Oil Spec`s (OT)
Larry in nw ohio
I`m going to change the oil in a friend of mines pressure washer and need to know something I really never did know. In the manual it says to use oil that is SJ/SL rated on the API label or better. What would be better, having oil that has only SN on the label or SM. Is it better as they put a different letter behind the S that is down the alphabet on down to the Z as being better. Thank You Larry
