Questions about Lowe's Plywood
I made two vanities for a house I am flipping. (Keeping out of pocket costs down)
Used Lowe's 5mm "underlayment" plywood for panels in the doors and drawer fronts. Drop panel doors. We have used this plywood by the acre under vinyl flooring. It has a rotory cut back face of some blond unknown wood and the front face is redish and appears to be quarter cut. The face is so thin the edge of the ply is invisible and now I am wondering if it is wood at all. You can sand through ti with 220 sandpaper in an instant. I used quarter sawn poplar for the door frames and face frames. Until I stained it the cabinet was very red and green. I used dark redish black stain and tried to wipe the panels lighter than the frames. thinking the quarter sawn type stripes would be nice. Turns out they don't show at all. In fact, If you look closely you can see the second ply's rotory cut figure through it. Just how thin is that stuff?
Still happy with the cabinets for the purpose.
Re: Questions about Lowe's Plywood
How much does one save building cabinets using underlayment plywood vs quarter inch birch for stained door panels?
As Much
As Possible.
In my area, anyway, quick-sellers ("flippers") are a caution light for buyers as that quick coat of paint may be hiding serious issues and a wary eye is required.
Mark Nowicki
How much quicker would you be able to flip it if you bought bought a cabinet?
Mark
Re: As Much
Bill, I did build the vanities to save money, but the cost of the birch vs. the underlayment was not significant. The underlayment is about $15 a sheet and the birch is about $30. The underlayment seems to be well made. Its five ply and has few or no interior voids. The birch is about as well made but often has internal voids and often has internal plys that have been overlapped and either crushed flat and sanded. This sometimes photographs through the face ply. I used the underlayment because I thought the stripped grain on the face would be more attractive that the plain face of the birch. The end panels and bottom of the cabinet are Baltic birch. I already owned it. The underlayment was scraps.
Mark and Mark,
This house and the others I have done have been far from a coat of paint and perhaps fresh carpet. This one had a number of home owner rank amateur additions. It was stunningly bad. I thought I was used to it and a little jaded after doing about six others. Still taken aback. The father had done the poor work and then passed away in 1997. Since then the Second wife has live it to death and done nothing to maintain it. I bought it at a tax sale, sight unseen. I finally came to the realization the house was lucky (can a house be lucky?) it fell into my hands. It was a good thing I bought it cheap. Have spent about twice what I intended. Corrected hundreds of goofy things.
OTOH, as a Home Inspector, I inspected a house a bank was selling after taking it in at foreclosure. They had their team come in and put in fresh carpet and paint. Looked great at first glance. Talk about putting lipstick on a pig. There were hundreds of defects. Someone had turned the AC all the way down and left. When I got there it was solid block of ice. Ducts collapsed in the crawl space. Water leaking under doors, rotting the framing. Insulation collapsed. About ten wiring connections not in boxes. Brand new range, no cord on it. Dishwasher rusted out. A room addition on the back that had not been built with permits. They forgot or failed to run heat and AC. Very poor windows and doors. I can't bring myself to do work at this low level.
And my vanities were not part of the critical path. I built them while other work was being done. But you are right. That is a consideration. Does not make sense to save a few dollars on vanities to lose time or opportunity to sell the whole house. Cheap vanities would have cost about $800 and I built them for about $100 out of pocket, even considering the cost of the lumber I harvested myself. OTOH, my son is unemployed and one of the reasons for doing this is to provide him an opportunity to work.
Tom
I have used a lot of that stuff to make boats. I have even used the stuff with interior glue, unintentionally, but 30 years later I am still OK.
The face on some of the stuff I use is .6 mm. I can also find it with balanced 3 plies. Sometimes with exterior glue. It isn't necessarily worse than birch, for one thing weigh is a lot better, and as I am standing on it at times, it seems OK.
The really thin face plies may have a number of purposes, but one is that they will have very nearly the same stiffness 0 or 90. It might also hold screws better.
Here is a boat I was working on a few years back, I guess I need to get back to her. Not much to look at, but it is all underlayment, and it is a lot easier to make curvy boats than flat ones out of this stuff. Flat panels are a lot less stiff, and need a lot of structure.
Tom
More underlayment and doorskins...
Larry
:( I used that same Ply from Home Depot to build cabinets for a friend (he got it) the ply wood warp bad, and the top ply separated in places. Woun't use it again! Junk
Larry in nw ohio
I would write the Box Store where you bought it from and send a picture if you can. I did that when I got some from Menards and I got some money back and I got to keep the ply since it was installed. These places don`t care and they also don`t know about what comes in their stores unless people tell them it is junk and your not going to buy it anymore. I still buy it, but very little, depending where I want to use it. If I can hide the bad spots. Sit done and email them. Go on google and find out where the home base is.Larry
Where is a legitimate claim?
.....or complaint for that matter? Situation- used left overs from plywood designed to have flooring stuck to it with thick adhesive to make stained panels in a door. Result was not as attractive as hoped for because the face veneer designed to accept floor adhesive was to thin to be used for stained door panels.
I had two sheets of phony "Baltic birch" from Home Depot warp into a potato chip because it was more than 18% moisture content when I got it. Now that is a legitimate complaint, but my letter of complaint resulted in only an annoying form letter response.
The moral of these tales is don't buy plywood from either store for cabinet work. For cabinet work shop where the cabinet shops buy their stuff, or get a sheet from the cabinet shop. It might not be as cheap as Lowes but a few dollars on the plywood would not be my main concern when making hundreds of dollars of cabinetry.
Re: Where is a legitimate claim?
Larry in nw ohio
I got a very good reply from Menards, I haven`t tried anyone else yet. Larry
Jerry Roberts
I don't know abt ply from either HD or Lowes but I do know ill never buy anything of any size from HD again. The gave me such a runaround from a new washer I bought from them on their extended warranty I wont do it again. Ill try Lws or someone else but not HD. Ever!!
Bill,
Some how this has gone sideways....I am not complaining about the plywood at all. Technically, its perfect. Reasonably flat, no interior voids, almost clear back side, smooth and consistent faces. These cabinets could have been built out of rail road ties and pallets and they would have been better than what was in the house to start with. I have used a number of cheap box vanities form Lowe's and HD and these are better than those. And I suppose it suits my miserly nature to take nothing and make something out of it.
Re: It is an engineered product...
Tom
"The moral of these tales is don't buy plywood from either store for cabinet work."
While I wouldn't call that a moral, that is certainly one way to handle you situation as a consumer. Since I use plywood in ways in which I can get people killed, my approach is more scientific. I buy plywood with the same care I would any other wood product. In most cases it is downright outstanding material, at a steal-it price. I don't rely on the reputation of anyone that sells it or warrants it. Most of that stuff seems to be BS anyway. It is pretty well known that all the stamps and claims tell you is what stamps the factory has on hand.
The people you buy it from can mean a lot, but it is unreasonable to expect big box stores to warrant the materials they are making other than financially. They could not possibly sort it all out. And it gets downright ridiculous when one takes it to uses not contemplated by anyone connected with the product. At some level this can include a lot of cabinet type uses also.
But that does not mean you can only use stuff from certain sellers, if you want to use something oddball, assess it, test it, and if necessary, fix your mistakes. Your best friend is normally a test, and not a post. Wood is wood; glue is easily tested; then just understand what the various products are designed to do, then use them intelligently in your product. I frequently find products in the big box stores I can use in my projects. One is essentially buying veneer at pennies a square foot, in a structured format, gotta be good for anything that makes sense when seen as a composite with certain exploitable characteristics. If you want to learn more about what those characteristics are, you can consider various military manuals from WWII that explain it in detail. These are generally online in PDF format, a lot cheaper than when I had to order photostat copies back in the 80s.
Finally got this in the water:
