Veritas - Innovation in Tools
Using BONDO as wood filler question
Rick Snyder
Hello, A friend of mine has a pedestal that has gotten chewed up on one corner (mitered) by their dog. It actually looks like termite damage. I have heard that some people use bondo instead of wood filler,epoxy,etc. What are the pros and cons of using this product and is it stainable, tintable, etc? The pedestal is constructed as such, that the problem area can not be replaced with new material.
Thanks, Rick
Re: Using BONDO as wood filler question
John Veerkamp
Bondo is an epoxy with fiber filler(fiber glass). Bondo that I'm familiar with is pink so I doubt it can be stained or tinted successfully. It does however take paint very well. If it is a natural wood surface/color some one who is good at faux painting should be able to make it look fairly good.
John McGaw
I used auto body filler (Bondo) as filler on my little entertainment center made of MDO plywood and it worked well but that is sprayed in black lacquer. Since the filler is made with an impermeable catalyzed resin (polyester I believe, from the smell) it won't respond to regular staining. A skilled painter might be able to paint in realistic wood grain to make a match but it would certainly be beyond my limited skills and I wouldn't even attempt it. There is some sort of wood-like material sold for repairing major rot and damage in wood and that may be stainable but I've never used it so I can't say.
Re: Using BONDO as wood filler question *LINK*
Dick Coers
The main pro for using Bondo or any 2 part material is that you can build it up thicker than single component. Original Bondo is gray. The pink is fiberglass filled and different product. The fiberglass filled is for filling holes, the original is for filling dents. They do have a wood filler that they advertise as being able to take stain or paint. Never used it, can't imagine it takes stain too well.
bond wood filler
walta
I have used both Bondo products they will never pass for wood without paint.
I prefer the steel product it seems to stick better to the wood.
Walta
roger lance
I've used the following product on outside house repair projects which were then painted....
Jesper, Denmark
Re: Slight correction.....
Jesper, Denmark
Bondo is polyester, not epoxy.
All the comments regarding suitability of the Bondo also applies to epoxy. Both are sensitive to UV light, and need to be covered with paint.
Paul Leuba
Roger: Is that a 2 part product?
Paul in Hunt Valley, MD
William Duffield
I've repaired and restored lots of furniture chewed on by Man's Best Friend, and by lesser varmints, and even kitchen cabinets made from pictures of wood on termite barf. I can't imagine a case that cannot be patched with real, matching wood using a marking knife, chisel and router. You may need to build up the underlying structure with Bondo, epoxy or System 3 SculpWood, depending on how vigorously the dog did his work, but you can always permanently cover it with real wood.
roger lance
Paul.....yes, two part.....the hardener comes in a separate tube.
