ot fluorescent ballast
Jerry Gibbs
How do I test if the ballast is any good. Jerry
Re: ot fluorescent ballast
John Veerkamp
Easy!
first make sure there is power to the ballast. Then put in known good bulbs in the fixture. If it doesn't light the ballast is bad.
replacing
I am probably the last person on earth to discover this approach. I used to install the new ballast and then wire it to each socket, destroying one or more in the process. No more. Buy a pack of the grey wire nut connectors. Cut the wires off the sockets leaving a few inches of wire- strip ends and wire nut these ends to the new ballast leads. Takes 5 minutes to do at most.
Make sure you get the correct ballast. T8 will not work with T12 lamps and visea versa.
Larry in nw ohio
Jerry If you do need a ballast, I have a bunch of them. If you want one or two, you are more than welcome to a couple. Just let me know what the number is or maybe send a picture of the label. Larry
Grant in Iowa
It would be helpful to know what type the ballasts are, but here are some tips:
-Rule out the bulbs as the problem by removing them and if they have two prongs on each end, test for continuity between the two prongs. Repeat on the opposite end, if no continuity between prongs on either end, then bulb is bad. Note that you won't get continuity between opposite ends.
-Flickering bulbs can overheat the ballast, thereby causing premature ballast failure. Therefore, fix a flickering light or face a more costly repair shortly.
-Often it is the sockets not making good contact with the bulb contacts, wiggle/twist the bulbs in the fixture socket a bit to ensure a good connection.
-Check bulbs in a known working fixture if one is handy.
Once you rule out the bulbs as the culprit, check the supply voltage where the ballast connects to house power. If the voltage is good and the bulbs and their connections are good, you have a bad ballast.
Milwaukee makes a $200 tool for testing fluorescent lighting, so if you have a lot of them to test, then you might benefit from one. Google Milwaukee fluorescent tester.
Regards,
Grant in Iowa
