Plunge cuts
Paula
I need to make a square hole in the middle of a 2x4. Should I use a circular saw and make a plunge cut or do you think an E cut blade would work better??
Plunge cuts
Paula
Have a chisel?
Mike Farinella
Drill hole(s) to remove most of the waste then square it up with a chisel.
saber saw
. . or an e-cut blade . . .
Yonak
If you're cutting holes in 2X4s something tells me it won't have to be real pretty.
all the way thro the 2x4 ??
How large a hole?
The size of the hole will influence the better approaches.
Re: all the way thro the 2x4 ??
Paula
Ya all the way. Basically it's a 2x4 about 10 inches long. I need a square hole in the middle of it.
Re: How large a hole?
Paula
About 2x3
Re: . . or an e-cut blade . . .
Paula
Ya I think you are right ...but can I get a blade long enough to go 2 inches down?
Drill a series of holes at each end of the hole - 1/2", 3/8", thereabouts. Get out a chisel, and start paring away at the wood.
Larry in nw ohio
Paula I did something like that with a saber saw or jig saw, whatever people call them. Drill a hole about the size you want and clean it out with a GOOD jig saw, not a cheap one. There is a big difference in them. Good Luck. Larry
Yonak
Most of the e-blades are 1 1/2" long. The biggest problem you will have is cutting the hole perpendicular to the surface of the 2X4.
If you decide to go with this method, I would :
1. Hold the 2X4 down firmly.
2. Draw the hole where and as you want it on both sides of the board.
3. For each side of the hole, clamp another piece of 2X4, that you know has been cut square to the top and bottom, to the board at the line.
4. Align the blade, as flush as you can, with the edge of the guide 2X4 and be careful to keep it aligned, as you cut half way down.
5. Turn the 2X4 over and do the same thing on that side.
6. If, at this point, the piece doesn't fall out, which is pretty likely, a hammer and/or re-cutting/trimming will be necessary.
7. Know that the hole will not be perfect. If you need it to be more perfect, use one of the other methods mentioned, such as drilling pilot holes at the corners and finish with a saber saw or chisel.
