox for years doing this. Usually it takes a nail hole or two in the cap to get the stuff out of the jar later, but that's ok with me.
Once you open the jar, you have the skinning problem if you can't use it all up in the time before it skins. Since I use small amounts these days, I'm forever saving smaller jars for successive decanting, but that gets complicated and you have to be a real cheapskate like me to prefer that over buying products like bloxygen.
I've also heard of people using propane in place of bloxygen, as it is heavier than air, cheap, and readily available. I would be concerned that it could react with the finish product, but I've never tried it out - Bill might be able to provide a prediction in that regard, but it's beyond my limited grasp of organic chemistry.
Re: Varnishes and oils
I don't see that hardness of the coating is relevant unless it sits on the surface. On the surface it will be cut in use and pieces flake off. In the pores a rubbery material would seem to be as effective as a hard one. Abrasion resistance would be determined by the wood and extraction resistance determined by properties other than hardness. In any case none of these formulated finishes is as convenient as adding a dab or vegie oil when needed.
Re: heating oil and wax
Last board I made was coated with Walnut oil - several coats - wiped after each coat. I gave this to one of my son's along with the remainder of a bottle of the oil. Most of my boards have been coated with a hot mixture of Bee's Wax, Paraffin with just enough mineral oil mixed in to soften the waxes. I have an old steam iron in my shop, used to lift dings, soften hide glue etc. When I heated the wax mix, I just turned the iron upside down, clamped the handle in my vice and set the pan on the iron - worked great. Then I applied the hot mixture onto the boards and "ironed" it into the boards, wiping the excess off while still hot. This seemed to penetrate very well and I have one board in my kitchen over 5 years old that still looks good. (However it is a large board so isn't used as much as some smaller ones.)
Very interesting article Bill, I learned quite a bit! I do know that some of the vegetable oils do become quite hard and solvent resistant. My youngest son works for a Soybean processing facility. (I do get all my cooking oil free). A few years ago they removed and scrapped all their indoor and outdoor explosion proof lights and replaced them with new high efficiency units. My son asked and received permission to take the scrapped lights. I have a couple to install in the shop yet. The glass globe on these have been coated over the years with soy oil and this has hardened to an amber colored "epoxy" type coating harder than any enamel or varnish I have seen. I have tried to remove this mechanically, and with several solvents with little effect!
Propane- the NOT brilliant idea
Excelling in cheap, I thought propane would be a dandy way to displace oxygen from a paint can. Indeed it does. However, it dissolves in the organic solvents leaving behind a vacuum which collapses partially filled paint containers. The vacuum will also suck in air if the seal is not perfect, remedied by turning the can upside down. Any leak gets sealed from the curing finish.
Microwaves should not heat mineral oil, in theory
In theory microwaves should pass through mineral oil just like light passes, without much effect. Indeed when I put full power on a bottle of mineral oil in a poly(ethylene) bottle(similarly theoretically transparent to microwaves) it only warmed slightly. For microwave radiation to couple to the electrons in a molecule the electron density at one end of the molecule must be different from the other end. Water, with oxygen at one end of the molecule and hydrogen at the other becomes excited by microwaves efficiently. A hydrocarbon with its regular arrangement of carbon and hydrogen (1:2) from one end of the molecule to the other should be inefficient.
But as one famous scientist proclaimed, "theory guides, experiment decides". If it works my understanding of the theory is flawed. Note: some containers do efficiently absorb microwave radiation as do all conductors.
While on the topic, the MW can be used to measure the speed of light, and dazzle your jaded children. Sprinkle some grated cheese on a circle of stiff paper. Put in microwave in a way that it does not rotate. Pulse until spots of cheese melt. Measure distance between melted spots and that is 1/2 the wavelength of the microwaves . Use the formula- velocity equals wavelength times frequency (2.45 gigahertz or 2,500,000,000 for a typical microwave) to calculate the speed of light(electromagnetic radiation) in air.
Re: There's a university study somewhere
Howard Acheson
This may be the study you are referring to. It was done quite some time ago and there is new data supported and published by the USDA.
UC Davis study:: http://faculty.vetmed.ucdavis.edu/faculty/docliver/Research/cuttingboard.htm
USDA Recommendation :: http://www.fsis.usda.gov/wps/portal/fsis/topics/food-safety-education/get-answers/food-safety-fact-sheets/safe-food-handling/cutting-boards-and-food-safety/ct_index
The bottom line seems to be that a plastic board is easier to clean effectively.
Clint Searl
Clint Searl
Conventional wisdom seems to be roughly split between using a drying oil or a mineral oil concoction, with a resin based finish a distant third. Perhaps it's a moot issue, since there's no evidence that any offer a functional advantage over simply leaving the wood untreated.
Aha!
John in NM
Reminds me of a youtube video of a 55 gallon drum with a few gallons of water in it. Heat on a fire until the water boils, then screw the caps on and remove from the fire :D
I figured you'd know the answer, thanks Bill :D
Howard, I don't understand how you read that article and come to the conclusion that plastic boards are easier to clean. Perhaps you consider running them through the dishwasher to be the easy way?
I admit I am biased toward the wooden boards. Perhaps because I am a wood worker?
John in NM
I remember that study, the UC Davis one.
It's not really a single sentence sort of conclusion, which is an occupational hazard for scientific writers. But basically, the results were that plastic was easier to clean effectively, but cleaning wood was largely unnecessary, since the bacteria did not seem to persist on the wood surface as it did on the plastic.
The one caveat, and it is a very important one, is that the plastic surface became nearly impossible to clean (I'm assuming through average household means) thoroughly once it was much used and knife scarred. That is a big, big plus for a wood board as they reported no change in bacterial suppression on a well used wood surface as a new one.
On the other hand, I seem to remember that when the discussion of the UC Davis study came up a few years ago, there were some legitimate criticisms of the methodology. I've now forgotten what they were, as they didn't change my view of the results, but I couldn't dismiss them as nit picking.
Purely speculatory now, I wonder if wood boards are hostile to bacterial survival because they tend to absorb water? How long does your wood board stay damp vs. a plastic one? Quick drying is the surest way to keep bacteria from being a problem in the kitchen - that is why 140 degree water is enough to rinse dishes. The temp doesn't disinfect, but the quick evaporation of a hot dish quickly leads to a dry (and thus hostile) surface for germs.
At least that's what my mom taught me :D :D :D
