Need advice for a new microwave
Larry in nw ohio
Anyone have advice on which microwave to buy. The whirlpool went out after only 4 years. So will not be buying that brand again. Suggestions? Thank You Larry
Larry in nw ohio
Re: Need advice for a new microwave
John McGaw
Well, I have a Sharp 930AW convection/microwave that I bought in 1999. It has just started to show signs of failure in the microwave function but I suspect that this is heat-related, possibly because of sucking up dust for all these years. Won't know that until I get it removed from the cabinet -- it is a heavy devil and I've been putting off the task for a couple of weeks now. Even given that, I have some faith in the brand.
Stuart Johnson
We have a Panasonic 1250 inverter that works fine. It doesn't have all the bells and whistles of some but the price was good. I bought it through Amazon two or three years ago so the price was good but maybe not great.
I would think about how you use it and then go from there.
Tony - Memphis
We've been very unhappy with our GE. It is 15 years old and still kicking though - can't complain about that. Issues are that it is VERY loud and several features quit working shortly after install. This is the type that is over the stove. It does heat well and has the rotary thing that works well. We use it daily.
Tony
Larry in nw ohio
Sorry I didn`t say much about it. It goes on top of the stove and gets used every day and quite a bit. Thanks. Larry
Merle
Our Sharp Professional has been going strong for the past 6 years and is still like new. It is used daily, but there are only 2 of us in the house. FWIW
don stephan
Whatever SHMBO wants . . .
Kurt
We've had a Sharp for probably 10 years. Not many bells & whistles, just a turntable. The clear plastic covering on the keypad is starting to come lose over the keys but everything still works fine.
Re: Need advice for a new microwave [update]
John McGaw
Rather late but I'll confirm by vote for the Sharp 930AW. I managed to get mine out of the kitchen cabinet where it is mounted (heavy beast mounted high and tight) and onto the table and opened it up. The problem turned out to be an overheated power socket that was part of the cabinet-mounting kit. Everything inside the oven itself was working perfectly after 13 years so it is probably a pretty dang good piece of equipment. Just wish I could have avoided the hernia trying to get it back into the cabinet though...
