Our Cat(OT)
Our Cat(OT)
Our Cat(OT)
Larry in nw ohio
is over 10 years old and when he does the hair ball thing, what he coughs up is only food that he just ate. Or if he eats and then after a few hours he just coughs up liquid. I have never seen anything like what is called a hairball like my older sons cats cough up. Is this anything or is our cat a little different. Thank You Larry
Re: Our Cat(OT)
Re: Our Cat(OT)
Merle
I am not a vet, but you should check with yours. This doesn't sound right to me. FWIW
Re: Our Cat(OT)
Re: Our Cat(OT)
BrianMonumentCO
I have two cats and they both do the hairball thing.
Most of the time it is a brownish color like the science diet food they eat.
But occasionally I have seen a greenish vomit.
I asked my vet after that happened if that was ok and was told ok.
With a caveat that if it became a regular thing we ought to see him again.
I am not a vet nor did I stay at a holiday inn.
But my guess is that the greenish stuff is from the deeper part of his digestive system.
While the other material is from upper part of stomach/digestive system.
By the way I consider discussions on cats to be on topic for woodworking.
Their claws work as rasps or aggressive sandpaper for anything made of wood.
Particularly visible section of furniture that one did not intend to do any woodwork nor finishing of.
Re: Our Cat(OT)
Re: Our Cat(OT)
"By the way I consider discussions on cats to be on topic for woodworking.
Their claws work as rasps or aggressive sandpaper for anything made of wood."
Or, as the old saying goes, cats are God's way of telling you not to care so much about the furniture.
They're also useful to hold things down, although it's not always easy getting them to lie where you want them to (say, on top of a recently veneered panel, to keep the veneer weighted down while the glue dries).
Re: Our Cat(OT)
Problem Solved Here
Since we feed our puss wet food (no corn, gluten, etc., content for weight control) per vet direction, she gets 1/4 teaspoon of Citracel fiber sprinkled on her food at each of two daily feedings. The methylcellulose is completely non digestible so it keeps things moving in one direction, especially hair.
Re: Our Cat(OT)
Re: Our Cat(OT)
don stephan
Frequency of vomiting and recent weight changes are important. Irritable bowel and digestive tract cancer both can cause vomiting. This fall we had several instances of vomited clear liquid over two weeks and then found a mature roundworm in the last. After roundworm treatment haven't had any more clear vomit.
Vets can be a good thing.
Re: Our Cat(OT)
Re: Our Cat(OT)
Lee Schierer in McKean, PA
You probably need to take your cat to a vet as your cat could have a serious condition.
But, for hair balls you can buy tubes of hair ball remedy that you squirt out like tooth paste and smear it on their upper lips. The cat licks it off and the hair ball goes into the kitty litter and not on the floor. You repeat this at intervals to prevent the hair build up. You have to do it more often on long haired cats than on those with short hair.
Lee
Re: Our Cat(OT)
Re: Problem Solved Here
Larry in nw ohio
Mark That Citracel, do you think that it would help if we would just give that to him with the dry food that we have? Thank You Larry
Re: Our Cat(OT)
Maybe Not
Ask your vet. The issue with the power on dry food is the ability to aspirate it into the bronchial tubes. Not a good thing.
We had to get our cats off dry food as they were gaining too much weight from all the corn and gluten content in dry food which are not part of cats' "natural" diet. We found a line of single-serving cans that exclude the grains and starches, similar to the "Fancy Feast" brand but at less cost. Cats have done well with them, and the powdered fiber mixes in.
