Tuning up a table saw...my way
Mark Hennebury
Starting to work on tuning up a 1950's Robinson ZT sliding table saw.
The set-up:
One good saw
Good old Stereo system
Kick-ass albums
Good supply of "Old Speckled hen"
Abrasive powder
Disc grinder
Serious straightedge
Feeler gauges
Commitment to see it through.
First thing for me is to get the table and sliding table flat.
Once i have flat surfaces then i can reference everything from them.
This is really hard dirty work, so i want to get this done first.
The sliding table is about .015" out overall; seems that the thin edge closest the blade is dropped at the front and rear. This part has no ribbing underneath for support, so its not really surprising.
Just means a lot of work to bring the rest of the table down.
So what i am going to do is check for high spots, then grind them away until the entire table is relatively flat, then i will polish the surface.
Traditionally this would be done by hand or power scraping, either way it is just a method of removing metal.
first check with the Straight edge, to get some idea of what is what.
then put abrasive powder and varsol or WD40 on the main table of the saw and flipping the sliding table on to it and lapping it for ten or more minutes. (good workout)
Then remove the sliding table turn it over and check to see where the high spots are, these will be the areas the have been abraded, also check the main table.
Then i grind away the high spots and repeat, many times. constantly checking progress.
This is a lot of thirsty work.
