Biggest lathe I've ever seen! *LINK*
Tom Dunlap
Variable speed...lots of power...and portable!
Big lathe
Re: Biggest lathe I've ever seen! *LINK*
Larry in nw ohio
WOW I`d like to see the table he intends to put it on. Larry
Here is one longer!
It is two Powermatics welded end to end.
Kneale Brownson
Re: Here is one longer!
Kneale Brownson
Re: germ of an idea
Tom
http://www.youtube.com/watch?v=P4qB6n1cm04
Re: Typical biggun
Tom
Somewhere I have pictures of some really big ones. The period around WWI seems to have spawned massive tools. I don't know whether their equivalents are today. Maybe they learned to work with sub assemblies of steel rather than full length castings, or something. Not to mention improvements in ballistics, though those were well underway in light arms by WWI. Today certain effects could be created by a drone with small accurate weapons, that might not have occured with a Big Bertha type gun in the past
http://www.youtube.com/watch?v=epclkzKJvfc
Some lathes after 6 and 9 minutes
Re: Rudder job
Tom
This one interested me. When I built my trimaran, the design called for a post that ran through the rudder top to bottom, so it could rotate on a neutral balance point, and so the rudder could have an ideal shape. It required weldments that I didn't have the capacity for at the time, though I do today. I made the whole thing up, only to discover when I got my tiller fittings for the top that they did not fit. I did not realize that the tubing I had bought was pipe and had external dimensions of an unusable size. Much quality stainless stock is pipe, or gun barrels, etc... The project remained unfinished for a good long time, due more to stuff I was doing at the time. By the time I got back to it, I had a lathe that allowed me to turn the tubing to a proper diameter. My set-up was through the headstock, but otherwise similar to the above picture.
Nick Cook has a new Powermatic 2442 with a bed extension that is longer than that. Don't know the exact dimensions but it takes up the entire wall length of his shop. :)
he missed an opportunity
this lathe sat next to his shop for months. Nobody would buy it because nobody could move it. I think the shop that owned it turned porch posts with it.
Back in the mid 60's I worked at the Youngstown steel mill in the East Chicago, Indiana area. The plant I worked in made "seamless" tubing for Nuclear, Oil well drilling and gas lines etc. There was a railroad siding inside the plant that ran about 1/4 mile. There was a three piece lathe (could have been a couple more "steady rests" in there too) that was placed on the rails when they needed to turn new bars that pushed a plug through the billet at the start of the pipe manufacture. As I recall the power unit was usually only 50 or 60 foot apart with the cutter / traveler unit in between, but could be extended up to a 1/4 mile! When the parts were made the lathe was removed and train cars ran on the track.
