OT: Well Pump Useful Life Expectancy
Paul Leuba
Our 14 1/2 year old Gould well pump submersed in a slightly sandy 88 foot well just went up.
What is a reasonable life expectancy for a well pump under such conditions.
Paul in Hunt Valley, MD
Re: OT: Well Pump Useful Life Expectancy
roger lance
The first submersible sump pump I had lasted 28 years. The guy at the plumbing supply store (where I got the first pump) said to expect 12 years out of the replacement.....and so it is going.
Stuart Johnson
I don't know the answer to your question but have you looked into having it rebuilt. We have a an aerobic septic and had the pump go out. A new one was installed and like always I keep the old parts. Later I took it apart and all that was wrong was a gasket. I haven't gotten around to repairing it yet but will at some point. The second pump that went out was the air pump. It was replaced with new Gast (big bucks). Later when I took the old one apart I found out the membranes would go out on them and cost less than $20 at that time.
The problem is when something like pumps go you don't really have time to explore all the options. In your case it's no water in mine it was no toilets.
It will last until.....
basil
.....some time in the future when it's extremely cold, extremely dark, extremely rainy and a long holiday weekend. That was my experience until we got county water system. Now the water goes off more often but it's someone else's problem to get it fixed.
Kneale Brownson
Sandy pump?
Kneale Brownson
Is the pump actually sending sand? If so, I'd replace the screen when I replaced the pump.
I've had a pump in a sandy soil setting (below some barrier material, of course) that's worked for 30-odd years now. Probably fail now that I boasted about it.
In a different location, still sandy soil between clay layers, I had two pumps fail in something like five years, but that was because of lightning striking the ground nearby.
