DeWalt 733 Fixed
Stuart Johnson
I finally got time to install a new busing. You can see the old one is cracked and worn into an oval.
I only installed the one but will probably do the other three when I get time. I did have a couple problems.
1. There is a rather stout spring pushing the bushing (57) into the holding bracket (56).
2. The room to get a screwdriver onto the screws is limited even with the head cranked up as high as possible..
Between 1 and 2 I managed to strip both screws and had to grind them off. Not hard but a pain. I hate Phillips screws.
The springs in number 1 can be overcome with a bit of pressure with a clamp.
I ended up buy a set of sprockets, not needed and four bushings. So all in all it was not an expensive fix.
One last issue was my own doing and a slap the forehead when fixed. In trying to get enough room to get to the screws I cranked the head up as far as it would go. The yellow sides and top were removed as a unit and would not go back on. I spent a half hour trying to figure why when finally the light bulb when on and I lowered the head.
