Raising drill press table
Tom Dunlap
My drill press column is a straight tube and the table clamps onto it in typical fashion. There's no rack/pinion height adjuster.
Does anyone have a clever table lift for a drill press like mine? The DP is a heavy duty old Craftsman.
Tom
Re: Raising drill press table
JMOHNIKE
scissors jack. Have had one on my old Delta floor mod. for over 30 yrs.
Dale warder
Many years ago, 1970s I think, several manufacturers made an aftermarket device for just this problem. It consisted of a roller chain suspended from the top of the column with a bolt-on crank attached to the table to raise or lower the table. I had one of these in the time. They worked very well. Unfortunately, I sold mine with the drill press, and I can't seem to locate a current supplier. You might be able to find one of these at a flea mkt or used equipment shop.
Another technique I have used is a cable attached to the table passing over a roller at the top of the column and the other end attached to weights to counterbalance the weight of the table. Also works well, and should be possible to jerry-rig to most drill presses.
Hope these suggestions are of some help.
Dale
I know exactly what you are
Gary Smyth
experiencing on this. These were made in the 1970’s when Sears made a real effort to make some professional machines. I have two floor model 1970's era Craftsman 15 ½” drill presses (one is a 113.21370 the other 113.213780. At the time that these hefty mothers cost about $159, the accessory for the table was separate, and was $79 + shipping. In fact Sears sold drill press models available with and without a motor. (without was 113.213702) The machines themselves were made by Emerson Electric. The lift was offered only by catalog for a short time only. Perhaps as short as one season. The reason was that the lift was made one at a time by a guy I thought in Montana, but after writing this probably Michigan. I don’t remember now. He made the thing, but was not a part of Sears.
Several years ago I had the luck to find a companion drill press to the one I already owned. The one I owned had a lift I bought when I ordered it. The one I found did not have a lift. After several crashes of the thirty pound table down the post I went out looking for the lift. I called Sears, no luck. I checked the code and found the original drill presses were made by Emerson. It gets fuzzy here but eventually (according to old notes, via case 345281, I got a name.) I called information (remember when you could do that) in that state and ended up with a woman. She told me years before it was her husband who made the lifts and just as things were starting to work out he died. Numerous orders placed via Sears went unfulfilled. She told me that all that remained was his shop with parts. I asked if there were enough parts to make one more lift. She didn’t know, but for $80 she would send me a box with whatever she could gather. According to my notes the box weighed 27 lbs, it was from Taylor’s Ace Hardware, 6141 Homestead Blvd, Colstrip MI, 59323. 406-748-3450. The box had enough to get me through – but was shy a few items I eventually scrounged by looking at my original and improvising. I’m pretty sure that I have the last lift not already on someone elses machine. Of course, if your machine is not a floor model this tale is for naught. If it is, you will always struggle (and I do mean struggle) with the table but you can rig a wire cable, some sort of anchor attached to the post, pulley, and some weights (approx 30 lbs) that will at least counterbalance the table to keep it from sliding down the post – which if it has happened to you is quite a surprise -- and hard to get back into position. The pictures show both lifts. There is a lock (red handle), a geared crank that fits a bicycle chain, a weight to hold the chain from kinking, a collar where the chain attaches to the post and a c hook with a bearing. Hope this helped.
I retired mine to be permanently set up for mortising and bought one with a crank that makes the table go up and down. Delightful invention. Looking back at the decision the new machine with its handy table adjustment was well worth buying.
Jerry Nicholson
I built a table height adjuster using a Harbor Freight trailer jack. It has worked fine for me for several years. There is a detailed discussion somewhere in the archives but I don't remember the year.
Jerry
Pete in Holland, MI
Have seen older commercial drill presses that have a cable and counterweight system. Cable attaches to the table between the column and machined suface. From the far rear will cause an inbalance and make it tough to lift the table. Cable went up thru the head, pulley at the top of the column and counterweight inside of the column itself. Taking the weight off the table makes it much easier to position up & down if it weighs 5# instead of 50#.
I Scrounged 40 pounds of lead......
Now I know what it was for. I was waiting for a good idea.
Wonder if you could buy a new table and the rake and pinion parts to convert yours?
Larry in nw ohio
I did the same thing as Jerry did with the trailer jack. I think it is suppose to be a jack for the hitch to raise it up so it can be hooked up. It`s very simple thing to do. I`ve had mine on for more 15 years and works very well. If your interested I can maybe take a picture and post it so you would have a better idea. Larry
Rack and pinion...
John in NM
You can buy them at McMaster Carr, and probably other vendors. McMaster is generally the most expensive place to buy stuff, but between their selection and well organized web site, it's often worth paying the price.
The drill press at work has a hand crank, the rack has to rotate with the table to keep the pinion engaged.
My drill press has a clamp ring on the shaft. I use it to hold up the table sometimes when I want to rotate it without losing the height setting.
I almost deleted...
Tom Dunlap
...the thread just after posting. But I got distracted and then spent the rest of the day in the shop.
I'm glad that it stayed up. Reading Gary's story was wonderful! What a treasure to find :)
There is a machined flat spot at the place where the table meets the collar clamp. Just in front of the facing that rotates the bed. This will be the perfect place to mount an eye screw for the cable to operate the counter weight. There is a nice 'tunnel' going up through the neck of the DP for the cable. A pulley up on top and sash weights down the column. Slick setup.
The scissor jack is a good idea too. I'm going to measure how much travel I can have and check out the salvage yard.
My DP is a bench top model but its mounted on a sturdy cart. If I recall I bought it for about $150 in mid-80s.
Tom
Dick Coers
I'd say the problem is the weight, not a method to lift. I would add a pulley on top and connect the table to a counterweight with a cable or rope. Do a Google Image search for drill press table counterweight. Pictures from Harbor Freight trailer jacks, cable counterweights, and spring assist cylinders. I use Google Image search daily for design inspiration to problem solving. Best thing they have!
Janice Manuel
My old Walker Turner drill press is like that...rather than moving the table at all, I have a stack of plywood pieces handy and simply add/remove them to get the working height I need...
I had one of those…
Rod Peterson—Ormond Beach, FL
…but I didn't know the back story. Fascinating.
I sold it with the drill press when I got a new Delta that had a built in rack & pinion elevator. Night and day.
Thanks for posting this story.
Rod
