All my tools stolen, need advice.....
The house we are working on was broken into and they stole everything that had a cord or battery. Milwaukee Sawsall, Milwaukee 1/2" right angle drill, Bosch drill and impact driver, porter cable plunge router, Porter cable air compressor and three nail guns, and my Hitachi nailer for teco clips, and on and on. Even took the mirrors we had not installed yet.
They got my ancient Chop saw. It was a ten inch and not a compound one. What would you recommend? Not really interested in a slider (don't have room in my shop for when it comes home.)
PS, this is the best reason I know of for recording the serial numbers of your tools. the Cops now have a "Links" program that will search all the surrounding pawn shops for the stuff, but they must have the SN. So, go record yours.
Re: All my tools stolen, need advice.....
Watch surrounding Craigslist too
Oh, deep bummer!
My son bought a Bosch sliding compound saw, and somewhat regrets giving me his (old, distcontinued) Hitachi compound miter - the Bosch is heavier and a lot bulkier. Based on what he's told me, unless you're cutting a lot of 10" wide siding or similar, a miter should be enough. The compound - 45 degrees right and left horizontally and vertically - is really nice, and I wouldn't consider less than that.
Brad Bransky
Really, really sorry!
Brad
Larry in nw ohio
Really sorry to hear Barry. I hope they are able to find who did it. With the serial# on them it may be easier. I think if it were me I would put motion detectors around where the tools are and maybe a camera and a super loud horn that would scare the crap out of them so they would leave a trail of crap when they run, and kind of hide them so they could not easily see them. Good luck Barry, but one thing kind of good is you get to shop for tools. Larry
I've been thinking....
about posting a reward poster in the yard. Something like $250 for the return of the tools or for the arrest and conviction.
OTOH, that might put a curse on me when I try to sell the house.
I'm checking Craig's List.
The Detective Suggested printing the list of tools and taking it to local pawn shops.
Back to the question, What about the Makita chop saw?
If your pawn shops are like
Henry Higginbotham
. . . some of the ones around here, then giving them a list of items and serial numbers just tips them off that, when they do take the stuff in, they need to wholesale it to their buddy who sells his wares at the flea market 60 miles up the road.
Makita tools are pretty reliable
John in NM
I'm sorry to hear it Barry, that always sux. Even had them locked up in a house!
For chop saws, I'd say stick with the 10" blade unless you need something bigger. Smaller blade just tends to be more stable and you get a better cut when using cheap blades or dull blades. Of course, none of us ever do either of those things! :D
Before I got my second hand Hitachi slider, I used a pretty standard Delta miter saw, not a compound one. My complaint with it was that the post the saw pivots on is not square to the base, so the cut was always a little out of plumb. Easy to shim it, but I never seemed to get around to that. From this point of view, a compound saw might be better even if you don't use the compound feature often -the tilt stop for 90 degrees will likely be adjustable.
james runchey
Barry, I had a similar situation 30 some years ago. Was doing a fire job and I locked up the tools at night with a padlock on the door. Next morning i found the padlock cut off and all the tools missing. I believe it was the guy who picked up the dumpsters. I lost a sawzall, drill, wormdrive skillsaw, and several other tools. Worst of all, I had a really nice set of premium chisels I lost. I often think of those chisels and get mad all over again.
Kevin French
My son had his shed broken into last year, and he put motion light on it. So far there's just been an increase in deer poop in the yard.
Merle
Barry, I hope they catch the miscreants and string them by by their, oh never mind, that would never happen. :(
Anyhow, I have had this scms for over 10 years and it is still very accurate. If it ever dies or gets stolen, I will get another one just like it.
http://www.amazon.com/Hitachi-C10FSH-10-Inch-Sliding-Compound/dp/B00007J8CH
Re: I've been thinking....
Bruce, a MN Galoot
I have a Makita chop saw, the LS1013. It's really good, reliable as the dickens. I've had it 10-12 years, and while it doesn't get used steadily, it's rock solid. If you get one, don't bother replacing the blade that comes with it; it's great and provides glass-smooth cuts.
Hope they are still sending the same blade....
I just ordered one to be delivered to the local Home Depot. Looks like it will be as good as and better than the one that was stolen, and ancient Dewalt. The only joy in this is that they stole it with a really dull blade on it we used for cutting laminate flooring. (That stuff eats saw blades, even carbide ones.)
Out of chaos, order or perhaps From adversity, opportunity. I get a chance to review my tools and improve them where I can. Still painful as I liked many of them and had spent a life time accumulating them.
