The chain chain cover has two screws on the bottom. Once removed the cover slips down.
The back chain goes to the motor and the back roller.
Three C clips hold it all in place.
I slid the chains back on for the photo. Prior to removing them the top of the back chain and bottom of the front was very tight. The opposite side in both cases was loose. The bottom of the drive chain (back) seemed to flutter from time to time and then run true again. The time between flutters was about the same as the skipping.
I just noticed in the photo the chains both appear to now have some slack in both sides. They were remounted in order to take the photo so I don't if it makes any difference.
I am guessing you took the top and both yellow sides off??? Then the cover over the chains?
I don't see a problem with your parts. Obviously if a tooth were missing from a sprocket you would have shown that. Didn't you say you blew a bunch of crud out of the enclosure?
Stuart In your second picture, your chain sure seems to be very loose, are they that way when you have it altogether. If so it may be skipping a tooth especially under load. You might try putting new chain on and see if that does any good. How old is the chain. Good luck Larry
I dismantled mine today to the point Stuart was at, except I did not remove the sprockets and chains. My chains were about as slack as his. Are we thinking they stretched? Does anyone remember seeing them when they were new? Where could we find a picture of them as new?
I planed a poplar board after I cleaned mine and it did fine. (I don't like fixes that don't seem to make sense.)
Prior to removing the chains one side was cery tight and the other very loose. When it ran fhe loose zide on the back chain would flop or flutter from time to time.
I have ordered two new drive chains. They claim to ship in one day and they indicated they were in stock. When they get here I will install them and let you know the result.
It will be interesting to see if they are shorter/tighter than the old ones.
I missed out on what the problem is with the planer. From reading the thread I take it that the chain was skipping a tooth or jamming.
For around 40 years I've worked with chainsaws. What I learned about chain is that what is called 'stretch' is something different. In each link's rivet there is a small tolerance machined in so that the link moves. If each link has X units of tolerance and the chain has 100 links by the time that all of that tolerance is pulled to one side of the round rivet hole the chain is going to need adjustment. The tolerances add up so it takes a few adjustments during the first hour of cutting with a new chain.
It's hard to imagine that those chains or sprockets could be worn out in a lunch box planer. Think of how many chain drives there are...bicycles...motorcycles...chainsaws...which are put to a lot higher load, yes, different chain/sprockets, but still.
The little sag in the chain drive looks pretty normal for that style chain. There has to be some tolerances or the whole works would lock up the first time a chunk of debris got between the link and sprocket.
In any chain drive repair I've always read that it is best to replace the sprockets at the same time. If not, the new chain will 'lap' itself into the worn sprocket and the same slop will occur. Again, this is low load and occasional use so it might be different.
I ordered new chains and after I placed the order I began to think I should have ordered the sprockets also. Wonder if turning them over would have any beneficial effect?
Considering the amount of use and low load on the sprockets I really doubt that they're worn in this application. You'll be able to look at the chain and sprockets to see if there is wear. It doesn't seem like flipping the sprockets would gain much. Since the chain is driven both ways there should be equal wear. Not like in other chain drives.
Carefully inspect your old chain for wear before you put on the new ones. You might not find any wear.
Can you operate the mechanism with the covers off? Is it still skipping?
Unlike Stuart, I was afraid to run mine with the covers off. I really wish I could have seen this one soon after I bought it. Having trouble with the idea that so little slack is creating a problem. Wish I had pulled the sprockets to see if the keys or slots were worn. There's always tomorrow.
I am thinking using it will not harm it to use it.
I got a bit of shop time today and took another good look. Neither the sprockets or chain look worn. When assembling I noticed the back roller on one side has a bunch of movement. Someone in the other thread mentioned the bushings (part 57) caused him a problem. If a strain was put on this causing the roller to lift up that might be causing the skip. I ordered new bushings and will let you know if there is any change.
