Pocket hole screws; Kreg jig; questions *LINK*
I find myself headed toward another compromise from woodworking purity, into a realm about which I know little.
We're remodeling a room in the house that has an alcove that will hold a natural-gas radiant heater - looks like a woodstove, doesn't involve schlepping wood in and ash out. It's tiled up four feet, and will have a painted frame-and-panel mantel-like trim a foot wide, wrapping around the back and sides of the alcove. The design scheme is Arts and Craftsy, so the frame and panel will be simple, square edges on 6/4 (1-3/8" actual) poplar frame members about 2" wide, flat panels of Masonite (the amount of recess to be determined in the course of the build). The whole thing painted white. There's plenty of structural meat behind the wall for me to fasten to, so, once this thing's in place, it will have no life purpose besides sitting there looking pretty.
I'm thinking about breaking down and using pocket screws for the assembly, something I've been avoiding for years. Because of my denial about this construction system, I know little about the fine details.
First, is what I've described workable with pocket screws? Kreg says it is, but there's sometimes a difference between the manufacturer's beliefs and field realities. Are there fine details I should know about this joinery technique, not obvious from the tools and manual?
Second, I'm considering the Kreg "JigMaster," which has a jig into which you clamp your board, with various adjustments, and a DeStaCo type clamp to hold the piece; and then a Vise-Grip with big faces on the clamping jaws to align the pieces being joined; plus other bits and pieces. This seems like enough for the job at hand and for what I can contemplate for future jobs.
I'd appreciate the thoughts of this brain trust.
Thinking about this jig
