THE WOODRAT IS BACK!
drill granite
drill granite
drill granite
mike mcnerney
I am building a handrail at the cottage because I'm elderly & all my friends are elderly & it is fairly steep. The previous owner built some very nice granite steps
& they are solid. I purchased a steel base that holds a 4 x 4 & reguires 4 fasteners to hold each. I need to drill 32 holes.
With my relatively small, corded ridged drill I drilled a 1/2" x 2" hole for a lag shield. I installed the lag screw & it worked. Problem is the 40 buck special carbide bit designed for granite & rock took 15 mins to drill. That feels too long.
So then I drilled a 3/16" (.187) x 2" hole & tried the tapcon (.240) ( but it stripped the thread.
It turns out the smaller tapcon is (.202) so I am going to try that today. I'm thinking about adding some PL premium to the hole.
My questions are:
Would a larger rotary hammer type drill & maybe a different bit do a significantly faster job on the 1/2" hole.
Can I make the tapcon work?
Is there another alternative?
Mike
Re: drill granite
Diamond core bit...
John in NM
That should drill much faster, most need water as a coolant. I saw some at Lowes last time week, first time I've seen them outside a specialty store. I didn't note the price I'm afraid.
Tapcons will not work, granite is far to hard. Construction adhesive in the hole will not work either, but there are specialty epoxies that would do the job. You could drill smaller holes and epoxy in some threaded rod that then would get a cap nut. I don't have any brand names or sources for you I'm afraid, it's been 15 years or more since I used any.
Re: drill granite
Consider renting a rotary hammer
I wish I'd bought a rotary hammer years before I did. Rotary hammers allow the bit to "bounce" from the hammer action, and drill hard substances much faster than a regular drill. I drilled four holes in a granite-like rock* in the retaining wall by our back gate to install a magnetic "catch" to hold the gate open, and the rotary hammer just sailed through the drilling. When my son drilled holes for the hook we later installed, after the magnetic catch proved it was weaker than the afternoon winds, he didn't have any trouble either.
I use mine often enough to justify owning, but they're usually not too expensive from the rental yard.
If you can find lead shields for the screws, I'd use those rather than Tapcons or the larger Simpson concrete lags (Titen bolts).
*I did terribly on the rock ID in my geology class 45 years ago. The rock may or may not be granite, but it's definitely igneous and hard.
Re: drill granite
Re: Diamond core bit...
Ralph Lipeles
That's what the contractor used when he added rails to my front porch. It was poured concrete that had been faced with stone. He cut holes that were a little bit over 1" in diameter. The rails had 1/2 by 1/2 posts extending out the bottom and he set them in epoxy cement that was in the drilled holes.
Re: drill granite
Re: drill granite *LINK*
Joanne in Point Pleasant, PA
My Dad used to do a lot of lapidary work. He drilled holes in rocks for pen bases, clocks, etc. He used diamond-grit edged hole saws in a drill press (with water cooling feature). Something like these:
Or these:
http://www.mkdiamond.com/tile/bit_190.html
http://www.rakuten.com/prod/lenox-tools-121108dgds-diamond-grit-hole-saw-d-s-8dg-1-2-inch-or-12-7mm/222791463.html?listingId=270771219
Re: drill granite
hammer drill is the key
It is phenomenal how much faster a hammer drill drills rock and masonry. Might try a rental place to obtain one for the task. The carbide bits can be sharpened with a silicon carbide wheel.
Re: drill granite
Re: hammer drill is the key
Bill Howatt
It is hard to believe the difference in speed. I bought an el cheapo Chinese hammer drill a few years ago for only $30 and it was the best money I ever spent. Naturally, it only gets used infrequently but I certainly got my money back especially considering the rental hassle and cost.
A trick if you are using a regular drill on concrete is when the cutting "stops", get a center-punch and whack whatever is in the bottom to the hole a few times. Usually it is a rock and the punch may break it up to make it easier for the bit to handle. This trick probably is useless if drilling a piece of granite.
Bill
Re: drill granite
Re: drill granite
Dale warder
The tool you are looking for is a SDS hammer drill. This drill uses a special shank bit which is loosely held in the chuck. The drill provides both rotational and hammer action, but because of the shank and chuck provides the hammer action only to the drill bit. Carbide hammer drills are used dry. It is amazing how quickly these drills cut granite or other stone. Most rental shops in this area have them, and I regularly see them in local pawn shops.
Re: drill granite
Second the SDS Drill
I have a medium sized Bosch version and its a very useful tool. It will drill or hammer or drill and hammer at the same time. One set of granite counter tops the installer used it to drill holes for the mount holes for the dishwasher, (I was chicken, but the installer drilled those holes in seconds.
I have drilled hundreds of holes in concrete, used it as a jack hammer to cut a section of concrete to allow for a drain pipe and a shower, and used it with a chisel blade to clean crap off concrete. Also have a core drill bit for it and it will drill 2" holes in brick and concrete as if they were butter.
Re: drill granite
Terminology
In case you go shopping for a tool to rent or buy:
My understanding is that a hammer drill is a regular drill with a hammer feature applied in the transmission. You use carbide masonry bits with a regular straight drill shank. These are useful up to about 3/4", depending on rating; but they vibrate a lot.
Rotary hammers use special bits - SDS or SDS Max being the most common, although larger sizes use spline bits - that, as others have pointed out, apply the hammering force to the bit only, thus saving your hand from feeling like it shook hands with the Hulk.
Like Barry, I have a little Bosch, and man am I glad to own it; but for a few holes, rental makes more sense.
Re: drill granite
Re: drill granite
R Payne
A rotary hammer is the correct tool for this job. IF you want to try something else before renting one, you could try flooding the hole as you are drilling with your hammer drill with water. The water will help some and may make the drilling with a hammer drill. If you aren't using a hammer drill, you can still try the water and it could help some.
Re: drill granite
Water will help only without the hammer action...
John in NM
The water in the hole should act as a bit of a shock absorber, it will impede the hammer action but might help some with a regular drill and carbide bit, but not a lot. The one exception I've seen is drilling our local sandstone. The sand grains are cemented with gypsum, which softens considerably when saturated with water. Soak a hole with water and the next day drilling is a bit faster. And to think they always joked at the drill rig about sending the newbie to ask the supervisor for some "hole softener" :D
I've drilled a lot of holes in concrete and sandstone with hammer drills and rotary hammers, I would be too chicken to use one near the edge of a granite step - where the railing goes :D But Barry's story of the countertop installer using one might be enough to convince me to try one day.... on someone else's granite! :D Given the short stroke of even heavy rotary hammers, it makes sense they might not crack a tough stone like granite.
Re: drill granite
Exactly......
I let the installer drill the holes based on the premise that at that point it was HIS granite and if he broke it, HE could replace it. If I broke it, I did not have a lot full of granite to draw a replacement from.
I had not thought about the position of the holes on the steps. I would be reluctant to drill holes near the edges. Not only the drilling itself might be a problem but the expansion of the shields might put the granite in tension and the flexing of the posts when under load might add to the stress. I think I would try to choose a mounting method that did not put too much strain on the stone.
Re: drill granite
Re: Exactly......
mike mcnerney
thanks folks sounds like the rotary hammer with the sds
MM
Re: drill granite
Re: Water will help only without the hammer action
R Payne
I've drilled holes with a rotary hammer with and without water flooding the hole, same piece of rock. The first couple of holes were without water then tried using water. It was definitely faster with the water and the hammering. The water didn't act as a shock absorber. Just my experience.
ron
Re: drill granite
Re: drill granite/A dissenting view
Justin Szeliga
I wouldn't take a hammer drill to a piece of granite unless it was quite massive & very far from the edge. A wet drill, even an sds, with no hammer, & flooding the hole with water will work.
Then I'd use the biggest, softest lagshiel
ds I could find & tighten VERY carefully, or if I could through bolt with some sort of sleeving to keep the steel fastener from the granite.
