Re: Clamping a bent lamination question
Sgian Dubh
1. Do I need a "caul" strip between the lamination and the clamps?
It's a good idea because it saves making indentations in your top lamination. Use an extra strip of laminate or find a piece of 6 mm ply.
2. How do I keep the clamps from skidding. They skid downhill as I tighten them.
In the straight edge opposite the curve cut angled notches roughly parallel with the curved edge so that the length of the clamps are perpendicular between the curve and its matching straight notch.
On much tighter bends than this, and big curves we bore holes in the former so that the ends of F clamps go into them. You don't need that.
3. How close together do the clamps need to be. (I have lots of clamps)
Fit in as many as you can that you are able to get in with your hands and tighten comfortably. About 3" apart should work fine. Apply pressure first at the brow of the curve and work outwards to the extremities, either one direction at a time or work outwards equally from the brow, whichever suits.
4. Any other advice?
Use a non-creeper glue, e.g., epoxy resin, urea formaldehyde, etc. Work fast to get the pressure on, avoid creating voids which is why you should work from the crown outwards. Wax the curved edge of the former, or stick plastic parcel tape down on the curved bit-- in fact, wax, polish or tape off any wooden parts you don't want to stick to your laminations, or to which you don't want your laminations to stick. Make sure you don't allow the laminates to drift out of line-- perhaps attach the wide face of the former to a base with screws so that you can push the edges of the laminates down to the base. Your curve is not at all severe--- it should be a doddle. We eat gentle curves like this for breakfast, lunch and tea. Don't be afraid of it. Slainte.
