ot mice in dishwasher
Jerry Gibbs
My daughter has a problem with mouse droppings in the bottom of her dishwasher. She will run the dishwasher, leave it closed up and later find mouse droppings in the bottom. This has happened on several occasions. The washer has a normal hot water supply. The drain goes into a garbage disposer which then goes to a trap. She has tried closing the sink drains. In addition the bottom of the washer where the water drains is covered with a screen. For what its worth, the washer is a basic GE about 2 years old. If anyone has suggestions my daughter will greatly appreciate it. Jerry
Re: ot mice in dishwasher
should have googled
Jerry Gibbs
This has been a problem for others and there are suggested answers. In my opinion if a mouse can get in a closed dishwasher, there should be a leak problem.
Re: should have googled
Larry in NW Ohio
Jerry I think you are quite right, if a mouse can get in a closed dishwasher, there should be a leak. I have never heard of this. What I would do is, of course, and I`d guess she already look the washer all over for an opening, then I would put a mouse trap in it and at least try to catch it. At least that way she`ll maybe get rid of them. Best of luck with it. Larry
walta
Try running the sanitize cycle. The normal cycle is only about 160, the hi temp cycle may get him.
Walta
John Veerkamp
All dishwashers have air vents up high to let out steam/moisture from the drying cycle. This is the only possible access for the mice. usually these are located on the front concealed by the top pannel trim cover. Run the dishwasher on heat dry and observe where the steam vapor is escaping. possible solution, remove the front cover and insert some fiberglass screening. The real solution of course is to rid the house of mice.
Mice in house...solution
Tom Dunlap
"The real solution of course is to rid the house of mice. "
Kitty! My three would do a job on the mice population. They even take stinkbugs out of the air and smash them. They know enough to only smash and run though. :D
Tom
Re: Mice in house...solution
OK, so just put the cat in the dishwasher over night, with little night vision goggles and a tiny little 32 gun for fun......just kidding.
I would have thought the mouse came in under the bottom of the door. I am half guessing here but I thought some dishwashers had little more than a rubber flap at the bottom that shed the water back into the pan.
Wonder why the mouse keeps going in there? Are you in the habit of leaving dirt dishes in it until the next wash happens?
Try this ..
mike farinella
1. Buy a small package of "Sticky Traps" for mice
2. Put a small dab of peanut butter in the center.
3. Place the trap in the bottom over night. Do not run dishwasher.
I think you will be amazed. I was.
Lee Schierer in McKean, PA
I don't think our dishwasher has a seal across the bottom of the door. It simply relies on the fact that the water spraying is occurring up higher and that it will run down the door and drip off the lip. As others noted there are also air vents for drying and allowing the room temp air to escape when hit with the hot water at the beginning of the cycle.
Place some sticky traps near the dishwasher over night baited with peanut mutter and your problem will go away by morning.
Lee
