ADVERTISE HERE - FREE TRIAL
Windows XP
Windows XP
Windows XP
Tom
I am thinking of picking up a few windows XP machines so that I can keep running my turbo and auto CAD, and various other programs. And possibly also some software for CNC. I looked at the cost of upgrading my copies, which are pre XP, and it is thousands of dollars for a program I use to design simple boats and stuff.
In the old days when one bought a computer, that was what one had until one upgraded or bought something new. But these days the computer is constantly trying to communicate with the mother ship and import changes. If I did not connect these boxes to the internet, would they just do what they are told to do indefinetly? Is there some instruction one can give to the box to abandon all hope of outside contact and just function as is for ever? I have other computers for my connectivity.
Re: Windows XP
Re: Windows XP
John in NM
Probably you could do so. I see quite old machines running as retail cash registers and stuff like that. As long as they work with the CNC hardware and software you want to run, there is no reason why they would need to be updated. You should be able to turn off the automatic updates feature, though one reason I rarely use MS products is that it seems you have to turn off stuff like that in six places before it takes :D
Of course, you will run into problems when you have a hard drive crash or the like. In addition to difficulty finding older hard drives, your XP software may be irreplaceable if it was pre-installed. Older versions of Windows allowed you to make back up CD's of the OS, last one I had was an XP-pro install that did not let you do that (at least I never could figure it out).
Re: Windows XP
Re: Windows XP
Chuck in Mtl.
yes if the computer is only used for controlling something and never needs updates then just disconnect all links to the network. I would strongly recommend you make an image of the disk in case the hard drive fails.
Re: Windows XP
Re: Windows XP
Joanne in Point Pleasant, PA
And turn off Automatic Windows Update in the control panel.
Re: Windows XP
Another thought
Lee Schierer McKean, PA
You can get Double Cad XT3 for free and it will run all your old drawings and works pretty much the same as AutoCad. I use it for my drawings that I created with Autocad Lite R14. It runs on Windows 7 and also on my XP machine.
Lee
Re: Windows XP
Running on Window 7
Craig
If you've got 2006 or newer this tip might help
I could not run on a Windows 7 unit and I tried this trick and it worked like a charm.
Good Luk
To run autocad 2006 on windows 7 you have to change some settings;
1)When you start the installation of AutoCAD on windows7 remember to install it as an administrator.
2)After installation go to the autocad icon on the desktop ,Right click on it>go to properties>the go to: compatibility tab>now tick on (run this program in compatibility mode for:) > then click on change the setting for all users >click on apply and ok.
3)Now open autocad ,it will show a message but tick on dont show this message again.
4)Done!!
http://hackycracky-pushpendersng.blogspot.com/2012/05/how-to-run-autocad-2006-in-windows-7.html
Re: Windows XP
Re: Windows XP
Jerry Nicholson
Windows XP will run just fine disconnected from the internet after it has been activated. If you have to reinstall you will of course have to re-activate it. You can probably still find copies of Windows 2000 if your software will still run on that "oldy but goody". Win 2000 does not have to be activated and hasn't had any support from Microsoft for 3 years. You would need to have Service Pack 4 (SP4). Win 2000 will run anything that Win98 ran and probably anything that Win XP will run. It should not be used to connect to the internet but can be used on isolated LANs. I have had very good luck with it running stand-alone and it runs well on old equipment that would really bog down with XP, ie. computers with 233mhz pentiums and 256mb RAM.
Jerry
Re: Windows XP
Added Info
Jerry Nicholson
Eb-bay shows numerous offers from Win 2000, many claiming to be original and sealed. If you still have a Win98 or Win95 disk around, you can install the upgrade version of Win2000. I don't know where to find a copy of SP4 to go with it.
Jerry
Re: Windows XP
Might as well throw in
Bill Howatt
You can also setup a virtual PC in Windows 7 and other OSes and load XP into the virtual machine. I ran Turbo-Cad in XP using a MS virtual PC. Can't say I pushed it but it certainly ran OK.
MS offers a free virtual PC but there are others you can buy which may provide more features.
I strongly second the suggestion to make an image of your working system. This makes reloading the OS and applications a breeze it you have to replace the HD which is probably the most likely component to fail and is certainly the component that will upset your program operation if you don't have a backup.
Bill
Re: Windows XP
Re: Windows XP
Kurt
I read once that when support for XP ends in April 2014, activation and activation servers will be turned off. I don't know if windows updates up to the end of support will remain available or not. Longer term, I wonder if manufacturers will provide and support WinXP compatible hardware such as disk drives and video cards. Another thought I had is I wonder how long VMware & VirtualBox/Oracle will continue to support Windows XP virtual machines.
Just for grins a few months ago I installed VirtualBox on an Ubuntu machine and installed Windows as a guest. It was quite simple to do and worked very well at least for basic stuff. I could enable or disable internet access for XP as I desired. This way I could use Ubuntu for things requiring internet access and XP for things that only work on Windows and don't require internet access such as CAD and Adobe's non-cloud edition software.
