The Peckerheads Have Done It Again
William Duffield
They've created another dysfunctional tool, at an absurd price.
http://www.woodpeck.com/ottpaoliniplanergauge.html
You might find something exquisite from John Economaki worth paying for and waiting for, but this bauble is really questionable.
You probably already have the tool you should be using to do this job, not to mention a lot of other essential shop functions. For example there is this one, at about half the price, and you can have it in hand next week, and not next March.
http://store.harryepstein.com/cp/Squares/7104-4R.html
Mine is nearly as accurate as my Starretts, and is easier to read than most of them, because the blade has a satin finish. The blade is hardened, so unlike the melamine surface of the pecker tool, it should last for a century or two and still be readable and accurate.
Many years ago, I bought one of the cheap aluminum versions of the planer gauge, but I never use it, because it has no real uses. It sits unused it the same nook I dropped it into in my tool chest when I got it.
Remember, you are probably running each of your pieces of stock through your planer multiple times, and you need to check each board each time it comes out of the planer, to decide whether it has been reduced to the required thickness, and also how much you need to crank down the planer head for the next pass. If the board is too thick, it doesn't fit, but you can't tell how much more needs to be removed. The bigger problem is remembering the target thickness, and consistently finding the right gap in the tool.
With a double square, you "set and forget". Offer the square up to the stock as it comes off the planer, and you can feel the amount that needs to come off with the tip of your thumb, so you don't even need to blow the dust off your glasses to read the measurement. The 4" double square is continuously variable, so you can easily set it to the nearest 64th of an inch, from 3" down to the thinnest piece of wood you can feed throught your planer. If you're counting, that's 192 different settings, not a paltry 13.
But wait, there's more. There are all the other uses for the double square, from marking tenon shoulders to checking jointer fence squareness, table saw blade squareness, and bandsaw table squareness, to router bit height to Forstner bit depth, scribing a line parallel to an existing face, and the list of real functions goes on. If you need metric as well as imperial, just get another blade. You don't have to pay for another whole square. Note that Dominos also come in thicknesses of 4, 5, 6 and 8 mm., all less than the 9 mm. minimum gap provided by the Paolini. "Recommended" stock thicknesses for Dominos (3x tenon thickness, FWIW) also include 30, 36 and 40 mm., all beyond the limits of the Paolini.
I've also used outside calipers that you have to set from a separate ruler.
