Something new
Larry in nw ohio
I`d like to try my hand at something new. What is the best way to start to inlay. What would be the best books to get and read, with lots of pictures. Always like books with a lot of pictures.
Larry
Something new
Larry in nw ohio
Larry
Try your local library - the books are free!
Re: Something new
del schisler
larrry go to these web site's u-tube video's on inlay's, i have done it and it is fun, get the inlay bit and set up and it will go very well, the link
https://www.google.com/#q=utube+on+wood+inlay
What kind of inlay?
Tony - Memphis
What sort of inlay are you interested in?
Tony
Re: Something new *LINK*
Bob
Larry, I got into this about a year ago here is a good resource for you. I spent about 45 min. on the phone with the owner Dave today they have been around for a log time and are a pleasure to talk to. There pricing is about the best I found for what you get - which is also the best veneers I have found. The link is to a book you may find useful, he has two others as well.
http://www.dyed-veneer.com/woodworkersguidetoveneeringandinlay.aspx
Re: Something new
And you will need one of these --
OptiVISOR Headband Magnifier
http://www.stewmac.com/shop/Tools/Special_tools_for_Inspection/OptiVISOR_Headband_Magnifier.html#shop/Tools/Special_tools_for_Inspection/OptiVISOR_Headband_Magnifier.html?tab=Pictures&_suid=1379435527206017403529852906524
Re: Something new
William Duffield
I would start with this old compendium of articles from FWW: Veneering, Marquetry and Inlay, the Best of Fine Woodworking. It is relatively inexpensive in the used book market. It's probably in your library, as well.
http://www.abebooks.com/servlet/SearchResults?sts=t&tn=veneering%2C+marquetry+and+inlay
You might try Amazon, as well, if you are looking for the lowest price.
If your tastes lean towards early 19th Century (Federal Period) style, Lie-Nielsen carries four DVDs on Fundamentals of Inlay by Steve Latta. I already provided a link to these a couple of days ago in the thread on "Sand shaded fans", but here it is again:
http://www.lie-nielsen.com/catalog.php?grp=1320&sort=prd_author
The DVDs are ordered alphabetically on author's first name, so Steve's DVDs are at the bottom of the page.
If you want to go back to the source, Lost Art Press is publishing a new translation of Andre Roubo's "To Make as Perfectly as Possible, Roubo on Marquetry."
Re: Something new
Larry in nw ohio
WOW everyone, as Tony asked, "What would I be interested in" well just reading your replies, that already made my head spin. What I thought I`d like to try is to just inlay some simple things in what I build, like cabinets and such things. Just would like to pretty up some of what I try to build. Thought if I could put an inlay on it, it would take theirs eyes off the mistakes I make
Thanks all of you. Larry
Re: Something new
Tony - Memphis
The reason I asked is becuase the term inlay is kind of general. There is marquetry, string inlay, etc. Either way, there are some good books out there and lots of good info online. I too decided that some of my work needed somethign to distract the viewer, so I added a dragonfly to my last table. This was veneer, so I'm not sure how it would be classified, but it was tough to do. I tried scrollsawing the pattern and that was a disaster. Ended up just tracing and cutting by hand. It took a few tries, but the gaps are negligible. Experiement! I tried several different knives and I did lots of trials before I found something that worked for me. I ended up using paper as a backer to keep my veneer pieces from splitting. I sand shaded the lower wings a little to try and get a little depth. I'll try and post a list of books I referenced. There is one in particular by two English guys that was really great.
Tony
I found the book name after I posted this...
Marquetry Course Paperback
by Jack Metcalfe (Author) , John Apps (Author
The wings are sycamore veneer I sawed from a pen blank I had and the body and eyes are dyed veneers I bought online.
Re: Something new
don stephan
There are perhaps two basic approaches, not sure which you are thinking of pursuing.
One is inlay in solid wood, such as stringing and bellflowers in Federal pieces. Might also include here I seem to remember router guide bit kit that would use a template to rout a negative space in solid wood and then rout out the positive space in another piece of thin wood or veneer.
The other approach is marquetry mentioned above, done all in veneer and then the completed assembly glued to a substrate. If you are interested in the latter I would highly recommend all the articles written by Paul Schurch in Fine Woodworking and all his dvd's www.schurchwoodwork.com. If you are new to veneering I would also recommend the dvd's by Darryl Keil www.vacupress.com There is some overlap between Schurch and Keil but not enough to only get one or the other. If you are lucky, your local public library system may have some or all of these videos.
Marquetry takes some time to develop comfort and skill, but not as much as I expected starting out, and some amazing results are possible. For veneer, I can't say enough about www.certainlywood.com - great to work with and great supply.
Good luck!
Re: Something new
Larry in nw ohio
Thanks for all the replies. I usually work with solid wood in my projects, but I have some ply in some of them.Larry
