Table saw question.
Table saw question.
Table saw question.
Tom Pilsbury (Chicago)
There is probably a real simple and obvious answer but this just has me stumped. Why are the miter slots in a table saw not the same distance from the blade? I can't think of any reason why they should be either, but it just looks odd and I was wondering if there is a practical reason for the difference.
Re: Table saw question.
This is a conjecture and I don't really know.
What about tenon (and other jigs) and miter gauges? Those are the things that always go in the miter slots. It would seem to make sense that different jigs and gauges need different distances from the blade. For instance if you wanted to cut a tenon, it would be helpful to easily go to one side or the other of the work piece.
Good question !
Observation.....
roger lance
I do not know the specific reason.....but, I've noted that the slot furthest from the blade is on the side that the blade tilts toward....and for some operations, this increased distance is useful.
John Pappas
I have an old Rockwell 9" saw, and the slots are the same distance from the saw blade.
AlanWS
The reason it might be handy is that you could then reverse a sled or miter gauge and use it facing the other way in the other slot with the same cut edge and stop blocks. My guess as to why they are not the same is that it would be difficult to ensure that they were exactly the same, and then you might not know which direction the setup was for. If they are unevenly spaced, all that's needed is that they be parallel. If the blade was centered, even if irrelevant, people would complain if it was off by thousandths.
I think Roger is correct.....
Mark Hennebury
In relation to your saw, but as usual there are different solutions.
My saw has mitre slots on the right and left of the blade, that are about the same distance from the blade. The right hand one has a filler strip in place at the moment. The solution in this instance was to cut a 45° angle on the lefthand side of the mitre gauge.
This is how the mitre gauge is on my 1950 Robinson sliding table saw; You can see that in the last picture i have positioned gauge over the righthand mitre slot ( not in the slot as the filler strip is in it) My slots look to be about the same distance from the blade, but you can see that the gauge would accommodate the blade tilting toward it with the 45° cut on the lefthand side of the gauge. If you didn't have the 45° cut on your gauge you would have to have the right hand slot a bit further away from the blade to allow your blade to tilt.
Good answer!
The photos help explain it best. Yes, the slot on the right side of my blade is farther away by about 1 1/4". This will allow enough room to tilt the blade without the miter gauge getting in the way.
I'm glad I finally got around to asking the question. Seems I wasn't alone in my curiosity.
