Very busy morning for me as I have a lot of catch up work to do at the day job from being off last week. The LOML and I spent Friday and Saturday in my shop cleaning up, putting up, organizing, and such. Now we have a fairly clean shop that has space enough now to move around in. I can actually think about woodworking projects now since I have a shop that is in much better shape than before.
The heat of summer came back to us and boy has it been hot. Still working on the odds and ends of the remodeling work on the inside of the house, spent time with the family yesterday, played bass guitar at church and rested a bit.
That's it for me, so what did YOU do this past weekend?
I can't imagine my wife helping me clean the shop. You're a lucky man!
I spent the whole weekend stacking firewood. Hurricane Sandy did a number on our woods last October, and I lost five red oaks that were close to three feet in diameter, along with a lot of other trees. It cost me a bundle to have the wood cut and split, and then I was left with about six cords of split wood piled around my woodshed. So, this weekend, I finally bit the bullet and started stacking.
First, I stacked a couple cords inside the shed.
Next, I stacked another couple cords under the lean-to.
At this point, I had run out of storage space under cover, so I decided to build a couple "Holz Hausen" woodpiles out in the open. I built the first one yesterday, well almost. It starts with a ring of sacrificial logs in an 8'-dia circle. I covered the bare ground inside the circle with sheets of oak bark to keep ground moisture at a minimum. Then I started stacking, filling the center cavity with oddball chunks and kindling-size pieces.
Here's where things stand as of now. The stack is now almost 6' tall and will go another foot or so to a beehive-type dome at the top. It will be covered with a small tarp and left to dry until it has shrunk about 20% in height, which is the expected dimensional shrinkage from green to firewood EMC. Each finished Holz Hausen holds about 2 1/2 - 3 cords.
I still have about three cords piled on the ground and another 5 or 6 cords cut but not yet split in the woods. Those log sections are too heavy to lift onto a splitter without a Dingo or skidsteer, so I'm still undecided about how I'll go about it. I will probably have to rip them with a chainsaw and shell out another pile of cash to have it all split and trucked down to the shed area, where I'll have to build at least another two or three of these domes. The cruel irony is that with what this is costing me, not including my own labor, I could have bought about 15 cords of dry wood. (Of course, I'd still have to stack it.)
After a few catches and bowl dismounts (sounds like gymnastics doesn't it?) from my first shop-made Longworth chuck, I decided I could no longer live with the imperfections. For non-turners a Longworth chuck holds almost-finished bowls or platters on the lathe so that the bottom can be finish turned, sanded, and finished.
I figured that concentricity between the two base and top plate was the biggest issue, as the mounted pieces were never quite centered. This also meant that re-sizing the chuck for a new piece was difficult because the "buttons" were not moving in the same arcs and they jammed.
I removed the top plate and re-matched it with the base plate, using a few screws to attach them. I tried re-drilling the presumed 'center' hole, but of course the new one was a partial overlap with the old hole and the bits kept straying into the existing slightly off-center hole. I quickly tired of this and simply turned (on the lathe) a mortise about 1.25" diameter through the top plate and into the base plate. Next I turned a tenon on a scrap block to fit into the mortise. I detached the top plate, reversed it for use, and glued the center block into the mortise. When dry, I turned the scrap block down to a manageable size and depth, and re-installed the buttons.
This provided a re-newed Longworth chuck with much improved concentricity and buttons that move in concert with each other to re-size the chuck.
Ellis I had the same problem a few years ago. I sold my splitter years ago, thinking, I should stop doing that, I would not need it anymore. Bull. After we had that storm come thru a year or so ago, I had more wood that I could handle. I made one of those Holz Hausen an needed to split the logs, since I didn't need my splitter anymore and got rid of it, I had to do something else to get them split. So I came up with cutting them length way about half way. Then took a wedge and a splitting maul and had at it. I was surprised How well it worked. Believe it or not, I enjoyed myself. I always liked to work cutting wood. Have a good time. Larry
It was getting mid afternoon and the sign said "Estate Sale". What the heck. I wasn't looking to buy anything but this was in plain sight with people walking all round, ignoring it on its metal stand. I have a much smaller inexpensive 4 x 24 stationary sander with 6" disc. I use it for a lot more than I expected, from sanding to sharpening, to rust/burr removal, so this 6 x 48 and 9" disc for $45 was of interest. Following estate sale convention I asked if he would consider a bit less. He would. After I paid, several other guys asked where I found it. I pointed to the center of the wall. It was in plain sight, exactly the same place it had been for the previous six hours. The sanding machine portion weighs in at well over 100 pounds and the assembled sander and metal stand wouldn't fit into the Honda so I broke it down to get it home. Reasonably clean, runs well with the disc and belt on. It's an older Craftsman, I think the big one they had 1 1/2 HP (peak) 351.225950, it ain't the honk'in 6 x 48 w 12" disc Rockwell, but it'll do.
Chainsawed up 5 logettes (diameter of log + 4") from a sugar maple that died and dried standing - and bandsawed LOTS of dry turning blanks. Then did the same with five sugar gum eucalyptus crotch logettes. Probably 60 % ended up as scraps for my fire pit in the japanese garden and probably 95 % of what was saved for turning will end up as curlies after turning.
It was HOT, but even hotter wearing chainsaw chaps, a turning smock verlcroed up at the collar, a hat and ear protection - HOT - even working in the shade. Chainsaw dust sticks to sweaty surfaces - acting as an insulator - holding heat IN - in me. When things cool off and the rains come I'll have lots of nice spalted maple to play with and some really interesting sugar gum eucalyptus to get to know more about.
Must convince my arborist , tree trimmer friends to stop delivering interesting wood to my house since I still have about 40 logettes of now dry claro walnut logettes, a half dozen logettes each of bradford pear, plum, apricot and cherry to convert to turning blanks - sigh . . .
You may find many people willing to split and stack all the wood you have left just for a share of the wood - say 50%. I know I used to burn wood and I had deals with landscape people that removed/trimmed trees for a while. They would cut the trees down or trim, and chip up the branches - I would go in and cut up and remove the rest. I'm sure there are many in your area that would love to "earn" free firewood. Those pieces that are too heavy - may not be for a couple of young lads with a splitter!
We found housing for our daughter faster than expected (she will be studying in Brussels, Belgium for a year) so my wife and I had a free weekend to enjoy Belgium. I am a war history fan, she likes castles.
Saturday and Sunday we took day trips to Vimy Ridge, Hill 62 and Hill 60, and visited castles in Beersel and Ghent. In the evenings we went to the Belgian Beer Weekend that was ongoing in Brussels at the Gros Markt.
