Tour of Baillie Lumber Mill
Bill Tindall, E.TN.
Tour of Baillie Lumber Company
Baillie is one of the largest hardwood lumber companies. I recently toured their Donalds,
SC facility. This mill only saws oak and poplar lumber and gum for cross ties. Their log grade is not high so the sawing strategy is different at this mill from that at a mill sawing higher value logs. Here the strategy is to enhance productivity rather than tease the best yield from each log.
PIC1
After debarking, a process described in my Article in the Articles Section, the logs are carried to the “head saw”, in this case a band saw. A laser scans the log to determine its shape and size and the saw is programed to make the most efficient first cut to remove a bark slab. The rest of the sawing is under the sawyer’s control. Several boards are sawed from this side of the log. Then the log is turned 180 degrees and a bark slab and boards sawed from the opposite side, to yield a “cant” 8” thick. This sawing takes 15 to 20 seconds for the logs they were sawing the day I toured.
PIC2
The cant is conveyed to the “gang saw” where an assembly of 8” saws rip the cant into boards. The gang saws are spaced to yield thickness to match anticipated orders. Boards with bark edges from the head and gang saws are conveyed to the “edger”. A scanner detects the size of the bark edges and sets the rip saw to remove the bark edges. This machine was buried within the chains moving lumber and I could not get a picture of it.
PIC 3
All the boards then pass by the graders, who, with a multitude of UV fluorescing crayon symbols, mark the lumber for grade, where it is to be trimmed and other information required for automated end trimming and sorting.
PIC 4
A “reader” reads the grader’s marks and sets the trim saw to cut the lumber to length for best price of the trimmed piece.
Pic 5
The boards are now positioned on the sorting chain. The length, width, thickness, species, and grade for each board at each position on the sorting chain is recorded in a computer.
PIC 6 and 7
As the chain carrying the boards traverses the sorting machinery the computer lifts a diverter and dumps each board into a bin according to length, width, thickness, species, and grade. This sorter has more than 60 sort positions.
PIC 8
When a sorting bin has about 2000 bd ft accumulated in it the lumber in this bin is lowered and conveyed to the end of the sorter where it is picked up by a fork lift and conveyed to the stacker to be put on sticks.
PIC9
The sticks are grooved to enable air flow across the stick for faster drying and less sticker stain.
PIC 10
After the lumber is put on sticks it is dipped in chemicals to retard mold, iron staining and kill insects.
PIC 11
At this mill the ends of the lumber are sprayed with a clear wax emulsion and then the poplar lumber is put directly in kilns. Oak is set out on the yard for air drying. The thicker oak lumber is covered to control the drying rate. You are looking at 1,000,000 bdft of kiln capacity, with several more million bdft of oak air drying to remove some moisture before kiln drying. Unusual for a mill, this one uses methane rather than wood waste for kiln boiler fuel.
PIC 12
After drying the lumber is unstacked, graded and reassembled into stacks by species, grade, thickness and length and the bundles stored in the “dry shed”. This shed has 3,500,000 bd ft capacity and it was full earlier in the year.
PIC 13
To fill orders packs are pulled from the dry shed, “prettied up” and sent to customers worldwide.
