Forgot how to fold a band saw blade
Actually, I really never knew. I would just grasp a blade palms up, flip it in some way now forgotten and it would neatly coil into three circles as if by magic.
I have seen large blades fooled in a deliberate step wise fashion into the storage coil but never learned how that was done. It is this technique I would like to learn. Anyone know of some web site that explains it well?
Re: Forgot how to fold a band saw blade
roger lance
Bill....go to YouTube....type in "fold a bandsaw blade"....you'll get several videos
John in NM
Hold the blade on opposite sides of the circle, each palm facing the same way. Twist each wrist in the same direction while pushing them together.
Never tried to put it into words before :D
Hoa in Alameda
I don't have the courage to fold a bandsaw blade with 2 hands. :\ I use a hand and a foot.
The way I do it: Hold the blade, teeth away from me, with my right hand, palm facing up. Step on the blade with one foot. Twist the hand holding the blade while pushing the blade down.
Easier doing it than describing it.
in our articles
Tom
Youtube would be the place, but in the interest of attempting a verbal explanation... take it so the blade lower is about belt height, grasp the upper part with the fingers back towards one in a pull up position rotate the hands towards each other and down, so the blade takes on a potato chip shape so it looks like a C from the sides or the top. Keep bringing it together until the tops overlap and let the sides collapse in. You will have three loops.
The trick is in getting them out.
del schisler
their are 3 ways to fold a band saw blade, here is the one , step on the blade not on concreat , it will maybe take the set out of the blade, step on blade not with the right hand put your palm under the blade and now twish and brind the blade down to your feet it should start to curl now it should be in 3 little coil's that come togother.
here is a video of this http://www.youtube.com/watch?v=KRarn9st2bg
followup
I tried the step on it method everyone seemed to know about except me and it worked uneventfully even with a large blade and no woosy gloves. Beat the "flip it between two hands" method I had forgotten how to practice.
But, when the Lenox tech rep talked to our club he used a deliberate fold it up coil at a time method that could be used to fold, or unfold, large blades. I had never seen this technique used before or since. If anyone has a reference I remain curious.
